Old 07-13-2019, 04:35 PM   #1
machinn
machinn has a spectacular aura aboutmachinn has a spectacular aura aboutmachinn has a spectacular aura about
Attention Not Able to Initiate TPMS Relearn
Hello Astra owners!
I installed new front tires on my 2008 Saturn Astra XE and moved the front tires to the back. Now, I am trying to reset the TPMS light (flashes for 1 minute and then go solid), but canít manage to get it in relearn mode with the remote ON and OFF pressed at the same time with the key turned to ON (not running) and the parking brake on - no matter how long. I tried many times without success. Any Astra owner had this issue and what was the fix? Thanks!
Add to machinn's Reputation
Rate the quality of this post and help machinn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
machinn is offline   Reply With Quote
Old 07-15-2019, 08:28 AM   #2
maschinenbauer
maschinenbauer will become famous soon enough
maschinenbauer's Avatar
2008 Astra XE
Default Re: Not Able to Initiate TPMS Relearn
Did you replace the sensors or transfer the old ones from the old tires? If they are still original sensors, they are probably out of battery. Mine will periodically do that, maybe a couple times a week, because the batteries are dying. All of our Astras are 10 years old, so the batteries and/or sensors probably need replacing.
'08 Astra XE 5-speed
'72 Chevrolet El Camino
'31 Ford Model A pickup
Add to maschinenbauer's Reputation
Rate the quality of this post and help maschinenbauer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 07-15-2019, 06:22 PM   #3
machinn
Thank you for your post! I thought of that, but because the tpms light was not on before I replaced the tires I thought the sensors needed to be reset. Maybe I will try to replace all 4 of them if not crazy expensive. Nonetheless, I guess the initial concern still remains: why canít the tpms relearn mode be activated? Any help with this would be greatly appreciated.
Old 07-16-2019, 07:50 PM   #4
imaddicted2u
imaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really niceimaddicted2u is just really nice
imaddicted2u's Avatar
2008 AURA XE
I think your answer is here...
http://www.saturnfans.com/forums/sho...highlight=tpms
Old 07-16-2019, 08:56 PM   #5
velocast
velocast has a spectacular aura aboutvelocast has a spectacular aura aboutvelocast has a spectacular aura about
Our Astras are 10 years plus old. I am getting old too!
So, you may need a set of new ones:
I suggest you:
DORMAN 974030
No programming tool needed
Self learning
Will fit in most aftermerket wheels
Nice two-piece design
The valve stems are independent from the sensors
Trouble free
Add to velocast's Reputation
Rate the quality of this post and help velocast reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
velocast is offline   Reply With Quote
Old 07-16-2019, 10:22 PM   #6
machinn
Thank you all for your help! I will go ahead and search online for the doorman sensor set.
Old 07-17-2019, 01:14 AM   #7
nicolas_p
nicolas_p's Avatar
2009 Astra XR
2008 Astra XE
Also something that no one mentioned is that the Canadian/US model of the astra don't have the capability to learn the TPMS. The system can't display each tire individually, to "re-learn" the sensors you just need to drive for a little bit and the car will automatically learn them. I believe it is something like 5 minutes above 50km/h or 20mph
09 Vauxhall Astra XR3/STD
18" Team Dynamic MonzaR rims
Add to nicolas_p's Reputation
Old 07-17-2019, 01:27 AM   #8
imaddicted2u
2008 AURA XE
Not a bad price...check the reviews.
https://www.amazon.com/Dorman-974-03.../dp/B0049EDXUC
Key FOB doesn't work on TPMS relearn. mark4Jesus Aura General 22 07-16-2019 10:27 PM
new ecm relearn Welderdude L-Series Tech 4 03-22-2014 12:45 PM
3.0 tps relearn vanish72 Vue General 2 01-21-2014 11:43 PM
ECM relearn help please fast5thgen Vue Tech 5 11-20-2010 10:08 AM
Passlock relearn... (optional relearn) austin71184 S-Series Tech 2 05-31-2006 05:51 AM
