Old 11-03-2017, 09:09 PM   #1
96sl1daily
96sl1daily is on a distinguished road
Default fuel line rotted out
my 04 ion rotted out under the heat shielding. i wanna bend my own lines if possible. my only concern is what do i do to where the 3/8 line goes into the fuel filter? is there a line i can buy with whatever type flange is on that line? the lines are fine from the front till where the retaining clip in under the drivers side rear door so id rather not buy all new lines if possible.
any advise or suggestions would be great thanks
04 ion 180k daily driver
97 sl 5 speed .....sold still running great
96 sl1 5speed ....head cracked 187k
Add to 96sl1daily's Reputation
Rate the quality of this post and help 96sl1daily reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
96sl1daily is offline   Reply With Quote
Old 11-04-2017, 12:20 PM   #2
Default Re: fuel line rotted out
Tried goggling 'metal fuel line repairs'? There are as many youtube videos with home made and professional repairs using everything from metal compression fittings to join metal lines, nylon end fittings with a metal barbed fitting to fit into nylon fuel lines while retaining the fuel filter quick connect end, and more. If splicing in a replacement metal line, be sure compression fittings fit and won't leak. Fuel pressures vary from as low as 30 psi to as high as 65 psi so ensuring you find the correct repairs won't result in pressure leaks.
Examples of repairs;
https://www.youtube.com/watch?v=vO0dd2guo90
https://shop.advanceautoparts.com/p/...wLrg&gclsrc=ds
Other members may have specific repair suggestions.
Fuel Line Supplier?-pressurized line is leaking Reliabilityman S-Series Tech 1 05-06-2015 11:31 AM
Fuel line specs on a 1998 Saturn Sl 1 (fuel injected) WadeNKC S-Series Tech 9 01-07-2010 05:42 PM
What happens if you kink/bend a fuel line during fuel filter installation? Dingo Warrior S-Series Tech 4 05-31-2008 09:43 PM
1998 Fuel Filter - (Fuel line retainers) Jeffsimpson S-Series Tech 3 01-30-2008 08:42 PM
Uh Oh! VUE Red Line Fuel Line Recall CanVueYes! Vue Red Line 6 06-26-2004 04:03 PM
