Old 11-10-2017, 01:11 AM   #1
Mysaturnbeater
Mysaturnbeater has a spectacular aura aboutMysaturnbeater has a spectacular aura aboutMysaturnbeater has a spectacular aura about
Default Timing belt
When does the timing belt needs to be changed on my 1998 Saturn SC 1?
I've owned it since 2006 and never did a timing belt change.
Add to Mysaturnbeater's Reputation
Rate the quality of this post and help Mysaturnbeater reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Mysaturnbeater is offline   Reply With Quote
Old 11-10-2017, 02:30 AM   #2
bachands
Default Re: Timing belt
There is no belt. There's a timing chain. They typically last for 100K-150K miles I'd say. And I don't believe there's a way to tell unless you remove the timing cover and check they extension of the tensioner.
'97 SL1, 136K, Auto, Mint Green (SOLD 146K)
'99 SL2, 126K, Auto, Silver (SOLD 149K)
'97 SL1, 136K, Manual, Burgundy (Gifted to Brother 138K)
'02 SL2, 149K, Auto, Light Gray/Silver
Add to bachands's Reputation
Rate the quality of this post and help bachands reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-10-2017, 03:14 AM   #3
Mysaturnbeater
Thanks for the reply back.
Well... I'm already at 277+ K miles on my car.
I'm surprised it's still going.
How difficult would it be to change it?
I really don't want to spend, what I assume will cost more than what the car is worth to have it changed.
Old 11-10-2017, 07:37 AM   #4
I replaced mine at 204K just because I was doing a rebuild. I honestly don't think I'd replace it if I was not already going inside the engine. If it is not making scary noises then I'd let it be.
When I bought my Saturn new in 99, that is one part of the sales pitch I remember. The Hondas and similar had belts and the Saturn had a chain.
Edit: at post 273 in my thread there are pictures of the timing cover off while in the car. Not super hard of a job but a pain compared to working with the engine on a stand. You could do it in a weekend.
http://www.saturnfans.com/forums/sho...230898&page=14
Add to Waiex191's Reputation
Old 11-10-2017, 08:31 AM   #5
Mysaturnbeater
So, what kind of noises should I hear for if it could be the timing chain?
Old 11-10-2017, 08:57 AM   #6
A slapping/loud clacking that never stops.
If you keep up with oil changes, and never let it get below the dipstick I would not worry about changing it at any interval (except at engine rebuild time).
My 96 suburban has a chain, 331K miles on it now, and does not make noise, does not use any oil ever. It had to have been build on a Wednesday.
Old 11-10-2017, 09:27 AM   #7
underthehood
underthehood's Avatar
If the engine is well cared for and there are no weird drives off the chain (i.e. early EcoTec 4 cylinders used the timing chain on the water pump) it should last the same as the engine itself. At 277k as you noted there is no need to do anything unless (as noted) you're hearing bad noises. Otherwise just keep running it until the engine gives up the ghost and needs to be overhauled or replaced
Old 11-10-2017, 02:24 PM   #8
Mysaturnbeater
Thanks for the info.
Old 11-10-2017, 11:52 PM   #9
ssicarman
ssicarman's Avatar
The engine will begin to sound like a diesel engine.
Add to ssicarman's Reputation
Old 11-11-2017, 02:36 PM   #10
meaning, checking the oil often, not letting it run low, and not letting it run dirty for long periods
This. That 883k mile Saturn from a few years ago was on the original chain. Luke's 660k mile car was also on the original chain when he retired the car.
My minivan has a chain, never changed at 240k miles. My '97 SC2 has 201k miles on original chain, my '02 SC2 is at 140k and still strong. I have no plans to ever do another chain unless I have the engine open for other reasons
Highmiles has something like 650k miles on his car. Chain was replaced somewhere around 300~400k miles ago, but only as part of the rebuild.
You do want to periodically replace your serpentine belt, though, as it drives the water pump and alternator, which are useful things to have in a running car
Old 11-13-2017, 04:43 PM   #11
PrestonIII
PrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura about
1994 SL2
1994 SL2
My first SL1 had about 150K miles on it, and the timing chain jumped time more than a few teeth, and ruined the valves and left marks in the tops of the pistons.
It wasn't the chain that went bad the most, but rather the nylon/plastic guides disintegrated. They simply weren't there any more. Large pieces of them were in the oil pan.
I put a junk yard head on the car and a new timing chain and guides and put it back together. It really wasn't that hard to do.
But IMO, the plastic guides are more of a worry than the chain.
Add to PrestonIII's Reputation
Rate the quality of this post and help PrestonIII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-14-2017, 09:43 AM   #12
TXSaturn02
TXSaturn02's Avatar
As mentioned, if engine oil was properly maintained, the chain should last the life of the engine. Replace only at time of rebuild. I sold my car with nearly 224K and engine still purred - original chain.
New owner report of 07/25/18: 229,023 Miles
As of 07/25/18: 51,495 Miles
Old 11-14-2017, 11:30 AM   #13
mbr
mbr is on a distinguished road
1998 SW2
Many confuse the accessory belt for a timing belt. Perhaps that's what the op was referring to.
Accuracy MATTERS!
Add to mbr's Reputation
Rate the quality of this post and help mbr reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mbr is offline   Reply With Quote
Timing marks off now. Timing belt change. Difficilus Vue General 4 12-06-2015 11:46 PM
Changing Timing Belt on a Saturn Vue 2002 AWD and without the timing belt tool kit Joelsaturnvue Vue Tech 16 03-13-2013 01:02 PM
Instalation instructions for Timing Belt from Gates timing belt kit. clean93 L-Series Tech 8 01-12-2012 07:15 PM
Help! - Timing Belt L81 - AC Delco -Rock Auto Kit - Timing Mark Question oldvue Vue Tech 5 09-16-2010 04:55 PM
Timing Belt And Serpentine Belt obsidian52 L-Series Tech 3 06-06-2009 09:23 AM
