Old 10-23-2017, 01:28 PM   #5261
Blueboy
Blueboy is on a distinguished road
Blueboy's Avatar
2001 SL2
Default Re: What did you do to your S-Series today...
Ordered two of these license plate frames over the weekend. I hope they're still available.
As of March 2018:
2001 SL2 Manual 223K
1998 SL2 Auto 46K
1998 SL2 Manual 1.5K
Add to Blueboy's Reputation
Rate the quality of this post and help Blueboy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Blueboy is offline   Reply With Quote
Old 10-23-2017, 05:44 PM   #5262
Blueboy
Blueboy's Avatar
2001 SL2
Just got a refund. They're out of stock.
As of March 2018:
1998 SL2 Auto 46K
Old 10-24-2017, 07:29 AM   #5263
bumpdraft
bumpdraft's Avatar
1998 SW2
I think e-bay has one for $99.95 + shipping
Rescued some N.I.B. seatbelt extensions.
They fit 3rd Gen Model Years 1999-2002
Can anyone here use these?
I was told Saturn Corporation gave them away free of charge.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Old 10-24-2017, 06:53 PM   #5264
Originally Posted by alordofchaos View Post
Yesterday, took advantage of nice weather and hit the local (Mason) JY. Pulled a pair of crystal clear headlamps from an SC1 (they are aftermarket units).
Installed! Old ones on top for comparison. That was after some polishing. They were worse before.
Light is noticeably brighter, at least turning them on in the garage. We'll see tomorrow night.
Old 10-24-2017, 09:03 PM   #5265
Zeebins
Zeebins is a jewel in the roughZeebins is a jewel in the roughZeebins is a jewel in the roughZeebins is a jewel in the rough
Zeebins's Avatar
Replaced the air filter today, the old one had seen better days...
Add to Zeebins's Reputation
Old 10-25-2017, 07:16 AM   #5266
At first, I thought "very unusual burn patterns - wait, why is it burning?"
On closer inspection - looks like mice. Reminds me, I should check the air filters on the cars that are sitting in the driveway.
Morning drive, beams only lit up a car length or two. Nice sharp cutoff but not impressed with pattern/aim yet. adjustment requires small Phillips (was able to adjust a bit with pliers on the outside), so will try and adjust later tonight or tomorrow
Old 10-25-2017, 09:49 AM   #5267
Zeebins
Zeebins's Avatar
Either mice or chipmunks, there was a ton of acorns in there too. One of them even got stuck in the throttle
They made a next out of the blower motor a while back too, this probably happened around the same time and I just never noticed the air filter until now
Old 10-25-2017, 11:42 AM   #5268
I bet that smelled awesome when you turned the heat on!
Add to Waiex191's Reputation
Old 10-25-2017, 11:50 AM   #5269
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: What did you do to your S-Series today...
Oil change on the 1997 SL1. Pennzoil Platinum full synthetic oil with Purolator PL20195 filter. All set for winter!!
1995 SL1 232,300 Well Oiled!!
1997 SL1 62,737 Just A Teenager!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
Old 10-26-2017, 10:53 AM   #5270
Eeeewwww! Gonna have to check the cars sitting in the driveway for that. Wonder how they got in there? I can see the air filter (I've had a bird's nest in one car . . . that my wife or I was driving daily at the time)
aimed the headlights this morning, much better. Vertical adjustment is near perfect, might touch up horizontal a bit. Still not a fan of the pattern, but it does put a lot of light on the road. HIR2s should show up soon, thinking I might install them after all.
Old 10-26-2017, 06:01 PM   #5271
Goggles Pisano
Goggles Pisano is on a distinguished road
Goggles Pisano's Avatar
1999 SL1
Picked up the parts that I ordered from Rock Auto and Tire Rack. I got front and rear struts, strut bellows, strut mounts from KYB, H&R Sport springs, Energy Suspension bushings and a pair of SKF front hubs. I also found a guy who has a front subframe from South Carolina that I'd like to get my hands on.
I had ordered bellows from JC Whitney on eBay, but made the mistake of assuming the front and rear bellows were the same... they were not, so I sent two of those back. The only hiccup from Tire Rack was that one of the rear strut mounts came without the spring seat.
I am still debating over whether to pick up the camber bolts for the struts.
Hopefully once that gets sorted out, I can get this all mounted before the winter comes.
Add to Goggles Pisano's Reputation
Rate the quality of this post and help Goggles Pisano reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Goggles Pisano is offline   Reply With Quote
Old 10-26-2017, 08:54 PM   #5272
We drained a little oil to get it down to the top of the hash mark. Filled up and averaged 32.6 MPG. This tank took us on the first significant highway trip, and we had the pod installed.
Old 10-27-2017, 02:02 AM   #5273
rgrafton
rgrafton is on a distinguished road
rgrafton's Avatar
2002 SC1
Were the old ones done for? Couldn't you have gotten those clear again or no?
2002 SC1 5 speed 140k miles
1994 SL 5 speed 150k miles on engine (250k+ miles on car, tranny...etc.)
Add to rgrafton's Reputation
Rate the quality of this post and help rgrafton reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
rgrafton is offline   Reply With Quote
Old 10-27-2017, 06:53 AM   #5274
TXSaturn02
TXSaturn02's Avatar
Have you ever tried to do that? A lot of work and rarely ever work/last. Replacements are relatively cheap and easy to install.
New owner report of 07/25/18: 229,023 Miles
As of 07/25/18: 51,495 Miles
Old 10-27-2017, 10:10 AM   #5275
True, and time is short for me these days. The pair cost ne around $32 total
Swapping the lights out took literally just minutes. Longest part was undoing the connectors and twisting old bulbs out. Second longest was adjusting beams up/down, still need to move the driver side to the left just a scooch
Stock beam pattern is better, IMO, and easier to aim. I'll take a pic of the aftermarket pattern some time.
I kept the stockers and my plan is, when I have time next summer , to hand-sand the fronts of the lenses, then polish.
Then use a heat gun, remove them from the body, and wash the inside of the lens. Followed by washing the reflective parts and blacking out the rest of the inside, and using silicone to re-attach the lens. They'd look something like this:
http://www.saturnfans.com/forums/showthread.php?t=73989
Old 10-31-2017, 07:36 PM   #5276
CheapRacer
CheapRacer is on a distinguished road
CheapRacer's Avatar
1996 SC1
1996 SC1
Wrapped up the 2017 season at Cape Breton Dragway with the Sportsman Class Points Championship. That makes 5 years in a row finishing top 5 in Sportsman points plus a Sport Compact class Championship in 2014. (2015 photo)
Green 1996 SC-1, Stock, Sportsman class Drag Racer, 17.97 ET @ 75 MPH.
Green 1996 SC-1, 355 Chev, NHRA/IHRA 10.90 class.
1994 Chev ext cab short box 2WD Daily Driver
Add to CheapRacer's Reputation
Rate the quality of this post and help CheapRacer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
CheapRacer is offline   Reply With Quote
Old 11-01-2017, 09:06 PM   #5277
KNGRK9
KNGRK9 has a spectacular aura aboutKNGRK9 has a spectacular aura aboutKNGRK9 has a spectacular aura about
Replaced Passenger Side Control Arm and Ball Joint.
Car was exhibiting very bad symptoms of clunking after braking and in some scenarios of acceleration / turning left. Really needs an alignment now.
Also cleaned the EGR valve and replaced the gasket.
It was very badly caked up with carbon build up. After cleaning that car runs very smooth again, has regained it's acceleration and no longer drops rpm under light throttle at low speeds (between 10-20mph)
And replaced the PCV valve
1999 SL2 HCE - 245k (wrecked)(rebuilding)
2004 Ion Redline - 108k
Add to KNGRK9's Reputation
Rate the quality of this post and help KNGRK9 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KNGRK9 is offline   Reply With Quote
Old 11-02-2017, 07:21 AM   #5278
trottida
trottida's Avatar
Changed over to winter rims and snow tires on the SL1 and SL2. Ready for snow.
Undercoated the SL2 with Corrosion Free.
2001 SL1 MT (417,500 km @ 05/2018)
1999 SL2 MT (260,870 km @ 05/2018)
2011 Suburban LT (111,176 km @ 05/2018)
Past Saturns
1993 SW2 AT
2001 LW200 MT
1992 SL2 MT
:canada:
Add to trottida's Reputation
Old 11-02-2017, 07:42 AM   #5279
Blueboy
Blueboy's Avatar
2001 SL2
Changed oil in the 2001 SL2 at 218K miles. It gets changed every 3000 miles and goes through a quart during that time. Used regular Pennzoil with a short Fram filter (last short one in my stock). I'll switch to the long filter next time, unless another short one is found in the trunk of a J-Y Saturn before then.
As of March 2018:
1998 SL2 Auto 46K
Old 11-08-2017, 09:07 AM   #5280
Nekomimi
Nekomimi is on a distinguished road
Nekomimi's Avatar
1996 SL1
I put hood struts together from the salvage yard ^^
'96 SL1 Originally the family car, passed on to me as my first. "Hellcat" 240,000+ miles and purring smooth.
My Mug is filled with the lost souls of imports.
Add to Nekomimi's Reputation
Rate the quality of this post and help Nekomimi reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Nekomimi is offline   Reply With Quote
Anyone see the "Judge Judy" episode with the 96 S series today? dave.sl S-Series General 23 02-20-2014 03:56 AM
The S Series would be a great car for the lineup today VTHokie00SL2 S-Series General 46 10-01-2012 07:26 AM
Got the L series recall letter today for rear lights Garciavision L-Series General 27 12-22-2005 01:29 PM
REDLINE Series Announced Today D C Vue Red Line 6 04-10-2003 07:14 PM
Saw the L series DVD system today Jeff P L-Series General 1 11-09-2001 08:03 PM
