Old 03-25-2019, 05:08 PM   #1
JosephN79
JosephN79 is on a distinguished road
JosephN79's Avatar
2004 VUE Red Line
Default High Beams Stay On
I took my Saturn out today, itís been sitting a few weeks.
I come home and notice after a half hour the high beams are still on. They stay on regardless of if ignition is off or on, if I pull the parking brake. If I turn lights off and on they do so, as well as turn signals. The high beams never go off.
I read that it could be the ďclickerĒ or stalk needs replaced. I already have it out, it would be super easy to replace.
The article I read was on an SL1, and never got any closure from the OP of a new switch worked, or any resolution for that matter.
Also, pulled the DRL relay and that didnít turn them off, just a stab.
Thanks for any help!
Add to JosephN79's Reputation
Rate the quality of this post and help JosephN79 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JosephN79 is offline   Reply With Quote
Old 03-25-2019, 05:16 PM   #2
JosephN79
JosephN79's Avatar
2004 VUE Red Line
Default Re: High Beams Stay On
Soooo, anyway.
I disconnected the battery and the lights went off. I figured Iíll put it pack on real fast and see if they come back on. They didnít come back on. I hooked everything back up and everything works as it should.
Iím a little gun shy after owning this guy for the past 6 years, so Iím still guarded. Lol. Could my switch be going bad?
Old 03-26-2019, 10:12 AM   #3
far2grumpy
far2grumpy's Avatar
One side of headlamps are "hard-wired" to battery (thru fuses).
Possible causes of high beams staying on:
1. Ground side wire of lighting circuit intermittently shorted to ground or one of following keeping ground applied.
2. Sticky HEAD LAMP Relay (part of auto headlight system - I/P fuse block).
3. Lighting stalk problem - either high-beam activation or flash-to-pass.
4. Internal BCM problem.
Old 03-26-2019, 07:31 PM   #4
JosephN79
JosephN79's Avatar
2004 VUE Red Line
Hmmm.. itís all good still since I disconnected/reconnected the battery cable. Hopefully just one of those things and I wonít have to deal with it til later. 👀
2006 Saturn Ion 2 - High Beams Work, Low Beams Do Not. spacer7767 Ion General 4 10-31-2018 07:44 AM
High Beams will not stay on after clicked bachands S-Series General 9 07-30-2015 05:29 AM
High Beams indicator flickering, cutting DRLs, but no high beams andymcconnell L-Series Tech 6 10-04-2012 10:14 PM
Low beams stay on Smokeater S-Series Tech 3 12-16-2011 12:04 PM
Fog lights to stay on when high beams are on Dave19yz S-Series Tech 12 12-26-2007 06:46 PM
