#5941 | |
http://www.saturnfans.com/forums/sho...d.php?t=237152 Just make sure to use something to lube the cylinders after the B12. That stuff has no film strength at all. Since I used the B12 first, I can't say how much better or worse than MMO it might be for loosening up carbon, but it did a good job. ![]()
Alordofchaos is worthy and hides in shadows only to hone his S Series knowledge ninja skills. Swift, silent, trustworthy. |
#5942 | |
![]() ![]() ![]() Join Date: May 2019
If I use MMO, it'll have a little 2-stroke oil in it.... I'll use my mixing syringe ![]()
2000 SL2 Automatic 200,XXX miles. 1999 Chevy K3500 |
#5943 |
B12 has a good reputation as a ring cleaner as long as the condition has not reached the terminal stage where the cylinder and rings have worn out of spec. It is about all there is for a DIY quick fix that is readily available.
#5944 | |
I did that followed by compressed air vacuum rig before cranking mine over after the soak, and got very minimal smoke show. It actually started as quick as usual with just a puff of smoke, then a bit more as it came up to temp. With a syringe you could get a lot of carbon off the tops of the pistons before cranking, and the MMO worked great for that. I used a squeeze bottle (think cafe ketchup squirter) so the vacuum to pull stuff out was limited. Had I used a syringe I think I could have gotten a better flush from all the stuff on top of the pistons.
#5945 |
![]() ![]() ![]() ![]() Join Date: Aug 2016
In "Geniune GM Parts" fashion, I got a damn "Service Engine Soon" light on my way to work.
Time to scan it and find out which "Pride of Delphi" electrical component is malfunctioned.......... Ironically, the car is running and driving perfectly fine.....code will probably scan as "No Apparent Reason"......
"What does a Saturn owner do, at the gas station?" "He checks the gas, and fills the oil....." |
#5946 |
![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2005
1997 SL1
Friday had a new muffler and strap installed. Saturday had to install a water pump.
1995 SL1 236,300 2005>2018 1997 SL1 75,200 2014>???? ![]() CHECK YOUR OIL!! ![]() |
#5947 | |
![]() http://www.saturnfans.com/forums/sho...d.php?t=156881 The leaks are often related to the sunroof drains (one in each corner) being either disconnected or clogged. See trottida's post/diagram here http://www.saturnfans.com/forums/sho...d.php?t=222895
I'm not worthy to grovel in the shadow of Signmaster's wisdom 11/2016 red 2002 5 spd SC2 151k DD 12/2008 eBay silver 1998 SL2 5 spd 102k, now 201k+ miles |
#5948 |
![]() Join Date: Nov 2010
1994 SL1
Had the garage replace my belt tensioner, idler pulley, and belt. This repair eliminated the unpleasant whirring sound from under the hood.
#5949 |
Finally got the new valve cover gasket on. I discovered a small crack the other day, and wondered how it happened. I think I figured it out today. The passenger side motor mount
interferes with the valve cover. I didn't try to move the motor mount. One of those bolt holes in the timing cover is already stripped and held in place with Loctite. The crack doesn't look to go all the way through the plastic, so I don't think it will be a problem. The Felpro gasket looks like it should seal pretty well. The old one leaked oil into the plug wells. It looks like the timing cover was pulled, and the "mechanic" goobered up the original valve cover gasket with something like RTV. The old gasket was hard, and cracked or at least the center section came out in two pieces. I'm also soaking my oil soaked truck carpet in the pan of degreaser I soaked the valve cover... it was really too weak for the valve covers baked on oil, but it might work on the carpet. I was going to toss it, but other than the dirty motor oil, it looked to be in great shape.
#5950 | |
#5951 | |
#5952 |
![]() ![]() ![]() Join Date: Apr 2008
Driver's side Wheel Bearing, Race & Hub replaced.
Race was LOCKED IN - Presses couldn't get it out. Finally used a Dremel to release pressure. All good AND no more pulling to the right! ![]() ![]()
Proud Owner of an Invincible '98 SC2 Rare "Red Hot" 5-Speed. Castrol Edge EP + M1 Ext Perf. Oil Filter. Owned 4 other S-Series. |
#5953 |
![]() ![]() ![]() ![]() Join Date: Jun 2019
Bolted on a power release trunk latch. I can now open my truck with my key fob
![]() It really is the little things that entertain me...
98 SL2, 70k miles, kept in the family since new! Her name is Uranus :) |
#5954 |
Got the new plugs and wires in.... still messing with the routing. I've got the plastic cover without the wire grooves. I've got a 3 and a 4 wire retainer. I couldn't figure out how they used to be routed, but I just looked at a picture I took. I think the new wires are longer.
The car runs, but still smokes. I still need to change the oil. It's old oil full of B12 Chemtool. I checked the gap on the plugs, all but one were right on. I torqued the to 20lbs with my beam torque wrench with anti-seize on them. It was tighter than I probably would have gone by hand, but I wanted to use a torque wrench because of the aluminum. Now I can finally move this thing around again!
#5955 | ||
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2005
1999 SL2 MT (287,130 km @ 10/2019) 2012 Ford Focus SEL HB MT 2011 Suburban LT Past Saturns 2001 SL1 MT (438,500 km 11y) 1993 SW2 AT (10y) 2001 LW200 MT (3.5y) 1992 SL2 MT (5y) :canada: Last edited by trottida; 06-19-2019 at 11:18 AM. |
#5956 |
Yeah, I probably should have gone lower than spec because of the anti-seize.
#5957 |
I began the process of wrapping my car today. I will have the car wrapped over the course of 3 visits due to my daily time constraints.
The shop receipt shows they used Oracal Premium 3.5 mil Cast Vinyl - 286 Bottle Green. So far I am very happy with how the surface has turned out. shop link: https://updog.com/ This morning at 9am: ![]() Completed: ![]() ![]() ![]() These images were taken with an old flip phone so they lack sharpness. The images are also linked to the Photo Gallery where a larger image is available. |
#5958 | |
The shop ended up using 677 Fir Tree Green Metallic for the color wrap. |
#5959 |
New valve cover day
97 SL2, auto, 123K miles |
#5960 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2016
Bryan Cotton '99 SL2, 5SP bought new Rebuilt at 204,067 September 2017 Engine, subframe, diff pin mod, brake lines, headliner, alternator, and so on! '98 SC2, 5SP bought 2018 |
Anyone see the "Judge Judy" episode with the 96 S series today? | dave.sl | S-Series General | 23 | 02-20-2014 04:56 AM |
The S Series would be a great car for the lineup today | VTHokie00SL2 | S-Series General | 46 | 10-01-2012 08:26 AM |
Got the L series recall letter today for rear lights | Garciavision | L-Series General | 27 | 12-22-2005 02:29 PM |
REDLINE Series Announced Today | D C | Vue Red Line | 6 | 04-10-2003 08:14 PM |
Saw the L series DVD system today | Jeff P | L-Series General | 1 | 11-09-2001 09:03 PM |
