Old 11-09-2017, 08:57 PM   #1
Keeter
Keeter is on a distinguished road
Keeter's Avatar
1999 SL1
Default '95 SC1 runnning issue-Asking for a friend
I'm kinda the middle man in this situation.
Brother in law to wife to me. I took a screen shot of the convo. I haven't looked at it, and am not familiar with the TBI setups as my SL1 has a swapped '98 DOHC in it.
Was thinking fuel filter. '95's i assume have one somewhere. The fact it doesn;t happen all the time tells me fuel, or ignition.
Being it's my wife's half brother's mom's car I'm not putting too much concern into it as I haven't seen his mom in 10 years.
Mostly told him post up a question on here himself, but he's too proud to ask for help.
Any way, If I get even one response that would be enough for me.
That's my opinion,
Keeter
Add to Keeter's Reputation
Rate the quality of this post and help Keeter reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Keeter is offline   Reply With Quote
Old 11-09-2017, 10:06 PM   #2
Default Re: '95 SC1 runnning issue-Asking for a friend
Well, mileage on the car?
Plugs n wires, what maintenance has been done recently if any?
TBI need cleaning, run some techtron (sp) cleaner through it?
Running bad? We would need more specific info to assist in this.
Old 11-09-2017, 10:10 PM   #3
Okay, my response is that we would need better info to be of any real help. "Runs like ****" is just going net a lot of guessing.
Add to billr's Reputation
Old 11-10-2017, 02:01 PM   #4
I'll add to guesses; what's fuel pressure, does the TBI leak when looking down into it with ignition turned on (engine off), was the two wire coolant sensor ever replaced from the faulty round nosed plastic one to the flat nosed brass one, t-stat replaced, fuel filter replaced?
Old 11-10-2017, 04:03 PM   #5
Jonasan308
Jonasan308's Avatar
1999 SC1
"Too proud to ask for help" but he's already asking for your assistance with it. Haha. Or maybe its different because its asking a internet community instead of someone you know? Ehh.
1999 Saturn SC1(CURSED)-156K at purchase(october 2016)-194k currently (Nov 2018)
Old 11-11-2017, 01:22 PM   #6
Keeter
Keeter's Avatar
1999 SL1
I told him something in the fuel system more than likely. He told my wife again he drives it for 45 min to an hour, and has no problems which makes it hard to diagnose.
At least I have a something to send back to him.
Thanks fellas!!
That's my opinion,
Keeter
Old 11-11-2017, 01:48 PM   #7
'95's don't have TBI, only '91-'94. All DOHC's and '95+ SOHC's have MPFI.
The fuel filter is on the driver side frame rail and costs all of $30 unless you get innovative (then it's like $8).
Sight unseen I'd start with the fuel filter, plugs, wires, ECTS (including connector if it shows signs of corrosion), thermostat and air filter.
Old 11-11-2017, 02:01 PM   #8
wolfman
wolfman's Avatar
Add remove and clean the EGR valve. An intermittent poor running issue, especially after the engine has warmed and at lower RPM or at idle is an EGR issue better than 50% the time.
Add to wolfman's Reputation
Old 11-13-2017, 12:39 PM   #9
Jonasan308
Jonasan308's Avatar
1999 SC1
Huh, i was under the impresdion that you weren't active on this forum at all. Stop by on occasion?
Friend looking for a car Dang S-Series General 9 04-24-2008 01:21 PM
Friend in need... RalliArt16 S-Series Tech 2 06-29-2005 12:22 AM
Hello Hello New Friend mikthehickNC General Saturn Discussion 50 12-31-2004 11:10 PM
Bye Bye Old Friend mikthehickNC General Saturn Discussion 69 12-05-2004 04:51 PM
