Old 11-08-2017, 12:08 PM   #1
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
Default What did you find at the Salvage Yard Today?
I figured I'd make a thread since something neat pops up every so often x)
94(iirc) SL2 with rear discs and ABS
Would the rear discs/ entire assembly, be worth taking off, or are they specifically tied to the ABS or gen specific?
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Old 11-08-2017, 03:18 PM   #2
trottida
trottida's Avatar
Default Re: What did you find at the Salvage Yard Today?
Are those OEM foglamps on that 94? That would be a good snag for someone with a Gen1 sedan.
As far as disc brakes go, there are a lot of mixed reviews. I think the look better than drum but functionally I don't think you'd find much of a difference on these cars. From the pictures they appear to be in really good condition.
I don't believe you require the ABS for disc brakes to function and it's highly probable that they would swap onto any generation S Series. You need to grab the P-Brake cable too.
2001 SL1 MT (423,500 km @ 10/2018)
1999 SL2 MT (267,940 km @ 10/2018)
2011 Suburban LT (116,506 km @ 10/2018)
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Add to trottida's Reputation
Old 11-13-2017, 04:20 PM   #3
PrestonIII
PrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura aboutPrestonIII has a spectacular aura about
1994 SL2
1994 SL2
I found a '91 sedan with the oil-gauge instrument cluster and rear disk brakes, and the mirrors were white to match the car body.
Add to PrestonIII's Reputation
Rate the quality of this post and help PrestonIII reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
PrestonIII is offline   Reply With Quote
Old 02-27-2018, 07:52 PM   #4
Blueboy
Blueboy is on a distinguished road
Blueboy's Avatar
2001 SL2
Today at the pick & pull:
3 trans-side dogbones w/ bolts from gen 3
1 center cover for '98 alloy wheel including lugnut caps
12 more lugnut caps for '98 alloy wheels
14 lugnut caps for plastic wheel covers
6 Saturn fender emblems & 1 front emblem
1 front passenger floor mat
An unused Purolator oil filter
4 plastic wheel well splash panels (2 per side)
Many fasteners and pushpins
4 red plastic covers for positive battery terminal
Saturn maintenance & warranty booklets and namecards
An inkpen and a marker
A usb power supply for lighter socket
4 golf balls
A marble and a ball bearing
$1.31 in pennies, nickels, and dimes
Also found a Michigan license plate but the attendant wouldn't let me keep it. A nice way to spend a sunny, nearly spring afternoon, and only costing $10.15. But the number of S Series cars at the yard is declining, and didn't see any gen 1.
As of March 2018:
2001 SL2 Manual 223K
1998 SL2 Auto 46K
1998 SL2 Manual 1.5K
Add to Blueboy's Reputation
Rate the quality of this post and help Blueboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blueboy is offline   Reply With Quote
Old 02-28-2018, 12:05 AM   #5
Saturn Night
Found myself a used wiper motor assembly, last week, and changed it out. I think I found the ONE thing, that is NOT very easy to service.
I had to pull the crash pad, to get to two nuts on the INSIDE of the firewall, to pull the wiper trans, to get clearance to remove the motor assembly.
Old 02-28-2018, 03:31 PM   #6
ErikTande
ErikTande will become famous soon enough
ErikTande's Avatar
Found a high performance Saturn at the salvage yard this weekend. Hot air intake, strut bar, dirty sock, probably corvette fast.
http://www.youtube.com/velocitylabs
Add to ErikTande's Reputation
Rate the quality of this post and help ErikTande reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ErikTande is offline   Reply With Quote
Old 02-28-2018, 06:01 PM   #7
Saturn Night
With a very lean curb weight of about 2,300 lbs, a stock Twin Cam/5-speed can break high 15s, in the -mile. If you look at the Corvette specs of the C4s from the early 1990s, you will see that the 1st Gen SCs were actually able to keep up with both Camaros and Mustangs. They could certainly drop the jaw of a Vette driver, as the quickest Vettes in that era REQUIRED a $50,000 "ZR1" engine option.
https://www.corvetteforum.com/forums...roduction.html
As Quoted: "1991 Chevrolet Corvette L98 5.3 13.9
1991 Chevrolet Corvette Roadster 5.6 14.1"
"1992 Saturn Coupe SC 8.6 16.5"(And that is likely with the automatic 4-speed, as I run a 17.2 in the -mile with a bad set of rings, bad valve stem seals, and a very large rate of oil consumption to the tune of 1qt/100miles)
As calculated by ideal conditions, an SC2 has the potential to run a 15.59 @ 86.66mph
http://www.wallaceracing.com/et-hp-mph.php
How a car is geared will affect the ETs, but will NOT affect trap speeds. The term "drag", in drag racing, is in reference to aerodynamic drag. HP translates to top speed, amd is affected by curb weight as well as coefficient of drag.
Super cars will hit their top speeds by one of the following methods:
Gear-Limited = Car can not go any faster, due to hitting maximum allowed engine RPM in top gear
Electronically-Limited = Car can not go any faster due to PCM programming restrictions in the engine management software.
Drag-Limited = Car does not have the amount of engine horsepower to overcome the negative effects of wind resistance and downforce drag on the car.
Old 02-28-2018, 09:07 PM   #8
DuaneL
DuaneL is on a distinguished road
Found a BCM to fix a the fuel gauge, odometer and water temp. Many thanks for all the advice about the thirty minute relearn. Two tries then the car fired up fuel gauge, water temp and new odometer reading. Bringing an '02 L200 back to life.
'02 L200
rebirth 2/18
Add to DuaneL's Reputation
Rate the quality of this post and help DuaneL reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
DuaneL is offline   Reply With Quote
Old 03-05-2018, 12:58 AM   #9
rockrtboy
rockrtboy is on a distinguished road
Erik, I could use that strut bar...
Add to rockrtboy's Reputation
Rate the quality of this post and help rockrtboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rockrtboy is offline   Reply With Quote
Old 03-06-2018, 01:11 AM   #10
Saturninin
Saturninin will become famous soon enough
Saturninin's Avatar
2005 VUE 3.5L
1994 SL2
That's just a cheap ebay strut bar.... there's the SPS and AMR which are the higher Grade... (have 1 of both)
Wanted: Dealer items (frames/ key-chains)
Miles(k) 2013~15
94 HCE ~180
05 Vue 3.5 87~140
98 SL1 260~426
08 Outlook XE 20~160
95 SC2 ~128
Past
96 SW2, 98 SL2
160k+ 95 SL,98 SW2, 03 Vue-I4
Add to Saturninin's Reputation
Rate the quality of this post and help Saturninin reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturninin is offline   Reply With Quote
salvage yard gem... S3aturnR S-Series Mods 18 07-14-2015 09:37 PM
Yard Salvage Parts hacadacalopolis L-Series General 3 08-06-2014 08:09 PM
I haven't been to a salvage yard in a while, but... ngrome S-Series General 16 06-29-2012 06:21 PM
saturn salvage yard new S owner S-Series Tech 10 02-21-2008 09:58 AM
Salvage Yard Wheels? 94SL2ndOwner Classifieds 3 05-10-2005 02:30 AM
