Old 10-28-2019, 09:09 PM   #1
dummo
dummo's Avatar
1997 SW2
Default Jacking Up Hockey Puck
I’ve seen a lot of Jacking Up Hockey Pucks on Amazon after watching a YouTube mechanic say that he uses a hockey puck with a groove cut into it to give a steady cushion when jacking up cars at the manufacturer’s recommended jacking point. It supposedly/ideally avoids the weld seam from collapsing to one side From the weight which seems to be a true possibility. I am getting ready to cut a groove in my 1994 Rangers Stanley Cup commemorative Hockey Puck and drilling out some divets in the other side to sit nicely into the head of my floor jack. I also just bought a pretty substantial $12.00 rubber floor mat to sit under the jack and jack stands (after cutting into sections) to add some more stability and grip on the surface of my driveway. I have tried pieces of scrap wood only, but the splitting sounds becomes unnerving while jacking the car up. I think a combination of wood and the rubber mat will hopefully offer a nice secure solution. There are even custom rubber Jack Stand head pieces on Amazon but I will try another small chunk of my floor mat first. I’ve even considered trying pieces of carpet.
Any thoughts or experiences to share?
Also: Is there a secure and safe center point on or near the rear axle for jacking up the entire rear of our S-Series Cars?
• 1994 SL1 new traded
Old 10-28-2019, 10:39 PM   #2
Zeebins
Zeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to beholdZeebins is a splendid one to behold
Zeebins's Avatar
Default Re: Jacking Up Hockey Puck
For the front, What I normally do is jack up the car along the frame where the subframe bolts on to, leaving enough room to next to it to put the jack stand. The rear can be jacked up from the rear subframe. There's a bump in the middle that I always use.
I can't even really use my "recommended" jacking points in the front anymore due to it being so bent. The back seem to be fine though
97 SL2, auto, 121K miles
Old 10-29-2019, 01:43 AM   #3
From the rear I either use the center of the rear subframe or where the trailing arm mounts. From the front I use where the cradle mounts. Pretty sure none of them are "factory authorized" but if they buckle under the weight of the car...it wasn't safe keeping the car anyway.
Old 10-29-2019, 08:00 AM   #4
onlinebiker
I have a straddle gantry I built - using S series rear wheel bearings and 4 spoke (93) aluminum rims.
I use it to lift Saturns by the roof - using a chain through the front windows.
It's a bit hard on the finish.
Then I load the stripped out carcass onto a trailer and take it up the street to the scrap metal dealer..
A stripped out 94 SC2 frame weighs 515 lbs and brought $33.
Now you know.
Currently owned
93 SC2
96 SC2
97 SL2
98 SL2
99 SC2
01 SC2 x 2 yellow
02 SC2
02 SL2
parts
2 94 SC2 parted out
2 96 SC2
Old 10-29-2019, 09:12 AM   #5
trottida
trottida's Avatar
I've used the slotted hockey puck on the pinch welds and flip it over to lift the back by the center of the rear subframe. I find it kind of finicky to get it positioned on the pinch welds and upgraded to this magnetic version. It works well and I still use the hockey puck for the rear subframe which lifts both wheels off in one lift.
Universal Aluminum Grooved Magnetic Jack Pad
2012 Ford Focus SEL HB MT
2011 Suburban LT
Past Saturns
2001 SL1 MT (438,500 km 11y)
1993 SW2 AT (10y)
2001 LW200 MT (3.5y)
1992 SL2 MT (5y)
:canada:
Old 10-29-2019, 12:37 PM   #6
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Wrench Re: Jacking Up Hockey Puck
I bought a cheap Chinese version and cut a groove into the back to fit flat on my cheap-assed floor jack... it ended up splitting in two. An actual hockey puck would've done the trick, but Trottida's magnetic jack pad looks much better.
I've already ended up crushing most of the pinch welds on the front anyhow, but sliding a jack under the SL when you've already put H&R Sport Springs all around just makes it a wee bit more challenging.
Goggles Pisano is offline   Reply With Quote
Old 10-29-2019, 01:21 PM   #7
trottida
trottida's Avatar
Just straighten out the pinch weld with some vice grips and you'll be good to go again.
2011 Suburban LT
Past Saturns
1993 SW2 AT (10y)
1992 SL2 MT (5y)
:canada:
Old 11-03-2019, 11:25 AM   #8
lilwhitetruck
lilwhitetruck is a jewel in the roughlilwhitetruck is a jewel in the roughlilwhitetruck is a jewel in the rough
Don't be so fast to cut that one up! Hopefully we'll have another puck this year!!!! In the mean time grab a puck from that "Other" team and cut that up. . .
2001 Saturn Silver SC2 Leather Interior with 297K and a newly acquired 2002 White Fully Loaded, With only 87K! My new DD!!!
lilwhitetruck is offline   Reply With Quote
Old 11-09-2019, 09:36 AM   #9
dummo
dummo's Avatar
1997 SW2
Here’s an interesting idea...
https://youtu.be/jp2DqnL3A1g
ACT street vs 4-puck vs 6-puck dragon370 S-Series Mods 27 01-29-2007 02:09 PM
New Clutch for the Yellow SC2 - ACT 6 puck Krid80 Mods and Performance 5 10-10-2005 09:21 AM
