Old 05-18-2005, 12:05 PM   #1
geartooth94
geartooth94 will become famous soon enough
geartooth94's Avatar
Default power steering fluid on alternator
I took the alt. shield off while taking off the powe steering pump. After disconnecting a p/s line from the pump, a few ounces of steering fluid got on the bare alt before I could get a rag. I also got some fluid in the plastic connector that goes to the alt and holds two very small gauge wires (not the larger single orange wire). What does this connector do, and will the steering fluid harm the contacts inside?
Is any of this a problem, or should I replace the alt. and connector before proceeding? This is on a '94 SL2 b/t/w.
1996 Dodge Avenger ES: 2.5L V6
Add to geartooth94's Reputation
Rate the quality of this post and help geartooth94 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
geartooth94 is offline   Reply With Quote
Old 05-18-2005, 12:30 PM   #2
ud503j
ud503j is on a distinguished road
ud503j's Avatar
Default Re: power steering fluid on alternator
I can't imagine it would be an issue...as far as I'm aware power steering fluid is neither conductive nor corrosive (at least not terribly so.) I've thrashed an alternator pretty good on my Blazer....had mud in it and everything with no ill effects.
1997 SW2 --> 'Vi'
g/f's 2002 SL2 --> 'Raven'
R4V3n SP33D's boytoy!
Add to ud503j's Reputation
Rate the quality of this post and help ud503j reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ud503j is offline   Reply With Quote
Old 05-18-2005, 12:33 PM   #3
dixonba
dixonba is on a distinguished road
dixonba's Avatar
2007 ION-2 Sedan
I've drenched my alt with ps fluid before. Hasn't hurt it yet.
I have heard of incidents of alternator failure due to ps fluid constantly dripping on it though...
Add to dixonba's Reputation
Rate the quality of this post and help dixonba reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dixonba is offline   Reply With Quote
Old 05-18-2005, 02:25 PM   #4
blackeagle1
blackeagle1 is on a distinguished road
blackeagle1's Avatar
2000 SL2
1997 SC2
How did you end up getting the lines off the pump? I made an attempt to replace mine but couldn't budge the fittings on the steering rack and couldn't figure out how to access the fittings at the pump.
Add to blackeagle1's Reputation
Rate the quality of this post and help blackeagle1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
blackeagle1 is offline   Reply With Quote
Old 05-18-2005, 11:23 PM   #5
sierrap615
sierrap615 is on a distinguished road
sierrap615's Avatar
wipe it off, inspect it, maybe spray it with electrical cleaner. unless that alternator is more then 3 years old, thats about the life of many S-series alternator. many S-series alternators do fail from engine oil leaks, but the key there is that the oil is normally hot dripping with the engine running. the two wires i beleave go to the dash for the charge light and the other is for the field coil.
i whent THRU the pulley
Add to sierrap615's Reputation
Rate the quality of this post and help sierrap615 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sierrap615 is offline   Reply With Quote
Old 05-18-2005, 11:45 PM   #6
ssicarman
ssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to allssicarman is a name known to all
ssicarman's Avatar
Long term oil soaking into the alt will shorten it's life. A dump of oil into it---clean it out with something like brake clean or as mentioned contact cleaner let it dry and then you should be ok.
Add to ssicarman's Reputation
Old 05-19-2005, 07:12 PM   #7
geartooth94
I also have to get just that ONE line off the pump: the one with the nut on the steel line. Just HOW did you go through the pulley to access the nut?
Old 05-19-2005, 07:37 PM   #8
kmix99
kmix99 is on a distinguished road
kmix99's Avatar
1996 SL2
1999 SC2
remove the pulley with a pulley-puller with the line still attached, then you'll have good access to the nut. The nut on my 1997 SL2 steel PS line was not metric, it was SAE for some odd reason. Use a flare nut type wrench to prevent stripping.
Add to kmix99's Reputation
Rate the quality of this post and help kmix99 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kmix99 is offline   Reply With Quote
Old 05-19-2005, 09:32 PM   #9
sierrap615
sierrap615's Avatar
whats really amazing is not that i whent thru the pulley, but i even did it with the beefyer flare wrench(it was about 1/8 taller then my standard box wrench). it also helps i have the hood, wiring harness, belt, and a million other things already removed. it would not go straght on thru the slot in the pulley. i instead got the wrench head in with the pulley at a different angle, then turned the pulley till it lined up with the nut. the pump was also unbolted from the engine at the time.
Old 05-23-2005, 10:29 AM   #10
geartooth94
well i found an old crescent wrench from my grandfather's garage that looks like it will fit on the steering gear lines. Also bought a 16/18mm flare nut wrench so we'll se how it goes when I try to remove the lines. PB Blaster is my friend!
Power Steering Fluid sl1driver S-Series General 10 07-13-2009 08:47 PM
Use brake fluid for power steering fluid???? JerryHughes S-Series General 4 02-27-2009 07:14 PM
Power steering fluid Jerry_Strn S-Series Tech 2 01-03-2009 11:45 PM
Power Steering fluid in Brake Fluid southlex Outlook General 4 07-07-2008 02:03 PM
Power Steering Fluid the_new_raceman S-Series Tech 0 04-10-2005 06:52 PM
