Old 10-30-2017, 03:20 PM   #1
jacek_p
jacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the roughjacek_p is a jewel in the rough
jacek_p's Avatar
2003 ION-2 Sedan
Default oil checking pittfals
Some of you may remember my thread on oil consumption. It's more complicated and i'm starting a new one now.
In short, my son drives 03 Ion and lives in another town and visits us about once a month. i checked oil a month ago and it looked like it was very low (barely on the dipstick) and it took ~2 qts to fill it up. I sort of yelled at him and he claimed oil was fine before the trip. I thought he lied about checking. He went back and I asked him to check oil again. He said overfilled. I assumed he does it wrong. So, I checked this weekend and it looks overfilled alright, at least 1qt, maybe more. Maybe it's not burning oil like I though, but somehow oil was trapped in upper part of crankcase when I checked before?
150,000+ miles. I like to check on cold engine after sitting overnight. My driveway is not perfectly flat, but not hilly either.
fixed/replaced so far: side mirror, window trims x4, trunk floor, radiator bushing, alternator, starter, LCA x2, sway bar bushings x2, end links x2, timing chain tensioner, O2 sensor.
Add to jacek_p's Reputation
Rate the quality of this post and help jacek_p reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jacek_p is offline   Reply With Quote
Old 10-30-2017, 06:49 PM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: oil checking pittfals
I can confirm the same situation on both of my 2.2's. I have to wait at least 24 hours before I get what appears to be a valid reading.
That engine seems to hold an awful lot of oil on the top end before it drains down to the pan.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
rb6667 is online now   Reply With Quote
Old 10-31-2017, 01:25 PM   #3
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
very helpful, thanks for replying. i thought i was going crazy.
Old 10-31-2017, 04:36 PM   #4
WrightMan
WrightMan is on a distinguished road
2004 ION-2 Sedan
Does anyone know why this would happen? I prefer to change the oil at a local shop rather than doing it myself in winter but if it won't fully drain then this could be an issue. Has anyone opened the valve cover to find oil hiding up top due to a partially clogged opening or anything?
2004 Saturn Ion CAI, Aftermarket Headlights and Taillights, Bluetooth Fogs, ZZP 2.5" Cat and Custom 2.5" Complete Exhaust
2000 F150 Off-Road 3" Duals and K&N Intake
2013 Escape 2.0T AWD CAI
Add to WrightMan's Reputation
Rate the quality of this post and help WrightMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WrightMan is offline   Reply With Quote
Old 11-01-2017, 12:27 PM   #5
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
I did open a valve cover almost 2 years ago to replace chain tensioner and there was nothing unusual re: engine cleanliness or oil trapping.
i did some more searches on this and found some old posts suggesting oil levels should be read on the back of the dipstick rather than front of it. i don't know why there would be a difference.
Old 11-04-2017, 11:24 AM   #6
This is a bit late, but I will confirm that an immediate check of the crankcase oil level after shutting off the engine will yield a reading of 1/2 of a quart below the actual level. My owner's handbook states that the oil level should be checked five minutes after the engine has been turned off. While this gives a more accurate reading, I found it to be at least 1/4 of a quart lower than the actual level. I can get an accurate reading after the engine has been off for about 3.5 hours. Generally, I prefer to check the oil level before the first drive of the day. Oil level readings are always accurate at that time.
WrightMan, with regard to draining oil and how much oil may remain in the cylinder head, it's not worth worrying about. Make sure that the engine is fully warmed when the oil is being changed so that it drains as completely as possible. One advantage I have over a shop when changing my oil is that I have much more time to let the oil drain than the shop does. Consequently, more bad oil is removed before filling the engine with fresh, clean oil.
300,000 miles - Holy canolli!
Add to pierrot's Reputation
Old 11-22-2017, 04:17 PM   #7
jacek_p
jacek_p's Avatar
2003 ION-2 Sedan
Update: son came back home for holiday and i got to test it more on a flat surface before changing oil with synth 5W30 this time. Checking oil minutes after engine running gave 1/4 qt above minimum line on both front and back. Checking oil a couple of hrs after engine running gave 3/4 qt above minimum line on the front, but 1/2 above one on the back of the dipstick. Drain and fill (5qts) gave exactly maximum line on the dipstick. I didn't exactly measure the used oil, but it was more than 4 qts. Say, 4.5qts. I assume the back of the dipstick a couple of hrs after engine running gave the best oil estimate.
I still think this is a stupid design of the dipstick with that fish weight at the end.
Happy Turkey everyone!
Checking LCA MikeNW S-Series General 3 10-10-2013 01:38 PM
New here! Just checking in! czd3my Astra General 0 08-22-2012 09:30 PM
New Guy Checking In. TNTRMSKD S-Series General 6 11-03-2007 01:30 AM
Checking oil daoyee S-Series Tech 10 09-19-2006 11:45 PM
Checking out TCM Urbanrover L-Series Tech 0 02-15-2006 08:10 PM
