Old 10-03-2017, 09:11 PM   #121
JerryHughes
JerryHughes has a spectacular aura aboutJerryHughes has a spectacular aura aboutJerryHughes has a spectacular aura about
JerryHughes's Avatar
1997 SL
Default Re: Spark plug ceramic tip broken in engine
Originally Posted by fdryer View Post
There's always a possibility of spark plug boots made a little smaller in diameter resulting in a tighter fit than stock boots. I haven't seen plugs boots in awhile but my guess is they still may require a two step motion of twisting the boot first to break the bond before pulling the boot off. Twist and remove, twist while putting them back on. If the plug boot is overly tight then this makes it more difficult to allow grease to act as a coating to separate plug from insulator.
Yeah, these fit so tight, it's like fitting a rubber over a watermelon!
Add to JerryHughes's Reputation
Rate the quality of this post and help JerryHughes reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JerryHughes is offline   Reply With Quote
Old 10-03-2017, 09:57 PM   #122
Too tight doesn't make sense at all as all these boots do is connect the high voltage coils to plugs while providing insulation against high voltage arcing from plug boots to engine block. I'm guessing those plug boots are incorrect and too tight or the plugs construction is too fat for the boots to fit. Plug boots should be easily removable and go on without tools with minimal grease. With standard plugs my guess is you have plug wires one size too small, if there is such a thing. Kinda like vain women swearing they can fit into a smaller size dress or jeans but everyone sees the obvious.
Old 10-03-2017, 10:03 PM   #123
JerryHughes
1997 SL
Ha, yes! Must be the "vain woman" syndrome.
Old 10-03-2017, 11:54 PM   #124
Correction; plug boots smaller than desired. Plug wires, whether actual wires or carbon impregnated string, remains the same for conducting high voltage.
Old 10-04-2017, 12:26 AM   #125
JerryHughes
1997 SL
Old 10-04-2017, 08:02 PM   #126
JerryHughes
1997 SL
Just bought this plug wire remover. 51250 BlACK
SPARK PLUG WIRE PULLER http://www.lislecorp.com/divisions/p...s/?product=315 Won't arrive for a week. $10 from Walmart, shipping included. Will post if it's decent. (Geez, I'm becoming "wire puller poor" with all these pullers!
Old 10-04-2017, 09:28 PM   #127
Just remember, pull while twisting.
Old 10-04-2017, 09:30 PM   #128
JerryHughes
1997 SL
Will do. I won't take off the current wires, to check the plug, until that tool arrives next week.
Old 10-05-2017, 02:58 AM   #129
Baron5867
Baron5867 is just really niceBaron5867 is just really niceBaron5867 is just really niceBaron5867 is just really nice
1994 SC1
Originally Posted by JerryHughes View Post
Well, I actually did both---on the plug and inside the boot. Ugg. But I think that there is so much grease in there that the metal, snap on part that snaps on the plugs actually pulled out of the rubber because of that fact.
Watch this regarding dielectric grease and its application.
Add to Baron5867's Reputation
Rate the quality of this post and help Baron5867 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Baron5867 is offline   Reply With Quote
Old 10-05-2017, 06:28 AM   #130
JerryHughes
1997 SL
Thanks, Baron. That's a good, informative video. Luckily, the only thing I was putting grease on was the ceramic part of the plug but-----when putting grease on the inside of the plug wire opening, I can't help but think that, in my case, when slipping the wires on the plugs, some of the grease is getting on the end of the spark plug metal terminal. I was putting a "dab" of grease on the end of the wire, then pushing the wire on to the plug. Thanks again for the video. Very helpful.
Old 10-26-2017, 03:43 PM   #131
JerryHughes
1997 SL
Pulled the plug that has been the worst of the bunch today to get a look at the carbon buildup, etc. (Please see attached photo) Time to change the four plugs again or run it for a while longer? Thanks!
Also, just F.Y.I., I tried the plug wire removal tool here---
and I can't get it to work well at all. Not good for me, anyway. Thanks.
Old 10-26-2017, 04:02 PM   #132
I would change at least that plug.
Old 10-26-2017, 04:47 PM   #133
JerryHughes
1997 SL
Okay, did that and upon inspecting the other three, I ended up replacing both #3 and #4 (the two adjacent cylinders which were always the worst). The other two didn't look too bad---in fact, had "some" grey color to them instead of all black. By changing these two, bad cylinder plugs, will they eventually clean themselves out and look more grey; again, eventually, with consistently changing them out? And I lucked out. Got the wires off successfully without trashing them. My fingers worked really well except on the one, closest to the A/C compressor. I used this tool-----
https://www.walmart.com/ip/Lisle-514...liers/51257299
which worked best of all I tried so far. And all the grease I had on the white porcelain part of the plugs helped too! One wire didn't have that audible "snap" when putting that wire back on and I couldn't get it to do that, like the other three. I'll drive and see if it's actually seated or not. Thanks, OldNuc!
Old 10-26-2017, 05:45 PM   #134
With any luck the #s 3&4 will clean up to look like #s 1&2. Will just take time.
Old 10-26-2017, 07:25 PM   #135
JerryHughes
1997 SL
Great! I'll keep on it and hopefully, nurse it back to health. Thank you, OldNuc.
Old 11-04-2017, 02:59 PM   #136
JerryHughes
1997 SL
Should have updated but my having trouble with one of the plug wires seating completely was NOT felt in the acceleration, etc. but it was felt, slightly at idle. Couldn't push the wire all the way down on one plug so I ended up cutting about 1/4" off the end of the rubber boot and now the wire "clicked" in place. Runnin like a top and I'm running some fuel injection cleaner through a full tank of gas, hoping to help the cleanup process.
Old 11-04-2017, 03:20 PM   #137
Some of those boots are just too long or the wire slips in the boot.
Old 11-04-2017, 04:29 PM   #138
JerryHughes
1997 SL
Yeah, in my case, it may have been because the wire slipped in the boot. All's fine now.
Old 12-20-2017, 10:44 PM   #139
JerryHughes
1997 SL
Just changed all four plugs. Actually, maybe a little "past due". Driving out of state Saturday (7 hour drive) and with the new spark plugs, will put some injector cleaner in the tank too. Hoping these plugs look better, in time!
Old 12-28-2017, 05:11 PM   #140
JerryHughes
1997 SL
Well, took a 700 mile drive and put some injection cleaner in the gas tank before leaving. Drove approx. 63 m.p.h. and got about 40 m.p.g. Not bad. All freeway driving. Plugs don't look too bad but I'll watch again in about two weeks, because it will be all city driving.
Broken Spark Plug Extraction / Next Step: Machining the Cylinder Head? Catharine S-Series Tech 38 09-29-2015 09:12 PM
broken spark plug inside cylinder neo7333 S-Series Tech 23 08-11-2012 01:14 AM
P0300 and broken ground on #4 spark plug Frostman L-Series Tech 6 12-01-2011 01:37 AM
Broken Spark Plug - solution eake S-Series Tech 10 03-03-2008 01:50 PM
Broken spark plug Chucktin S-Series Tech 15 11-12-2006 03:47 PM
