Go Back   SaturnFans.com Forums > Reference Forums > Mods and Performance
Old 02-04-2004, 05:05 AM   #1
JDub99SL2
JDub99SL2 is on a distinguished road
Default Rear Disc Conversion
A couple weeks ago, I bought all the required parts to convert the rear brakes over to disc from Sleepr. In case any of you were interested, there are some pictures of the final product in my gallery.
Overall, the installation is not difficult at all. The best part is getting to go crazy on the drums and just rip 'em apart! :-)
The worst part is bleeding the new calipers. Ughhhhh. I am still not sure I've got ALL the air out, but the brakes work great, so I'm not worried. I may bleed them again, when I get a chance.
Overall, this was definitely very worthwhile and if any of you are considering this upgrade, I highly recommend it and don't be afraid to do it yourself!!!
Oh, I didn't bother swapping the brake hoses. The length seems to be just fine. Plus, the clip that holds the line in place is a bi***.
Add to JDub99SL2's Reputation
Rate the quality of this post and help JDub99SL2 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JDub99SL2 is offline
Old 02-04-2004, 10:02 AM   #2
eRic 02sc2
eRic 02sc2's Avatar
Default
SWAP THE rear BRAKE HOSES. a saturn brake engineer warned me about using drum hoses on the rear discs. yes, they will connect and 'work', but there is a risk of the drum hose ends popping out (and gushing brake fluid) of the caliper from suspension movement. the rear disc hoses have the metal section on the end for a reason. oh yeah i used russell speed bleeders in mine to make bleeding easy after i did the rear discos on my old 92 sc and now 96 sc2.
eRic 02sc2
WHRRi 2007,2010 Fun Run 1st
DR SCCA Solo 2009 2nd ST
DR SCCA Solo 2010 1st ST
eRic 02sc2 is offline
Old 02-04-2004, 10:35 AM   #3
bennett9000
bennett9000 has a spectacular aura aboutbennett9000 has a spectacular aura about
bennett9000's Avatar
Default
I'm still on drum hoses, but I have a set of disc hoses I'm going to put on SOON. There IS a difference, like Eric says. I'll take a side-by-side photo when I do it.
Really, you should swap the lines.
-Andy
01 SL1 (2011-2014) 99 SW2 (2002-2009) 95 SL2 (1997-2002)
00 ROUSH Cougar V6 03 SVT Focus #2370 08 Mustang Bullitt #5389 2013 Fiat 500 Abarth
Add to bennett9000's Reputation
Rate the quality of this post and help bennett9000 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bennett9000 is offline
Old 02-04-2004, 11:59 AM   #4
fogdrive
fogdrive is on a distinguished road
fogdrive's Avatar
1993 SC2
Default
You should get SST braided hoses. That way, you will not have to worry about replacing them again.
330K before a Hondog rear-ended me and totaled it out :(
Add to fogdrive's Reputation
Rate the quality of this post and help fogdrive reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
fogdrive is offline
Old 02-04-2004, 03:49 PM   #5
JDub99SL2
Default
I am planning on putting on the steel lines that tirerack has sometime in the near future. I don't see how there can be such a big difference. I'm not engineer, though. Man, you've got me all paranoid. I was going to say that 80%+ of the braking is done up front, anyway, until I realized that if the actual hose 'popped off' there would be no hydraulic pressure --- er.... man, I may just walk to work. :-( Thanks ERIC! Lol.
Old 02-04-2004, 08:59 PM   #6
Tycho
Tycho is on a distinguished road
Tycho's Avatar
Default
19 months/20,000 miles on drum lines.
They aren't even close to touching the wheel or anything in that region.
Forced induction is rape.
Add to Tycho's Reputation
Rate the quality of this post and help Tycho reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tycho is offline
Old 02-04-2004, 09:30 PM   #7
bennett9000
Default
No - it's not that they TOUCH anything; they are just kinked REALLY tightly (or rather, more tightly than they should be), which causes premature wear.
-Andy
Old 02-05-2004, 02:28 AM   #8
winc
winc is on a distinguished road
Default
almost a year now on drum lines, just checked them again 2 weeks ago, still fine. not kinked at all as far as I can see. But I have the replacement disc ones just in case they do. I'll probably do the steel braided ones if I ever change them again. Bleeding is easy for me, I have access to that vacuum pump from snap-on for quick bleeding.
'95 SL1 auto (retired)
'02 RSX 5spd (her baby)
'05 WRX 5spd (my baby)
Add to winc's Reputation
Rate the quality of this post and help winc reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
winc is offline
Old 02-05-2004, 10:30 AM   #9
eRic 02sc2
eRic 02sc2's Avatar
Default
drum hoses used on the rear discs shouldn't touch anything. the issue is when the rear suspension is hyperextended with the wheel fully drooped. that will straighten out the hose and could possibly pull the end of it out. make sure your parking brake is functional, just in case.
eRic 02sc2
Old 02-05-2004, 10:35 PM   #10
KevSC1
KevSC1 will become famous soon enough
KevSC1's Avatar
2008 Astra XR
1995 SC1
Default
Eric, I know you and I have disagreed about this for years
I have had rear discs on the car for nearly 5 years, still using the drum lines. When I swapped to stainless lines, SPS sent me long (drum) ones, even though I specifically said I had disc brakes. In talking with other GM engineers (besides the one that Eric has talked to), there is not an issue.
and with the condition of the streets around me, my suspension gets VERY hyperextended.
Add to KevSC1's Reputation
Rate the quality of this post and help KevSC1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KevSC1 is offline
Old 02-07-2004, 10:46 AM   #11
eRic 02sc2
eRic 02sc2's Avatar
Default
hey, i'm just going by what a saturn brake engineer warned me. i didn't want to prove him wrong (or right!) so i used the correct parts when i did mine.
eRic 02sc2
Old 02-07-2004, 02:36 PM   #12
Tycho
Tycho's Avatar
Default
Yeah...better safe than sorry.
No worries...
We're just saying that the drum lines can work if you don't have the disc ones.
Tycho is offline
For those with rear-disc conversion Vertigoomg Mods and Performance 15 10-21-2005 05:52 PM
Rear disc conversion - no how-to? sps SOHC S-Series Tech 46 09-08-2005 09:24 AM
Rear disc conversion Masterson Ion General 7 09-06-2004 10:11 PM
Rear Disc Conversion dschrader S-Series Mods 20 04-14-2004 11:55 PM
Rear disc conversion Bar(long a) S-Series Tech 7 02-23-2002 08:04 PM
