Old 11-11-2019, 01:24 PM   #1
dummo
dummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of lightdummo is a glorious beacon of light
dummo's Avatar
Default Blowout!!!
I went to get my jack out of my SW2 for use as an aid in repairing my mother in-law's outside staircase and noticed that my never used Space-Saver Spare had exploded at some time in the last year-ish. Exposed steel wires and ripped open tread. This is a moderately rusty rim as the wheel well does get moist inside and I found it with about a half inch of water in it when I first purchased the car. I am open for suggestions as to the best and easiest way to replace the thing.
Q: Does a full size spare fit in the well? (If it does then why did they put in a space-saver spare? money???)
Thanks in advance for all the good advice.
• 1997 SW2 used 12/29/2011 with 124,200 -27 mpg
• 2004 Ion3 new 11/2003 (totaled) 11/2011 -23 mpg
• 1994 SL1 new traded
• 1992 SL2 new traded for above
Add to dummo's Reputation
Old 11-11-2019, 01:43 PM   #2
onlinebiker
Default Re: Blowout!!!
Stop by.
I have a few.
Btw - is the exhaust heat shield in front or the side of the well intact?
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 11-11-2019, 02:10 PM   #3
454cid
Weird, mine was burst too.... it was also very well used, so I assumed it happened during use. I never asked my brother-in-law about it.
I pulled a 14" fullsize wheel from a salvage yard car and it almost fits flat.... close enough for me. I don't have the carpet or board in the truck anymore, Though.
1999 Chevy K3500
Add to 454cid's Reputation
Old 11-11-2019, 02:28 PM   #4
Both my Saturns blew their spare in the trunk. Both got new tires. See this thread:
http://www.saturnfans.com/forums/showthread.php?t=60735
On the last page I posted this link:
https://m.tirerack.com/tires/tires.j...170924131058:s
Any junkyard or onlinebiker tire is likely to be past its freshness date.
Add to Waiex191's Reputation
Old 11-11-2019, 03:30 PM   #5
Here is one of my blowouts.
Old 11-11-2019, 03:41 PM   #6
454cid
Oh wow! That's bad!
1999 Chevy K3500
Old 11-11-2019, 11:15 PM   #7
dummo
dummo's Avatar
Okay, since the compact spare should only be put on the back anyway and I have little drum brakes on the rear, I am going to see if I can find a 13 or 14 in thin steel rim and put a sorta tall thin (ordinary) tire on it and see if I can come up with a wheel/tire combination that fits in the well. Back in the day (late 1970’s) the common tire sizes were thin tall sneakers the likes of 155/78R-13. I think VW beetles were running 155/78R-15 which is a tall skinny setup which I haven’t seen recently until I saw BMW’s contemporary electric compact car.
Thought: Maybe there is a dressing like Armor All that retards the deterioration of the ‘rubber’ and keeps your compact spare from drying out. ...and a time machine to go back and apply it.
Thought: the Ion’s Compact spare should also fit so that means a wider window of opportunity for finding an unused used one..
Old 11-12-2019, 02:14 AM   #8
A 175/70R14 fits about perfect in place of the temp spare. Dropping to 65 from 70 would probably let it fit perfect; either one would last longer in-use then the temp spare.
I believe with the right offset (and inner wheel shape) even 13" wheels fit over the front calipers, some auto-x guys would run those tiny wheels & tires for better acceleration and less weight IIRC.
Old 11-12-2019, 04:40 AM   #9
Zeebins
Zeebins's Avatar
There are 13 inch wheels out there that fit, not sure which ones though. Would having 1 wheel be 2 inches smaller than the rest be safe? I've driven on the spare a few times and that already feels kinda weird.
97 SL2, auto, 117K miles
Powered by Plastic
Add to Zeebins's Reputation
Old 11-12-2019, 03:32 PM   #10
dummo
dummo's Avatar
a smaller wheel with a taller thinner tire is just a possible cheap and readily available from the store shelf option once I figure out what's possible. It is still just for temporary use and on the rear axle only where it won't put unnecessary strain on the transaxle and for safety and handling reasons - the outer circumference is the critical measurement so a tire as close in height to the other 3 is desired. Wrapping a tape measure around the tire will give you a good and pretty accurate measure of the circumference and this measure does vary greatly between tires of the same size from different manufacturers. (I know this first hand after putting two new tires on my wife's Pacifica and had to buy two more right away or mess up the 4WD system)
I remember that my 1979 Honda civic sported 12 inch rims. (155/75R-12's I believe)
Old 11-13-2019, 10:40 AM   #11
nealt
nealt is on a distinguished road
nealt's Avatar
1997 SC2
1999 SC2
My kid just got a flat in his '99 sc2 tire, and we just found out that the spare must have blown up over the summer.
I like the idea of using a 175/65r14 tire. Will that fit on the compact spare rim, or will I need to get another rim?
Add to nealt's Reputation
Rate the quality of this post and help nealt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nealt is offline   Reply With Quote
Old 11-13-2019, 12:04 PM   #12
dummo
dummo's Avatar
My plan is to go to a Town Fair Tire and find an ordinary but smaller size 14in tire that fits in the well first and then see if it fits on my skinny 'donut' rim.
That's step 1 of my plan.
Old 11-13-2019, 01:26 PM   #13
I've changed both my tires by hand using motorcycle tools. Those space saver rims are pretty narrow. Not sure a real tire would work. I'd probably go with an SL 14" rim instead.
With that said, I'm happy to have new space saver tires in the trunk. If I ever rebuild the coupe, I might cut out the tire well and weld in one from a Buick Century.
Old 11-14-2019, 12:13 AM   #14
A2Saturn
A2Saturn is on a distinguished road
A2Saturn's Avatar
1994 SL1
I tried fitting a 175/70/14 tire with about 2/32 tread left in the wheel well, but it really didn't fit. I've replaced the compact spare tire once, and I'll go with the Tire Rack option that Waiex went with next time around. I've only had 1 flat in 26+ years owning my car, so getting another flat is not a real worry of mine. Try using 303 protectant on your tires to help them last longer.
Add to A2Saturn's Reputation
Rate the quality of this post and help A2Saturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
A2Saturn is offline   Reply With Quote
Old 11-14-2019, 12:22 AM   #15
Zeebins
Zeebins's Avatar
As far as I know, my space had been used 3 times by me and twice by my father in the last 19 years. I wonder how much life it has left in it, lol.
Powered by Plastic
Old 01-08-2020, 11:09 PM   #16
dummo
dummo's Avatar
Epilogue:
Being the cheapskate that I am, I have been scanning craigslist, ebay and Letgo all this time. Finally found a solution in my price range/comfort zone. The tire is slightly smaller and the seller couldn’t tell me the donor car’s make, model or age but I went for it. I just picked the donut up tonight on my way home from work and as a so-far-so-good bonus the lug hole distance matches my SW2. If the rim somehow doesn’t fit I will have to pay to have the tire mounted to my factory rim. I did buy a can of Super Tech Fix-a-Flat and a fresh tire plugging kit a few weeks ago as an emergency backup.
Craigslist ad....
Most other options I could find were up in the $50.00 and up range or just geographically too far to make sense.
Old 01-09-2020, 12:15 AM   #17
focusofheart
Are spare tires "blowing up" mainly a cold weather state problem? I have never experienced that problem myself.
Saturn 1998 - SL2 automatic
Old 01-09-2020, 08:31 AM   #18
I thought it was mainly a heat and age problem. That is why I didn't go with a cheap used donut.
Old 01-09-2020, 08:36 AM   #19
onlinebiker
We have not experienced a spare blowout on any of our vehicles - but have bought a few that were already blown. I noted the blowouts were always on the front facing section of tire - leading me to believe it is exhaust pipe heat related.
92 SC2
93 SC2
96 SC2
97 SL2
97 SC2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 01-09-2020, 09:11 AM   #20
Hey Dummo!
Thanks for the LETGO.com option. Had never heard of it and yet I see it is very active in my area.
RT43 Blowout? Tiger S-Series General 5 02-17-2015 10:41 AM
Tire Blowout@80mph aidan80 S-Series Tech 4 11-18-2009 11:07 AM
Radiator hose blowout... help!!! bskicrash1 S-Series General 3 08-10-2006 12:13 AM
Ps2 Blowout Sell getz999 Classifieds 2 03-19-2006 11:44 PM
PC Blowout Sale!!! getz999 Classifieds 14 08-17-2005 01:56 AM
