Closed Thread
Old 11-23-2004, 08:50 PM   #1
silverblueL200
silverblueL200 is on a distinguished road
silverblueL200's Avatar
Default Brake lights working intermittently
I noticed tonight that my brake lights are not coming everytime. Also, when I try to shift out of park, I have to hit the brake pedal 3 or 4 times before the switch in the shifter "clicks" and I can pull it out. This started within the last two days. I assume the root cause of both of these is the switch/sensor on the brake pedal. My questions are where is it, how do I replace it & how much does it cost?
TIA.
- 2003 Saab 9-3 Arc
Hello, mother. I come bearing a gift. I'll give you a hint. It's in my diaper and it's not a toaster. -Stewie Griffin
Add to silverblueL200's Reputation
Rate the quality of this post and help silverblueL200 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
silverblueL200 is offline
Old 11-23-2004, 11:35 PM   #2
ssicarman
ssicarman's Avatar
Default Re: Brake lights working intermittently
You may not need to repalce it. It may just need to be adjusted. Get under the dash and have a look to see if that is the case. Something may be bent or perhaps the switch has moved inits mount and is out of adjustment.
What year is the car?
Add to ssicarman's Reputation
ssicarman is offline
Old 11-23-2004, 11:51 PM   #3
silverblueL200
2002 L200 @53K - sorry, used to having sigs
- 2003 Saab 9-3 Arc
Old 11-25-2004, 01:47 PM   #4
silverblueL200
I crawled under and looked at it, the switch is aligned propely, however when I push the pedal in the switch is making a popping sound, must be shorted out.
Off to Saturn tommorow I guess
- 2003 Saab 9-3 Arc
Old 11-26-2004, 01:50 AM   #5
madpogue
1996 SW2
Is the "plunger" going in and out normally? Are you seeing any arcing / sparking when it pops? If it's "shorting", you'd have the opposite effect, that is, the brake lights would be on when you aren't pressing the pedal. Maybe the contacts inside the switch are just shot, or corroded (which, in all likelihood, means new switch time anyway). Look also for any external short, that is, any place where either wire could be contacting a ground outside the switch. Deal with that first.
If it is the switch, I would think you could find an aftermarket. Can't say for sure, but it doesn't seem to be the kind of part that, quality-wise, would compel you to go OEM (like with, say, a PCV valve).
Add to madpogue's Reputation
madpogue is offline
Old 11-26-2004, 12:08 PM   #6
silverblueL200
It is moving in and out smoothly & with the pedal. I'm going to try and follow the wires today, thats not the easiest place to work.
- 2003 Saab 9-3 Arc
Old 11-26-2004, 02:02 AM   #7
sierrap615
sierrap615 is on a distinguished road
sierrap615's Avatar
it sounds like its just sticking
Formerly - Saturn of Downers Grove Parts Department
Current - Castle Chevy in Villa Park Parts Department
EPA 608 Certification
EPA 609 Certification
Add to sierrap615's Reputation
Rate the quality of this post and help sierrap615 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sierrap615 is offline
Closed Thread
help please- brake lights not working jcono Vue Tech 12 06-13-2018 04:08 AM
Fog Lights, Dashboard lights, Tail lights are not working dbunch Vue Tech 8 10-10-2015 04:33 PM
2000 LS1 brake lights aren't working sirtwist2 L-Series Tech 7 06-20-2011 02:28 PM
Brake lights arnt working????? jcurrieirocz S-Series General 9 03-15-2005 12:17 AM
tail/stop/brake lights stop working? (QUICK FIX INSIDE) BLUEION2 Ion General 17 06-21-2004 08:04 PM
