Old 10-17-2017, 01:48 AM   #1
RobertGary1
1996 SC2
Default A/C pressure switch
The FSM doesn't call for discharging the A/C system prior to changing the switch. I'm assuming this is a mistake and that there isn't some type of diaphragm in the manifold at the compressor. Anyone here actually need to change the pressure switch on a Vue?
-Robert
Old 10-17-2017, 10:47 AM   #2
RobertGary1
1996 SC2
Default Re: A/C pressure switch
Hmm, parts diagram shows it sits over a valve. Maybe you can replace it without discharging. This is the valve it says it sits on.
https://static.summitracing.com/glob...0177_br_ml.jpg
-Robert
Old 10-17-2017, 01:58 PM   #3
ronaconda
ronaconda has a spectacular aura aboutronaconda has a spectacular aura aboutronaconda has a spectacular aura about
2003 VUE 2.2L
The diagram is correct. Typically the pressure switches sit above a shrader valve that will close when the switch is removed.
Add to ronaconda's Reputation
Rate the quality of this post and help ronaconda reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ronaconda is offline   Reply With Quote
Old 10-18-2017, 11:30 AM   #4
RobertGary1
1996 SC2
Thanks!
-Robert
a/c pressure switch SURFERDAVE L-Series Tech 1 10-18-2015 10:56 AM
a/c pressure switch?? desertrat S-Series Tech 3 08-04-2012 01:14 PM
Replacing Pressure Cut-Off Switch or (cycle switch) mrclean92124 S-Series Tech 6 04-07-2010 06:32 PM
98 SW2 A/C pressure switch Donny L-Series General 2 03-10-2008 02:15 AM
A/C Low-Pressure Cut-off Switch... Where is it?? jayjr98 S-Series General 3 04-15-2006 05:47 PM
