Old 11-08-2017, 08:33 PM   #1
dwtutts
dwtutts is on a distinguished road
Default Getting code u2105
Hey guys. My wifeís Saturn is throwing a code u2105. Itís shifting hard and starting a little hard. However. I donít know if thatís is something wrong with the car or itís cold. Either way, I have done some research into it, Iíve tried doing a reset with pulling the battery out and such, but it still is shifting hard. Any ideas?
Itís a Saturn l300. 2004. 135k. V6. Thanks.
Add to dwtutts's Reputation
Rate the quality of this post and help dwtutts reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dwtutts is offline   Reply With Quote
Old 11-08-2017, 09:13 PM   #2
Russet
Russet will become famous soon enoughRusset will become famous soon enough
2002 L-Series 3.0L Sedan
Default Re: Getting code u2105
1. Check Tranx fluid levels that could also affect hard shifts with a reliable tranx shop.
2. What proceeded this problem if any?
3. Maintenance history and repairs?
4. What did you use to read the codes if I recall they are P0 codes.
Add to Russet's Reputation
Old 11-08-2017, 10:20 PM   #3
dwtutts
Seem so fine to me.
I just checked the codes after it started doing it. It was driving fine for us beforehand hand.
I change oil religiously and do all the other maintenance that I know of. Last major repair was a oil pan replacement done maybe 3 months ago.
I used an ancel ad310 classic. It did not have Saturn in it. I used the gm setting.
Old 11-08-2017, 10:31 PM   #4
dwtutts
Also, I just remembered the car seemed to loose power while going through snow drifts or if it spun out on the ice. I was never driving it hard, but if you tried to push it the car would loose some power. The heater would blow much lighter, the dash lights got dim. It never stalled, just loss of power.
Old 11-08-2017, 11:50 PM   #5
Anytime you drive with a car that has abs and traction control, lose traction on slippery surfaces, traction control automatically takes over for one reason. You no longer have your car under control as different wheel speeds are detected by the abs with traction control the opposite of abs, to deliberately reduce wheel spin and regain traction to all four wheels. Any one wheel not having traction means that wheel is either spinning faster or slower than the other three with abs/tc reacting. In your case the abs starts a procedure with reducing spark timing, reducing throttle (literally taking away engine power from your right foot) and in extreme cases, applies braking to remove as much wheel spinning as possible until all four wheels return to the same wheel speeds - the electronics knows the car is back to having traction at lower speed and returns throttle back to your control until you drive faster than the conditions allows normal driving. Yes, electronics are everywhere to remove power when necessary. From any abs, traction control, limp home mode from errors in drive by wire systems, and airbags. Stabilitrak removes engine power when someone makes incorrect high speed car changes in direction. The last step to removing the irresponsible driver are driverless cars being tested everywhere to see if these autonomous vehicles can handle everyday driving situations most of us take granted from years of 'practice' computers need sensors and highly developed programs. Guess how I know this? Practicing in a large parking lot with snow or ice and deliberately accelerating as fast as my car can when abs and traction control take over. I never assume a computer is smarter than me until I test it. This ads first hand experience to anyone interested while most remain clueless until experiencing it the wrong way, while driving in conditions not conducive to having complete control of a vehicle.
Old 11-09-2017, 08:50 AM   #6
floridasl22002
floridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to beholdfloridasl22002 is a splendid one to behold
Before you can propose a solution, you have to know what the problem is. Your car is telling you code U2105. You need to find out what this code means. Once you know the fault, then you can determine a solution. Meanwhile you are grasping at straws.
You need to either call in one of the autostores and see if their CEL readers will diagnose a U Code OR you need to find someone with a Tech11 scanner which will certainly be able to detail the 2105 code.
Don't know if this will help
https://www.justanswer.com/saturn/2x...start-ran.html
Old 11-09-2017, 10:02 AM   #7
dwtutts
Right and it was doing that as well which I knew was traction control, however, why would traction control dim my lights, make the fans blowing hot air half speed?
Old 11-09-2017, 04:43 PM   #8
Your descriptions suggests a power issue; battery, battery cables, their connections, drive belt and tension, and alternator. All are considered parts of main power issues.
Old 11-22-2017, 01:31 PM   #9
According to my 2000 L-Series FSM, Body/Electrical, vol. II, DTC U2105 is defined as "LOST COMMUNICATIONS WITH ECM." One possible repair is to replace the ECM, but that is only stated after certain tests are performed. Other than that, terminal connections at various locations are recommened to check tighteness. This relates to things fdryer has pointed out. I also agree with floridasl22002 regarding the understanding of what this DTC actually relates to so as to make an accurate diagnosis. He correctly points out that use of the GM Tech II Scan Tool, or its equivalent, is required in this instance.
I hope that the OP will keep this thread updated.
287,000 miles-it keeps on rolling!
Add to pierrot's Reputation
U2105 Code bobbycarmon S-Series General 2 08-27-2013 01:33 PM
U2105 and P1780 codes geno607 L-Series Tech 12 10-11-2012 03:40 AM
service engine light error code p1780 and u2105 krateliff L-Series Tech 1 09-01-2012 08:19 PM
Codes U2105, P1780 & P0304 2000 LW2 rigo009 L-Series Tech 3 02-26-2012 03:50 AM
Need my paint code, 96 sc2 black/gold metallic (I'm missing the trunk panel w/code) DJboozeAlot S-Series General 3 03-18-2011 09:26 PM
