Old 07-17-2006, 07:57 AM   #1
ouananiche
ouananiche is on a distinguished road
Dizzy Can't set clock on new 2006 Vue
I'm usually pretty good at this, but for some reason I can't change the clock setting on my basic CD radio in my new Vue. I press the clock button, get the hours or minutes flashing, then try to turn the tuning knob, the seek buttons(as prescribed in the manual) and absolutely nothing happens. Can anyone help?
Add to ouananiche's Reputation
Rate the quality of this post and help ouananiche reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ouananiche is offline   Reply With Quote
Old 07-17-2006, 08:16 AM   #2
Swishguy
Swishguy is on a distinguished road
Default Re: Can't set clock on new 2006 Vue
Been der dun dat. You must turn the dial on the far top passenger corner of the radio move the hours & minutes after you press the clock button. Drove me nuts but after 2 days I figured it out.
Add to Swishguy's Reputation
Rate the quality of this post and help Swishguy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Swishguy is offline   Reply With Quote
Old 07-17-2006, 09:45 AM   #3
ouananiche
That is the tuning knob, I believe. Done that. Unfortunately does nothing. I will keep trying. Thanks.
Old 07-17-2006, 01:00 PM   #4
GearGuy
GearGuy is on a distinguished road
GearGuy's Avatar
I don't have that specific radio but can you push one of the "preset" buttons to choose hours or minutes, and then adjust with the knob? That's the way it works on mine.
If I hit the button, it highlights the minutes for adjustment.
2006 Vue 3.5L FWD
Add to GearGuy's Reputation
Rate the quality of this post and help GearGuy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GearGuy is offline   Reply With Quote
Old 07-17-2006, 10:08 PM   #5
ssicarman
ssicarman's Avatar
Are you doing it with the radio on?
Add to ssicarman's Reputation
Old 07-18-2006, 01:17 AM   #6
GearGuy
GearGuy's Avatar
Ok. Checked the manual for the base CD radio without date display...
This is what you have, right?
Looks like you are doing what it tells you to....
The forward and reverse buttons are also supposed to work.
You have to start changing the time within 5 seconds or it will set to whatever time is on the display and you will have to start over.
All I can suggest is that you try it with the radio on and with the radio off to see if it makes a difference.... It doesn't specify in the manual.
2006 Vue 3.5L FWD
Old 07-18-2006, 07:31 AM   #7
ouananiche
Default Got the clock setting to work. THANKS!
Finally got to adjust the clock. Yes, the radio needs to be on when making an adjustment. Having the accessories or ignition on is not enough. Thank you for your help.
2006 Ion clock/radio display randomly shutting off mj3783 Ion General 2 06-04-2008 10:51 AM
How do I set the clock on a 97 SC2 lorelei2007 S-Series General 10 01-23-2008 11:29 PM
dumb ? how do I set my clock (1998 sl1) joe872004 S-Series Tech 4 11-17-2006 03:15 PM
How do I set the clock? crchli_vjc L-Series Tech 1 10-29-2005 04:48 PM
How to set the clock on a factory tape player in a 1994 saturn sl? uncle420 S-Series Tech 3 02-03-2005 03:49 PM
