Old 01-02-2009, 12:04 PM   #1
jam12
jam12 is on a distinguished road
Default Rear Main seal
I have a 2003 Ion with a 2.2 Eco Tech engine with a/t, has anyone have an issue with the rear main seal or the upper oil pan carrier leaking? I have had the lower oil pan seal replaced twice but still leaks at the right rear corner of engine where the oil pan and trans meet. You cannot get a good look at where the oil is leaking because of the way the engine and trans come together. I even used dye with a black light. I checked the surface with the oil pan off and didn't see any cracks or pits in the housings.
Add to jam12's Reputation
Rate the quality of this post and help jam12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
jam12 is offline   Reply With Quote
Old 01-02-2009, 07:02 PM   #2
2006 ion2
2007 ION-2 Sedan
Default Re: Rear Main seal
someone on here had a problem with their ecotec leaking oil from seemingly nowhere and it ended up being porosity in the casting or a small crack, they couldn't determine which. other than that, these engines aren't well known for leaking anything, as a matter of fact, the ecotec is known for being relatively trouble-free minus the 02-06 2.2s ignition system and the 02s (in the L series and cavaliers) timing chain.
2007 Saturn Ion 2
2003 Chevrolet venture lt
Add to 2006 ion2's Reputation
Old 10-11-2017, 12:52 AM   #3
ddemier7
ddemier7 will become famous soon enough
ddemier7's Avatar
2004 ION-1 Sedan
I have a similar problem. See my posts that explain it in detail. Did you ever find the root of your problem?
Add to ddemier7's Reputation
Rate the quality of this post and help ddemier7 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-20-2017, 12:34 AM   #4
ddemier7
ddemier7's Avatar
2004 ION-1 Sedan
Dizzy Re: Rear Main seal
Update
Rear main seal kjtyo4 S-Series Tech 4 11-09-2009 04:19 PM
Rear main seal Saturninin S-Series Tech 10 06-19-2009 06:15 PM
rear main seal vtsl2 S-Series Tech 9 04-26-2008 12:51 PM
Rear Main seal MikeNW S-Series Tech 2 04-14-2008 10:41 PM
Rear Main Seal 8urz06 S-Series Tech 11 05-03-2003 12:53 PM
