Old 05-25-2019, 05:43 PM   #1
vikasevan
vikasevan has a spectacular aura aboutvikasevan has a spectacular aura about
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
Default 2001 Saturn SL2 - replaced the starter it tried to start on its own without key
2001 Saturn SL2
After I replaced starter...(bought from Amazon - https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1)
when I connected the negative cable again after putting all wires ...it tried to start on its own ..when it was trying to start ..I turn on the key and car ran ..I moved a little and turn off ...next time I tried to start it would not start...
Did put the wires wrong....two wires one from battery and one from alternator goes to 13mm bolt on solenoid and purple wire - 10 mm goes to solenoid too..I dont think I made any mistake....
May be wire touching solenoid could cause this?
Did I burn the starter? Because there is no relay or fuse for starter...it would not protect the starter correct?
vikasevan is offline   Reply With Quote
Old 05-25-2019, 08:55 PM   #2
Default Re: 2001 Saturn SL2 - replaced the starter it tried to start on its own without key
You could post a picture of the wires attached to the starter, but it sounds like you have them correct. Take off the PPL wire and see if it still "auto-cranks".
I gotta ask... what were the symptoms that caused you to change the starter?
Also, I think there may be a relay for the PPL wire circuit; if so, pull that out as it may be stuck (welded) closed.
Old 05-25-2019, 10:23 PM   #3
vikasevan
vikasevan's Avatar
2001 SL2
2004 VUE 3.5L
It was intermittent no stat and had to bump solenoid ..and it would start...I have the wires correct...I removed and checked again...is there any relay for starter?
if not where is the relay for purple wire..I believe purple wire is ignition switch? if so fuse ?
when I try to start ...light on radio and odometer goes dim for second but no crank any more..did I damage the starter?
Old 05-26-2019, 12:09 AM   #4
The starter assembly itself is probably OK. The symptoms you describe, symptoms of the old starter as well as the changing symptoms of this new one, strongly suggest that there is a relay and it is bad. Do you know where the instrument-panel junction block (IPJB) is? It will be to the left of the front passenger, behind a small panel that is below and to the right of the radio. Look in there for a relay. Replace it with a similar one from any other spot on the panel or the UHJB (under-hood junction block). That is a quick and no-cost test to see if this is any easy fix. If you get no joy with that, then we will have you break out your voltmeter and begin tracking this down step-by-step
Old 05-26-2019, 12:32 AM   #5
ssicarman
ssicarman's Avatar
Wiring diagram for the starter purple wire/solenoid signal wire is.
Battery power to under hood fuse block to the ignition switch ---- for the manual trans to the clutch switch to the under hood fuse block to the starter --- for the auto under hood fuse block to the trans range switch to the starter switch.
No relay shown in the schematics.
Old 05-26-2019, 12:40 AM   #6
My schematics only go up to '98, and show the relay for '97-'98; it looks to be part of the RKE circus. I figured it was probably continued into the later years, but honestly don't know...
2001 Intermittent turn key to start and no starter sound at all BobbyBeans S-Series Tech 2 12-30-2014 05:20 PM
99' Saturn SL1, turn key start and nothing...already replaced starter KristinC121 S-Series Tech 13 09-22-2014 10:47 PM
Replaced dead battery in my 2001 Saturn SC1 and now it turns over but won't start? LeisaD S-Series Tech 15 08-03-2014 09:03 PM
9 saturn sl2 short somewere ..replaced starter.... paperplanes S-Series General 17 11-07-2009 07:55 PM
Replaced Starter, Now won't Start RicSC2 S-Series Tech 25 12-27-2006 10:06 AM
