Old 12-30-2008, 11:06 AM   #1
atldad
atldad is on a distinguished road
Default Replacing valve cover gasket on 2002 L100 - need torque settings
84,000 miles and have oil leaking out backside above the exhaust header - smells wonderfull.
Got the OEM replacement kit from NAPA.
Anyone have the correct torque settings for all the bolts?
I searched here and found a link on a racing site that said 98 ft/lbs for the DOHC version but not sure if that applies to mine - which is stock.
Thanks all
Add to atldad's Reputation
Rate the quality of this post and help atldad reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
atldad is offline   Reply With Quote
Old 01-04-2009, 06:45 PM   #2
born again
born again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of lightborn again is a glorious beacon of light
2000 L-Series 2.2L Wagon
Default Re: Replacing valve cover gasket on 2002 L100 - need torque settings
The specification is 22 ft-lb + 155 degrees
Start with the centre front bolt, then the centre rear, then the pair towards the timing chain F/R, then at the timing chain F/R, then out towards the drive end. The 155 degrees should be in two stages, first 75 degrees, then complete to 155 degrees (80 more). Note - these are torque-to-yield bolts and must be replaced with new ones if loosened/removed.
Note - this is for the 2.2 Litre L-61 engine as spec'd for MY 2000. If you need the 3 litre then post back.
Add to born again's Reputation
Rate the quality of this post and help born again reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Replacing the valve cover gasket SaturnManiac S-Series Tech 29 02-19-2017 07:05 PM
MJO's guide to replacing valve cover gasket on Aluminum valve covers for S-series mjo How-To Library 2 04-26-2011 01:56 PM
Currently replacing valve cover gasket - question giants55 S-Series Tech 2 10-23-2008 02:53 PM
After replacing the valve cover gasket striker1584 S-Series Tech 1 09-15-2008 06:54 PM
replacing valve cover gasket. kingvandal S-Series General 22 01-22-2008 01:27 PM
