Old 11-10-2019, 12:39 PM   #1
sc2dave
sc2dave is on a distinguished road
sc2dave's Avatar
Default Need screw in fitting for water heater hose, dr. side
'96 sc2. I need the heater hose fitting that goes on the intake manifold on the driver side, Anyone have a listing for it on Ebay or Amazon, maybe auto parts store? thanks.
www.bold-fortune.com
Add to sc2dave's Reputation
Rate the quality of this post and help sc2dave reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sc2dave is offline   Reply With Quote
Old 11-10-2019, 02:01 PM   #2
billr
Default Re: Need screw in fitting for water heater hose, dr. side
Got it out, can you post a picture? I'm guessing it is NPT and you can get a suitable one from even Lowes or Home Depot. At your FLAPS, Dorman is a common brand, look on the Dorman web-site for a match.
Add to billr's Reputation
Old 11-10-2019, 02:21 PM   #3
Waiex191
Waiex191's Avatar
Seems like an odd part to fail, which may make it hard to find. It is probably a pipe thread. If you can measure the old one, would be easier to find a replacement. Or grab one from a junkyard. Will probably be free.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 11-10-2019, 03:26 PM   #4
sc2dave
sc2dave's Avatar
Originally Posted by billr View Post
Got it out, can you post a picture? .
Ihaven't put a wrench to it, but I'm thinking that it might break off in the manifold. The part that connects to the hose just broke off with finger pressure.
Old 11-30-2019, 05:25 PM   #5
sc2dave
sc2dave's Avatar
anyone have a picture of this?
Old 11-30-2019, 07:16 PM   #6
Is this the intake manifold with heater outlet? If yes, there are threads about it. One video, https://www.youtube.com/watch?v=jtiv4FTcPg4, shows a repair. Other videos are available. Dorman part, https://www.amazon.com/Dorman-902-10...12713976&psc=1.
Old 12-01-2019, 12:03 AM   #7
That's for the craptastic 3rd gen plastic intake manifold. The aluminum intake manifolds have a screw in fitting "hose barb" that threads into the IM while providing a nipple for the coolant hose to slip onto.
I've no idea what the thread is, but I'd hazard a guess that the hose is 5/8" so you'd need a 5/8" barb and try a couple different 5/8" thread styles to see what fits in the intake. Pipe thread tends to be a narrow measure for a given size while straight/compression thread tends to be normal/wide measure.
Old 12-01-2019, 01:00 AM   #8
sc2dave
sc2dave's Avatar
I need one for an aluminum I/M, not plastic.
Old 12-01-2019, 07:43 AM   #9
454cid
Originally Posted by fetchitfido View Post
...Pipe thread tends to be a narrow measure for a given size while straight/compression thread tends to be normal/wide measure.
Pipe sizes are inside diameter. I'd guess it would be 1/2 pipe thread, for a 5/8" hose barb, which seems a bit big for a little 1.9L engine, to me. 1/2" thread is what the V8's use for both the 5/8" and 3/4" lines.
1999 Chevy K3500
Add to 454cid's Reputation
Old 12-04-2019, 11:23 PM   #10
TomM96
SC2Dave-
Following 454cid suggestion, if hose diam=5/8 buy two npt hose barb nipples, one with 1/2" npt thread, maybe a second with 3/8" npt nipple.
Then go undercar with wrenches and try to get the old nipple to unscrew.
There's a good chance the hex/thread portion is intact... but you need find out.
If it breaks apart, can maybe remove with a screw thread extractor, or even use various screwdrivers to jam/turn. Worst case, use hacksaw blade & punch/chisel to break apart the threaded sidewall, then prise out fragments....
Clean threads in head of debris(as with tiny wirebrush), thread in the new nipple to check fit....remove , coat threads with Pipe Sealing Compound
install nipple, tighten just more than by hand with wrench, Remove & Repeat to insure the Pipe sealant is on entire threaded bore in head, tighten firmly.
The hosebarb/nipple needs be galvanized steel/iron Not plastic or bronze or brass. Actually Aluminum might be available, and might work... but i'd stick with the original zinc/galvanized steel/iron.
Add to TomM96's Reputation
Old 12-05-2019, 09:25 AM   #11
454cid
What is your argument against brass? I've got two brass fittings on my truck.
1999 Chevy K3500
PCV breather hose fitting Claybury S-Series Tech 0 11-01-2016 03:35 PM
3.5L tee fitting for coolant hose RobertGary1 Vue Tech 0 01-13-2016 02:34 PM
'97 SC2 heater hose removal for heater core flush SC2by2 S-Series General 3 10-24-2015 07:03 PM
Cracked fitting-end of overflow hose SL2Many S-Series Tech 4 05-17-2011 09:43 PM
brass fitting near oil cap on valve cover, where does hose go? mikes 1994 z28 S-Series General 1 08-05-2006 02:06 PM
