Old 12-30-2019, 11:49 AM   #1
Cavell
2003 VUE 3.0L
Default strut mount noise?
front end is making noise on washboard type ruts. i had previous vue where i changed struts but not top mounts and noise remained. changed mounts and noise was gone. got different vue and it has new struts. same noise. end links and bushings are good. i took out strut and see spring is new and i think mount is new. so, new strut assy's installed? hate to chase my tail here. i put strut back in. not a hard job but it is a pain if i accomplished nothing. should i get new mounts to try and fix issue?
Add to Cavell's Reputation
Rate the quality of this post and help Cavell reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 01-14-2020, 02:07 PM   #2
jco35
jco35 is on a distinguished road
2005 VUE Red Line
Default Re: strut mount noise?
I would. I replaced my original mounts at 80k with new Delco's when i replaced my shocks and struts. I'm kicking myself for not re-using them. The 'new" mounts started make noise after a month. Now i have to redo the job and replace the mounts. Hope the new set last longer.
Add to jco35's Reputation
Rate the quality of this post and help jco35 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jco35 is offline   Reply With Quote
Old 01-15-2020, 04:42 PM   #3
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2007 VUE 3.5L
2005 ION-3 Sedan
this is the stuff of nightmares for me. you'd expect the Delco's to be flawless. is there any chance they were counterfeit?
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Strut/Strut Mount Problems dougalldc3000 S-Series Tech 3 09-21-2014 02:34 PM
strut and strut mount advice needed mudawg Vue Tech 20 12-07-2010 10:30 PM
Strut/strut mount/spring removal AJT_Leo S-Series Tech 9 05-24-2010 02:17 PM
Dealer replaced strut, strut mount, and strut bearing tomcatt1 Vue General 17 10-03-2007 04:53 PM
Strut mount bearing noise=danger? BigShelby S-Series Tech 1 04-18-2005 09:54 PM
