Old 10-22-2017, 07:06 PM   #1
ddemier7
ddemier7 will become famous soon enoughddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
Dazed Left Rear Door Actuater Not Working
I have a 2004 Saturn Ion sedan and the left rear door actuater stopped working. I took door panel off and tested actuater and it works with 12V external power supply so I have a wire intruption somewhere. Anyone know any common problems with the wiring on these sedans?
Add to ddemier7's Reputation
Rate the quality of this post and help ddemier7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-22-2017, 07:34 PM   #2
ssicarman
ssicarman's Avatar
Default Re: Left Rear Door Actuater Not Working
Likely a broken wire in the body to door harness.
Add to ssicarman's Reputation
Old 10-27-2017, 10:45 PM   #3
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Dizzy Re: Left Rear Door Actuater Not Working
You mean right there where the door opens in that black rubber boot?
Old 10-28-2017, 02:03 AM   #4
ruley73
ruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to allruley73 is a name known to all
ruley73's Avatar
2007 ION-2 Quad Coupe
Correct. You can connect a volt meter to the plug going to the actuator and test for 12v if you press and hold the power lock button. One wire will have 12v when pressing the lock and the other wire will have 12v when pressing unlock.
2007 Ion 2 Quad Coupe 5-speed manual 177K miles
2007 Chevy Equinox LT 177K miles
Add to ruley73's Reputation
2002 SL - left rear door glass Apeman S-Series Tech 1 12-16-2016 05:13 PM
Free for pick up...Rear left door 2001 SL1 Worknclassbug Classifieds 0 02-05-2006 02:18 PM
Left Rear Window not working n0n Ion General 6 09-01-2005 06:31 PM
Left rear door small window need to be change watben58 S-Series General 1 08-05-2004 12:36 PM
Rear left door not shutting sometimes elviec Ion General 5 07-20-2004 09:36 AM
