Old 08-25-2011, 06:12 PM   #1
slacke
slacke is on a distinguished road
Default 2006 Saturn Vue Blower Motor Totally Inop
This is giving me fits. Blower motor inoperative. I test the motor with 12 volts and it runs fine. Blower fuse has power both sides. HVAC relay is working. Control switch is operating normal as far as I can tell. (When you switch it to off it cuts off the A-C compressor.) Could it be the resistor? Any ideas? Thanks in advance, Slacke.
Add to slacke's Reputation
Rate the quality of this post and help slacke reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
slacke is offline   Reply With Quote
Old 08-25-2011, 08:08 PM   #2
far2grumpy
far2grumpy's Avatar
Default Re: 2006 Saturn Vue Blower Motor Totally Inop
See post # 4 of following thread for wiring diagram (its good for 2006):
http://www.saturnfans.com/forums/sho...d.php?t=144044
The blower bypasses all resistors when you select position 4.
Most likely cause of not operating at any speed is a overheated (and now open) connection in the 40 amp blower +12 feed line.
See the diagram - many have found overheated/corroded connections in the C200 connector which is behind the close-out panel next to drivers left foot when seated (panel behind hood release).
The panel is part of the carpet / door sill retainer. It can be removed by sliding a putty knife or screwdriver underneath and gently working it up.
You may want to take a peek behind the panel. If the larger orange wire has black and bubbly insulation - you could cut a chunk out and splice in a new piece to bypass the connector.
Old 08-26-2011, 04:23 AM   #3
slacke
Thanks Grumpy! That makes sense to me. I will check it out today and report back.
Old 08-26-2011, 07:41 PM   #4
slacke
Well Grumpy, you were right. I have the blower running again. I pulled a bone-head manuver and cut the wrong orange wire so I got to splice two wires tonight. I never would of found that in a hundred years. Once again, thanks.
Old 08-26-2011, 09:44 PM   #5
far2grumpy
far2grumpy's Avatar
You only cut one wrong wire? That hardly qualifies as a mistake in my book.
I've been known to build a 24 wire harness and wind up with the whole thing about 18 inches too short. It was painful and pitiful to see how I paid for that.
Its good you have the blower working again - there's a bit of chill in the air in Iowa so we'll soon forget about the A/C and start checking to make sure the heated seats still work.
Old 06-30-2013, 05:36 PM   #6
gonna.act.right
gonna.act.right is on a distinguished road
Just note: I found this thread after the same issue has come up on my '07... I appreciate the diagram, but just want to add my findings and assist others with it...
On the blower motor resistor, after pulling the plug and turning the click facing towards me... my colors are the same as the schematic, but pin outs are different... instead of (lft to rt)Yel,TN,L-Blu, Pur.. Mine is Yel,L-Blu, Pur,TN... And my VOM readings show increasing or decreasing resistor values; depending on how you want to look at it; but do relate to the diagram as more resistance slows the motor down... on the pur branch those 2 resistors equal .6 Ohm, the resistor between L-Blu &TN is 1 ohm, and between TN & Yel is 1.7 and total I got 3.3 Ohms.. So aside from the these values being incorrect, I know I have no open circuit and I should be good to continue...
As far as the orange wire at c200, again, great help on the pointer... I checked voltage on both sides of the plug and had 1.5vd.. So I am going to splice the connection & bypass the connector with fuse link wire. Hopefull this will restore ample power to my blower, as I was only getting 11.2v at the blower motor...
PS: if you ever need help troubleshooting & don't mind spending $15 for your vehicle... The DYI version of the software shops & garages use is available... alldatadiy [dot]C0M Which is where I'm going if this c200 doesn't do it...
Add to gonna.act.right's Reputation
Rate the quality of this post and help gonna.act.right reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gonna.act.right is offline   Reply With Quote
Old 07-09-2013, 03:31 PM   #7
gonna.act.right
Hey guys....
BINGO!!
Popped the panel, lifted the harness from the body clips & seperated the plug.. Sure nuff, saw a burnt spade from one side of the plug... That's the wire that I spliced and cold air again!!!
Old 08-28-2013, 06:42 PM   #8
travisp864
travisp864 is on a distinguished road
travisp864's Avatar
2004 VUE 3.5L
Same thing here. Orange wire in that connector totally burned the terminal. 2004 AWD V6.
Add to travisp864's Reputation
Rate the quality of this post and help travisp864 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
travisp864 is offline   Reply With Quote
Old 07-19-2014, 10:37 AM   #9
WannaHelpU
WannaHelpU is on a distinguished road
Found the connector behind the plastic panel just as f2grumpy described.
Before looking here, I checked the manual/fuses, etc. Funny, but the manual didn't say anything about the possibility of a corroded orange wire... go figure.
I was lucky. Separated and re-connected the connector and that did it; no splicing necessary... whew!
Thanx, grumpy!
Add to WannaHelpU's Reputation
Rate the quality of this post and help WannaHelpU reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WannaHelpU is offline   Reply With Quote
Old 04-17-2015, 10:54 PM   #10
AWDsaturn
AWDsaturn is on a distinguished road
2002 VUE 3.0L
Guys,
I just had this same issue on my 02 Sat Vue, AWD , V-6....it was driving me nuts. I checked the 40 amp fuse - all ok , I removed the blower motor and checked it with a alternate power source (motorcycle batt) all ok, I swapped out resistors - no help , I swapped HVAC blower relays in pax kick panel - no joy. I then read this thread and went straight to that problematic connector in the drivers kick panel. Sure enough, I re-seated the connector a few times and BINGO....Blower fan , ops checked good. I wish there was some way to shield the connector from corrosion.....anybody know ??
Add to AWDsaturn's Reputation
Rate the quality of this post and help AWDsaturn reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
AWDsaturn is offline   Reply With Quote
Old 08-17-2015, 10:13 AM   #11
saturnknight
saturnknight is on a distinguished road
Thumbs Up Re: 2006 Saturn Vue Blower Motor Totally Inop
Thank you! My blower is back in operation now. Burnt orange wire at the panel connection behind the hood release.
Add to saturnknight's Reputation
Rate the quality of this post and help saturnknight reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
saturnknight is offline   Reply With Quote
Old 09-17-2016, 08:51 AM   #12
moogoogypan
moogoogypan has a spectacular aura aboutmoogoogypan has a spectacular aura aboutmoogoogypan has a spectacular aura about
Cheers Grumpy, you have saved another Saturn owner from endless frustration and mucho expense with your simple blower fix.
Add to moogoogypan's Reputation
Rate the quality of this post and help moogoogypan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
moogoogypan is offline   Reply With Quote
Old 10-14-2017, 04:24 PM   #13
Erock7777
Erock7777 has a spectacular aura aboutErock7777 has a spectacular aura aboutErock7777 has a spectacular aura about
Happy Re: 2006 Saturn Vue Blower Motor Totally Inop
I just want to say thank you thank you thank you !!! I've been working on my wife's saturn vue for about three weeks trying to get the blower motor working !! To no avail !! We have a 15 month baby girl . And it has been ruffff on her .. I have spent a little over $230.00 trying to get this thing fixed. And after reading this forums threads. I had it fixed in about 7 minutes !! It was behind the driver's side kick plate. I have done a lot of reading and video watching . And nobody else ever said anything about behind the kick plate.. again thank you !!!!!
Add to Erock7777's Reputation
Rate the quality of this post and help Erock7777 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Erock7777 is offline   Reply With Quote
2006 Saturn VUE V6: Changed motor mount, still getting vibration & MORE! mustud79 Vue Tech 18 02-26-2017 05:06 PM
2000 saturn ls2 blower motor how to?? omgwtf L-Series Tech 1 11-22-2009 11:35 AM
2004 saturn vue , ac/heat blower motor no power iamyourtech Vue Tech 3 09-08-2009 09:40 PM
2006 Vue blower motor replacement NoCheese Vue Tech 13 08-22-2009 07:36 PM
Blower motor inop Nick3saturns S-Series Tech 6 04-01-2007 10:49 PM
