Old 10-26-2017, 08:28 AM   #1
SL2 Ride
SL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura aboutSL2 Ride has a spectacular aura about
2009 AURA XR
2005 ION-3 Sedan
Default 2003 Vue w/bad trans, stalling out
A coworker of mine has the dreaded screeching happening on her 2003 4-cyl Vue automatic, so it's quite likely that the trans is on it's way out.
She says the noise just started today. It shuddered a little bit, then smoothed out and drove fine after that.
But she said the car also stalled out twice on the way to work while driving, something it doesn't normally do. Also, she had the ignition switch replaced under recall a few months ago, so it's not that.
She says the lights were fine, and it started up completely normal. So no dead battery or alternator.
So my question is first of all, is there a general time frame that she can expect complete trans failure? If it's a least a couple of weeks, she'll be able to find another ride at least.
And is it possible the trans could be causing it to stall?
Add to SL2 Ride's Reputation
Rate the quality of this post and help SL2 Ride reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SL2 Ride is offline   Reply With Quote
Old 10-26-2017, 12:55 PM   #2
waiter21
2003 VUE 2.2L
Default Re: 2003 Vue w/bad trans, stalling out
What time is it???
She's on borrowed time
Add to waiter21's Reputation
Old 10-27-2017, 06:44 AM   #3
SL2 Ride
2009 AURA XR
2005 ION-3 Sedan
It failed on her way to work this evening.
Amazing. No sign of trouble previously, and dead within 2 days of first symptoms showing up.
2003 Saturn Vue Stalling out freedomsr40 Vue Tech 40 11-12-2016 08:57 AM
2003 Vue 3.0 Stalling while driving.. kidmoon90 Vue Tech 10 04-04-2016 12:39 PM
2003 Vue stalling/erratic tach Scubadude Vue Tech 14 06-15-2015 10:48 PM
2003 Vue Stalling mmaz Vue General 5 06-10-2010 10:23 PM
2003 LW300 Stalling ggetman L-Series Tech 4 03-04-2010 09:08 PM
