Old 09-20-2017, 02:09 PM   #1
saturn_batterie
saturn_batterie is on a distinguished road
saturn_batterie's Avatar
Default Saturn Project
Hello,
I'm new to this forum. I spent a lot of time looking to see if there was another thread I could put this in, but I didn't see anywhere else where I could put my idea for my Saturn. If this isn't supposed to be here, the moderators can gladly delete or move this thread if they need to.
Anyways, I have a 1997 Saturn SL2 with DOHC. When I bought the car, the man who owned the car before me put a Spectre performance air filter on it. I bought the flexible intake ducting for it, and moved the filter in a colder spot.
My future plans for the car is to install a dry nitrous kit on it. I am planning to run 50 shots max, because I don't want to blow up the engine. What nitrous brands are recommended for Saturns? I am also thinking of putting on performance suspension parts onto it, and better brakes.
Thank you!
Add to saturn_batterie's Reputation
Rate the quality of this post and help saturn_batterie reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturn_batterie is offline   Reply With Quote
Old 09-23-2017, 07:29 AM   #2
Saturn Night
Saturn Night has a spectacular aura aboutSaturn Night has a spectacular aura aboutSaturn Night has a spectacular aura about
Default Re: Saturn Project
I believe AMR Engineering makes the suspension components you will want. With a 50-shot of dry nitrous, I would recommend forged internals and a full balance of your crankshaft.
These engines flop around and have a lot of damaging harmonics, due to the camshaft profiles. The stock components are fairly rugged. I just made 10 passes at the track, last night, and I burn a quart of oil every 100-125 miles. No knocks, no ticks, and almost 180,000 miles on it.
But, when you add nitrous or boost(turbo/supercharger), you change things pretty drastically.
Finding forged pistons shouldn't be a problem. Look for reputable machine shops for balancing the crankshaft. Sealed Power, by Federal Mogul, are the recommended piston for standard rebuilds(due to having oil drain back holes that GM "conveniently" left out of the stock pistons).
1991 Pontiac Grand Am @ 142k - Iron Duke w/auto
1995 Saturn SC2 @ 184k - DOHC w/auto 1qt/100mi
Old 09-24-2017, 06:39 PM   #3
saturn_batterie
Thank you for the advice! I'll have to see what I can do about the Pistons and crankshaft. I'll check out AMR when I get the chance.
Old 09-24-2017, 09:03 PM   #4
Saturn Night
Not a problem. If you search by keywords, you may find some older threads with the information you are searching for, right here on our site, too.
Old 10-15-2017, 09:11 PM   #5
saturn_batterie
I saw ZEX has a safe shot nitrous kit that has jets that add up to 35 shots, and I think that's the way I want to go, I'd still stick with 15 or a low number like that. Do you think that balancing the crankshaft and getting better pistons would still be needed? It won't let me post a link, but I found it on Amazon.
Old 10-15-2017, 09:59 PM   #6
Whole entire forum section dedicated to N2O: https://sixthsphere.com/forumdisplay...-Nitrous-Oxide
I think I'd still do a wet shot rather than a dry shot, and get a wide-band O2 sensor with gauge.
Saturn SW2 project car Brendo613 Classifieds 0 10-03-2015 03:01 PM
Saturn V8 project Saturn V8 S-Series Tech 14 10-29-2009 01:59 PM
My First Saturn Project PH8AL S-Series Mods 25 04-14-2009 04:13 PM
Current Project Towing New Project popp Vue Red Line 6 04-10-2006 11:55 PM
