Old 10-15-2015, 06:29 AM   #81
KDulcimer
KDulcimer is on a distinguished road
1998 SW2
Default Re: Used Oil Analysis Thread for Our Engines.
I always use Mobil 1 or Pennzoil Platinum. I believe this one was Mobil 1.
SaturnFans helper map: http://bit.ly/1uDorVF
Wife's: 98 SW2, 130k, auto trans, bought 01/2014
Mine: 07 Focus wagon, 5 speed, 380k km, bought 02/2015
02 SL sold after 3.5 years of faithful service.
Add to KDulcimer's Reputation
Rate the quality of this post and help KDulcimer reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
KDulcimer is offline   Reply With Quote
Old 10-31-2015, 07:35 PM   #82
KDulcimer
1998 SW2
For the record, I think I found the source of my above issue. The air filter is fine, but the last time I cleaned the throttle body, I forgot to tighten a hose clamp.
Old 02-13-2016, 10:23 AM   #83
Sid
Sid will become famous soon enough
Sid's Avatar
1996 SW2
Previous oil and filter: Mobil 1 Extended Performance 5w30, WIX 51348XP filter.
Last oil and filter: Amsoil signature series 0w30, WIX 51348Xp changed after 1 year (recommended by Amsoil)
New oil and filter: Amsoil 0w30 and WIX 51348XP filter.
Oil use for both oils was my typical 1/2 Qt per 1,500 miles. The 0w30 oil use may have been a tad less than the M1 5w30.
Less shearing with the Amsoil than the M1 oil as expected.
96 SW2 5MT
Add to Sid's Reputation
Rate the quality of this post and help Sid reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sid is offline   Reply With Quote
Old 08-30-2016, 08:23 PM   #84
saturnsctwo
out of curiosity has anybody gotten an oil analysis who uses an oil filter magnet? if so did it make a difference with the iron particles in the oil?
Add to saturnsctwo's Reputation
Rate the quality of this post and help saturnsctwo reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 11-03-2016, 08:25 PM   #85
mattwithcats
mattwithcats will become famous soon enoughmattwithcats will become famous soon enough
Default 2002 Saurn SL2, Mobil 1 AFE UOA
Mobil 1 Advanced Fuel Economy, 0W-30
Purolator Synthetic PSL 20195
2500 miles, 2 years
Changed due to time
Mostly long highway drives, 2 hours+
2002 Silver SL2, manual, 5th gear swap (.605), 78,000 miles, black badges,
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 03-29-2017, 08:57 PM   #86
RB97SL1
RB97SL1 is on a distinguished road
I bought a 1997 SL1 new. I changed the oil every 3,000 miles with Valvoline 5W30. The car has 330,000 miles on it and still runs good. I have to add a 1/2 quart of oil per week.
Add to RB97SL1's Reputation
Rate the quality of this post and help RB97SL1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
RB97SL1 is offline   Reply With Quote
Old 10-06-2017, 09:15 PM   #87
NWSaturn247
NWSaturn247 is on a distinguished road
NWSaturn247's Avatar
1993 SL2
My first analysis
1993 SL2 AT - 185k miles
running blend of various SOPUS oils & D3422
TCW3 dosed fuel
Goldie: a dame to kill for...watch out squirrels!
Add to NWSaturn247's Reputation
Rate the quality of this post and help NWSaturn247 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
NWSaturn247 is offline   Reply With Quote
Old 10-06-2017, 10:54 PM   #88
Eiron
Eiron is on a distinguished road
Eiron's Avatar
1999 SW2
So, your sig says Valvoline HM 5W-30 + LM2009, but the report says Mobil 1 5W-30. Was this UOA M1 w/o LM? And was it the HM M1? Also, are you using the larger 20195 filter shown in your sig?
Some interval questions:
How long did it take you to reach 5544 miles?
How much make-up oil did you have to add?
What kind of air filter are you using?
That's all I got for now.
He's dead Jim!
You grab his tricorder, I'll get his wallet.
Add to Eiron's Reputation
Rate the quality of this post and help Eiron reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Eiron is offline   Reply With Quote
Old 10-07-2017, 12:36 AM   #89
NWSaturn247
1993 SL2
Oil used in OCI
Initial:
1 quart Mobil 1 HM 5w-20
3 quarts Mobil 1 5w-30
15 ounce bottle of STP High Mileage Oil treatment
Bosch Distance Plus D3422
2 additional quarts of Mobil 1 used for top-off during OCI
OCI duration, ~2.5 months
Purolator Classic air filter installed
Cleaned throttle body just a couple hundred miles before oil change and installed a fresh Purolator air filter
I add 2 cycle oil to nearly every fuel fill-up
My emissions are very low when tested by my Department of Motor Vehicles
Currently I am using the Valvoline with LiquiMoly and Purolator Synthetic filter. I did not use it in the oil analyzed.
TCW3 dosed fuel
Old 10-07-2017, 11:41 AM   #90
Eiron
Eiron's Avatar
1999 SW2
Cool, thanks! A few more questions:
Why are you adding the STP?
Do you add the 2 cycle oil to the fuel? And if so, how does it benefit?
2 qts in 5,500 miles sounds relatively low for top-up (around here), and your numbers look reasonably good. Combined with your short amount of time (lots of highway miles?), why wouldn't you top up with M1 HM and extend out to 10,000 miles?
He's dead Jim!
Old 10-07-2017, 11:07 PM   #91
NWSaturn247
1993 SL2
I stockpiled some products during the great $5 off $5 days at O'Reilly.
The 2 cycle oil seems to clean things up and help with emissions. Last test my old beast only polluted 15ppm HC. Pretty darn good. Oregon allows 220ppm. Also my car emitted zero Carbon Monoxide.
Check this site
http://www.ls1.com/forums/f48/been-testing-oil-91206/
I also have this device installed which may reduce emissions
http://nvfuelsaver.homestead.com/index.html
TCW3 dosed fuel
Another spark plug analysis thread WarWeasel S-Series General 1 07-04-2011 04:44 PM
Oil analysis - 09 xr VUESBROTHERS Outlook General 4 06-29-2010 09:48 PM
Follow up thread to the ignition key cyl thread Scott Peterson S-Series Tech 3 06-09-2010 07:00 PM
A Look at Oil Analysis for 92 Sl2 stanleyr S-Series Tech 2 05-18-2007 08:08 AM
04 Vue V6, Oil Analysis HomeBase Vue Tech 4 01-06-2005 12:52 PM
