Old 10-09-2017, 11:18 AM   #1
WrightMan
WrightMan is on a distinguished road
2004 ION-2 Sedan
Question Wiring New Fog Lights
So I did not have any factory fog lights so I picked up a set that run off Bluetooth and just need to be wired in the front of the car and no switches to the inside. Normally I would go straight to the battery but since that is in the trunk I was looking for options under the hood. Where would be the best place to wire this? I do not like those splice kits and would like to find a bolt on for the positive at least since the ground can pretty much go anywhere.
Any tips would be appreciated!
Thanks!
2004 Saturn Ion 2 Black Trim Headlights, Bluetooth Fogs, and Smoked Taillights
2004 Crown Vic Mostly Modified
2000 F150 Off-Road Mostly Stock
2013 Escape 2.0T AWD
Add to WrightMan's Reputation
Rate the quality of this post and help WrightMan reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
WrightMan is offline   Reply With Quote
Old 10-09-2017, 03:09 PM   #2
WrightMan
2004 ION-2 Sedan
Default Re: Wiring New Fog Lights
I was thinking of trying to find a constant power source that I can add the lights to which already have an inline fuse and about an 1/8 inch bolt.
Old 10-10-2017, 04:10 PM   #3
hudypete1
hudypete1 is a jewel in the roughhudypete1 is a jewel in the roughhudypete1 is a jewel in the rough
2007 ION-3 Sedan
On the underhood fuse box, there are two screws that stick up, both on the front side. The engine side one has a lead that goes to the starter. The outside one (wheel side) brings in power from the battery.
I would think about connecting to the engine side one, labeled B+ (iirc) on the wiring schematics and putting my own in-line fuse on my wire. It is a good open location and very easy to connect on to. All you will need is a 10mm socket or wrench to get the nut off.
For the ground, you could probably just tap into the metal of the body anywhere.
If you don't have any wiring diagrams yet, if you open a MyZone account at AutoZone under Vehicle Repair Guides (left side of page, under MyVehicle) there are many wiring diagrams.
Peter in Lansing MI
current cars:
94 SW2 (White, automatic)
99 SL2 (Silver Plum, manual)
99 SL2 (Dark Blue, manual)
04 Ion 3 (Berry Red, 2.0L automatic)
07 Ion 3 (Cypress Green, 2.4L, manual)
Add to hudypete1's Reputation
Rate the quality of this post and help hudypete1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
hudypete1 is offline   Reply With Quote
Old 10-13-2017, 10:18 AM   #4
WrightMan
2004 ION-2 Sedan
Actually I would prefer to go to the live one which is the outer one by the wheel. There is a low voltage cut off and in line fuse that I am using as well so it won't let the battery drop too low. I like to be able to turn on the fog lights with the wireless control which also lets me change the colors as well.
Old 10-13-2017, 02:25 PM   #5
GTS350
GTS350 is a jewel in the roughGTS350 is a jewel in the roughGTS350 is a jewel in the rough
1999 SC2
How about a piggy back fuse. Quick no wire cutting and the original circuit has its own fuse and the fog lights have their own fuse.
1999 Saturn SC2 (automatic) 23,000 orig miles (9/10/16)
1996 BMW E36
1971 Holden Monaro GTS 350
1908 Buick Model 10
Add to GTS350's Reputation
Rate the quality of this post and help GTS350 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
GTS350 is offline   Reply With Quote
Old 10-13-2017, 03:22 PM   #6
WrightMan
2004 ION-2 Sedan
In that case it would be sharing power with what ever else is on the shared circuit though and I prefer to use a higher gauge wire that is by itself so it doesn't draw from anywhere else or have to worry about the jumper going bad and effecting the original item. That is an interesting idea though and if I add more to the front I might be able to incorporate it elsewhere. My truck has a fuse block I added to the back with direct power to work auxiliary outlets and a hitch mounted winch. This would help to not have to replace the box with a larger one.
Wiring Trailer Lights Snerdguy S-Series Tech 6 12-18-2015 08:40 AM
Fog Lights Wiring crimsonandblue L-Series Tech 1 05-22-2013 03:13 PM
93 SC1 parking lights wiring diagram z28bill S-Series Tech 0 12-23-2010 04:04 PM
Lights wiring questions macman90 L-Series Tech 8 07-15-2009 10:30 PM
'01 reverse lights wiring KnockOut S-Series Tech 4 03-15-2007 04:19 PM
