Old 11-03-2017, 04:37 PM   #1
IsaacRosemond
IsaacRosemond is on a distinguished road
Dizzy 2002 SL1 Clutch Replacement
New to the Forums as a member, however, I've been lurking around here for a while. On my way to work a couple days ago, I was in traffic at a complete stop in first gear. I see an opening in the next lane and shoot for it and lo and behold I cant shift into any gear and can't move. Now after a thorough investigation into the Shifting Mechanism under the cent console I find there is nothing wrong and continue my way down the line. I believe it is problem with one of three things or with my luck a combination of all three. The Clutch Cables, the Master and Slave Cylinder, or the Clutch itself. I was just wondering if you guys know the best parts to get to put in there and some good resources so that I might have some clue as to what I'm doing while I install them. Also is it a good idea to replace all three since I'm going to be doing work down there regardless? Thank you for your replies in advance!
Add to IsaacRosemond's Reputation
Rate the quality of this post and help IsaacRosemond reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
IsaacRosemond is offline   Reply With Quote
Old 11-03-2017, 05:29 PM   #2
Default Re: 2002 SL1 Clutch Replacement
Another thing to check is the passenger side half shaft. Mine snapped once, I could shift through the gears but it is like I was in neutral.
Add to Waiex191's Reputation
Old 11-03-2017, 07:02 PM   #3
Check both axles as either one broken prevents the car from moving.
Clutch guru's please read...New clutch slips after replacement ??? Im-not-guilty S-Series Tech 12 03-15-2018 01:22 PM
Clutch & used Tranny Replacement Comments no Auto Zone clutch!! afptl S-Series General 2 02-22-2015 05:53 PM
2002 SL2 Clutch Squirrel13 S-Series Tech 7 04-06-2013 08:58 PM
A/C clutch replacement 2002 sl1 Mobster S-Series Tech 10 10-29-2011 02:42 PM
94 clutch replacement--must engine be removed to access clutch? agingric S-Series Tech 3 11-11-2010 10:30 AM
