Old 10-24-2017, 07:22 PM   #1
Chaz9496
Chaz9496 is on a distinguished road
2001 L-Series 2.2L Sedan
2003 L-Series 2.2L Sedan
Default Under The Hood Fuse Box
Does anyone have any pictures or diagram of the under the hood fuse box of the L Series ? For some reason I have a loose A/C relay. I've switched out the horn relay with it and it's still loose. It also pulls out easy. The other's are tight in the sockets. It appears to be quite a job to pull it apart and check why this is that way. This is why I have a compressor intermittent on & off issue unless you wiggle the relay at times. Somethings going on inside that shouldn't be if it's loose.
Add to Chaz9496's Reputation
Rate the quality of this post and help Chaz9496 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Chaz9496 is offline   Reply With Quote
Old 10-25-2017, 03:22 PM   #2
Russet
2002 L-Series 3.0L Sedan
Default Re: Under The Hood Fuse Box
Did you inspect the socket connections to see if something was bent or loose inside the socket plug? This should be the first thing to do before any dissembly takes place.
Add to Russet's Reputation
Old 11-15-2017, 09:49 PM   #3
Tom Walsh
Tom Walsh is a jewel in the roughTom Walsh is a jewel in the roughTom Walsh is a jewel in the rough
With a loose socket, you are probably better off just replacing the whole box. Bad things happen when you try to pull them apart and repair them. They are pretty easy to replace. There are three modules that pop out and all the wires are in them. A couple of screws in the bottom and you're done. There,s plenty of them for cheap at the pick and pull. I've installed sockets in S series that didn't have power windows but I haven't had luck with taking them out.
Add to Tom Walsh's Reputation
Rate the quality of this post and help Tom Walsh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Tom Walsh is offline   Reply With Quote
09 VUE under hood fuse block schematic gaurdien 2008 Vue 2 02-11-2017 12:52 PM
low turn light and lose undert the hood fuse box trolwarrior S-Series Tech 0 04-19-2014 04:44 PM
Fuse Panel (under the hood) Jase Astra Tech 4 07-16-2012 09:41 PM
Hood release cable crimped, hood stuck in a released state Cards Ion Tech 3 01-06-2009 06:05 PM
1998 SL1 horn wont work on steering wheel or keychain remote -checked fuse under hood 2002SaturnMan S-Series General 9 04-02-2006 09:11 PM
