Old 11-02-2017, 07:27 AM   #1
VentureForth
VentureForth has a spectacular aura aboutVentureForth has a spectacular aura aboutVentureForth has a spectacular aura about
VentureForth's Avatar
2006 ION-3 Sedan
Default 2006 Ion 3, 2.2L
I've seen some videos on YouTube, but those are really LOUD clicks. My are annoying but are much less, well, violent. It starts when I start the engine, and continues for about two minutes, until warm. Then it slowly fades away. It's noticeable when idling initially. Then, when in Drive, it is only obvious when I accelerate. If I put the car in Neutral and hit the gas, it doesn't occur when it's just a little warm.
My theories - Busted engine mount lifting motor from exhaust flange?
Exhaust leak - perhaps in exhaust manifold?
Noisy lifters (!)?
I think it's exhaust. Anyone else with an idea?
Add to VentureForth's Reputation
Rate the quality of this post and help VentureForth reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
VentureForth is offline   Reply With Quote
Old 11-02-2017, 11:43 AM   #2
jacek_p
jacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the rough
jacek_p's Avatar
2003 ION-2 Sedan
Default Re: 2006 Ion 3, 2.2L
where's your video?
fixed/replaced so far: side mirror, window trims x4, trunk floor, radiator bushing, alternator, starter, LCA x2, sway bar bushings x2, end links x2, timing chain tensioner, O2 sensor.
Add to jacek_p's Reputation
Old 11-08-2017, 11:50 AM   #3
VentureForth
2006 ION-3 Sedan
I don't have a video. I watched other videos. They all seem wrong.
Increasingly, I'm also getting a thumpthumpthump sounds whenever I let OFF the gas when the engine is warm.
Old 11-10-2017, 11:40 AM   #4
VentureForth
2006 ION-3 Sedan
Anyone?
Old 11-21-2017, 07:03 AM   #5
VentureForth
2006 ION-3 Sedan
Determined the 2nd sound was a bad front right shock. THAT fixed a lot of little issues. Still don't know about the clicking when cold.
Old 11-21-2017, 09:18 AM   #6
BobWolf
Find a large empty parking lot and make sharp figure eights both at slow creeping speeds as well as while slightly accelerating. Clicking indicates possibly an outer CV joint. Noise left turn, left side, left outer joint, and vise versa the joint can be bad even if there is no play If your lucky they can clean and repack the joint with the proper grease.
Check that its not a loose wheel, rust between the rotor and hub. If the strut mount is going it will also make a popping / springing noise and the vehicle might pull. I also always check the rubber bushings and mounts including engine mounts, swaybar bushings & links as sound will travel through other components.
Benjamin Franklin.
Add to BobWolf's Reputation
Vue 2006 awd and equinox 2006 awd woilly Vue Tech 3 04-28-2015 01:35 PM
My New Vue 2006 AWD V6 Soberbyker Vue General 6 07-24-2006 06:22 PM
4 Cyl, 5 speed 2006 Vue versus 2006 Tuscon?? 6SHIFTIN Vue General 26 07-07-2006 11:18 AM
2006 AWD 4 Cyl VUE? dpware Vue General 1 07-18-2005 09:59 AM
2006 Vue southaeastpunk Vue General 9 05-20-2005 04:14 PM
