Old 09-27-2017, 02:23 PM   #21
Ecomike
Ecomike has a spectacular aura aboutEcomike has a spectacular aura aboutEcomike has a spectacular aura about
Default Re: hard starting 2001 SL1
Originally Posted by SRGW View Post
I am old school always look for the obvious. Hope it doesn't return.
1995 SL1 231,050 Well Oiled!!
1997 SL1 62,450 Just A Teenager!!
CHECK YOUR OIL!!
What is baffling is I have been fighting the P0401 and P0410 code nightmare issue for 6 years. It was at the point where it was time to pull the head and soak it to remove the carbon and pull exh manifold and clean its air ports a second time.
I did the MMO oil soak trick of the pistons top side to solve a 1 quart of oil/200 mile guzzler issue 8 weeks ago (20W50 oil), worked like a charm, them 3 days ago I had a dash clicking sound that came on long after the car was turned off, and a second door lock switch go bad a week ago while this issue started and while the lean code showed up.
Now all of a sudden no problems after the battery (and I did pull one door switch, and replaced the 2 door lock-unlock switches and fuse and relay last night, but none of that stopped the lean code, EGR codes and engine idle cyclic miss issues)
Add to Ecomike's Reputation
Rate the quality of this post and help Ecomike reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 09-27-2017, 02:26 PM   #22
Ecomike
LOL, vehicle and other cloaked gremlins are rarely obvious in my world.
CHECK YOUR OIL!!
Old 09-28-2017, 02:39 PM   #23
Ecomike
The P0171 lean code showed up right away first short trip today (rapid acceleration/decel triggered it, cleared the code, and minutes later P0401 code came up, cleared it, then no codes since then on the last 40 miles of the single trip.
Starting the think the FPR is bleeding down after the 2 second initial prestart prime, more on that later....
Old 10-06-2017, 01:05 PM   #24
Ecomike
Too little time....but so far I am suspecting the FPR is not holding pressure, and leaks down quickly after priming. Still need to test it with an FP gauge. LTFT is just a little bit too positive, enough to start throwing a lean code per this. My LTFT is running as high as +12 IIRC, +10 to 11 for sure, and If I crank the rig at exactly 2-2.5 seconds after reaching the run, from the off location on the ignition switch, It usually starts right up and fast (right after the 2 second fuel primer timer sequence). I do not think the FPR has ever been changed, not since before 2008 for sure.
PCV valve and hose (both ancient), EGR valve sticking open (It does have an never ending EGR code fetish,LOL, even with the new EGR), and a few others I found:
Causes of Fuel Trim Trouble Codes P0171 P0174
A P0171 or P0174 trouble code tells you the fuel mixture is running lean (not enough fuel and/or too much air). This type of problem can be confirmed by looking at the Short Term Fuel Trim (STFT) and Long Term Fuel Trim (LTFT) values with a scan tool. Normally, STFT and LTFT should be plus or minus 5 to 10 from zero. If STFT and/or LTFT are more than about +12, it indicates the engine is running lean. Negative numbers (-12 or more) indicates the engine is running rich.
A lean fuel condition can be caused by:
* Low fuel pressure due to a weak pump or leaky fuel pressure regulator. Use a fuel pressure gauge to check fuel pressure at idle. If fuel pressure is less than specifications, your fuel filter may be plugged, your fuel pump may be failing or have a bad wiring connection, or the fuel pressure regulator may be leaking.
* Dirty fuel injectors. Cleaning the injectors with a fuel system additive, or having the injectors professionally cleaned may solve your problem.
* Vacuum leaks at the intake manifold, vacuum hose connections or throttle body.
* Leaky EGR valve. Check the operation of EGR valve and system, and for a buildup of carbon under the valve.
* Leaky PCV Valve or hose. (Check valve and hose connections)
* Dirty or defective Mass Airflow Sensor (MAF). Try cleaning the MAF sensor wires or filament with aerosol electronics cleaner. Do NOT use anything else to clean the sensor, and do not touch the sensor wires.
From: http://www.aa1car.com/library/common_trouble_codes.htm
I did RE-discover, that just clearing the MIL codes, does not change as much as disconnecting the battery. Killing power at the battery clears all the old sensor junk data stored in KAM, like the LTFT and results in very much different behavior in the first 30 minutes or more of run time!!! And it changes the relearn drive time in a huge way!!!
Old 10-06-2017, 01:06 PM   #25
Ecomike
Where is the fuel filter on the 2001 SL-1?
Old 10-06-2017, 01:36 PM   #26
Look under the rear driver's side or passenger side chassis between the fuel tank and ahead of the rear wheel wells. It should be obvious.
Old 10-06-2017, 01:43 PM   #27
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: hard starting 2001 SL1
https://www.youtube.com/watch?v=lVeyA6B2afU
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 10-06-2017, 03:27 PM   #28
Fuel filter on an '01 should last 150k or more (owner's manual calls for changes at 100k miles).
Any idea of the brand that was installed?
Multiple people have had issues with pressure with certain brands - the recommended one is Wix 337331; though a few have tested GK Industries Part number: GF1846 and found it works (IIRC, it was 1 psi over the range)
Fram (G9370) and Purolator (F65501) were listed specifically to be avoided. Fits, but provide incorrect fuel pressure
Old 10-07-2017, 11:49 AM   #29
Ecomike
and fuel filter brand, if replaced. Only a couple brands are known to provide the right pressure with the integrated regulator
Tell me more please!!! What brands? Sound like you are saying the FPR is also an inline filter? I priced on at AZ yesterday, they must be gold plated.
What is (are ?) the proper fuel pressure(s)?
Thanks
Old 10-07-2017, 11:52 AM   #30
Ecomike
Thanks, Richpin to the rescue again, gotta love that guy.
CHECK YOUR OIL!!
Old 10-07-2017, 12:01 PM   #31
Ecomike
AZ wanted over $80, Amazon Prime has the GK GF1846 brand for just under $20 (edit I just ordered one, will here Monday). AZ is toast. The Wix is about $49 at Amazon. 1 psi difference is not significant.
Old 10-07-2017, 12:21 PM   #32
Ecomike
Thanks for your feed back (and others here). Been dealing with a flooded shop and house from harvey, and long commutes, etc, so just finally got around to testing the fuel pressure, since I had other signs suggesting it was an issue...
Not sure yet what the OEM fuel pressure is? But I know now the Filter-FPR (it is also a Fuel Pressure Regulator, right???), is bad as the 2 second prime in the start up sequence works, but 2 seconds later the fuel pressure is already ZERO LOL
At idle on a cold start I was getting 30 psi at the injector fuel rail test port.
I suspect the pressure should be closer to 49????? But I am not sure what the Saturn OEM spec is???
Also I need to replace the schrader valve at the test port. It is leaking with the cap off. Any one know the part number or crossover for it???
No dual circuit for fuel pump. It's one line, one circuit, period. One signal to run the for pump whether it's for two seconds or as long as the engine turns. The PCM detects whether the crank sensor signal is being sent to the pcm or not and determines either to run the pump for two seconds or have crank sensor signals allow it to run the pump for as long as crank sensor signals are being sent to the pcm. This isn't a pump or pump signal problem.
With mileage approaching 300k and replacing pump and filter, did you check fuel pressure? Don't assume, verify it. Guessing can be an expensive way to replace parts without determine what failed. With an intermittent starting problem, fuel and spark are the two main issues that must be verified at least once when problems don't go away. Yes, fuel and spark are there because the engine runs but no one can tell you why one or both aren't giving near instant starts which we're expecting. Starting requires instant full operating pressure from the fuel pump - that's where a fuel pressure gauge is needed to see actual pressure at ignition on time just before starting. Spark needs to be verified by a starting test in the driveway to verify spark at low starting rpm. When you verify both are consistent without problems, the next step would be a compression test. Lower than normal compression is only one reason for poor startups.
Chasing the egr and secondary air pump problems may be contributing to this issue. Addressing each problem requires eliminating one problem at a time as one or several problems can contribute to startup problems.
Old 10-15-2017, 10:12 PM   #33
Ecomike
Still need a part number for the schrader valve in the fuel rail test port, so I can find one. The typical stores do not even list it.
No more lean codes in over a week. I replaced the FPR-filter today. ran it for 30 minutes, made a few trips, cycled the engine on/off a few times first. Then turn it off at a store (I was buying an impact wrench for my jeep....).
Saturn tried to start. It would catch-fire up and die in one second. 40 times I tried to get it to run. No joy. I disconnected the battery, grounded the harness, then reconnected it.
Started right up drove it home, cycled it 2 times, made another 30 mile trip and so far so good. So far no lean codes.
Oh, and once again, after disconnecting the battery, it went almost immediately to a no CEL code green status for about an hour. But clearing codes, never gets to the green status and takes forever to lock in the emissions monitors and throws a code 401 first.
Old 10-16-2017, 03:40 AM   #34
1-Fuel pressure between 40-55 psi.
2-Fuel valve stem replacement; DieselOrings.com
The site sells a fitting and valve core together. I couldn't find any place selling the fuel valve core separately. In the meantime while waiting for the correct fuel valve stem, I temporarily used a new ac schrader valve core; http://www.saturnfans.com/forums/sho...em+replacement
Old 10-16-2017, 07:01 AM   #35
SRGW
1997 SL1
ACDelco 12574525 . Check eBay $15.00
1995 SL1 231,591 Well Oiled!!
1997 SL1 62,650 Just A Teenager!!
CHECK YOUR OIL!!
Old 10-18-2017, 11:12 AM   #36
Ecomike
No more problems with hard starting for several days. Now always starting in under 1 second, under all conditions. This may have solved the schrader valve leak as well, since the FPR is no doubt holding pressure. The zero line pressure when off may be why I saw fuel under the fuel test tap. I will check it when I get a chance.
Thanks for help folks!!! 2001 SL1, 276,000 miles rides again
Old 10-21-2017, 07:09 PM   #37
Ecomike
No more starting issues, way better than its ever been since I bought it 10 years ago. No more lean codes (they were recent) or pending codes and the P0410 that has plagued it for 6 years or more is gone, for 2 tanks of gas???
Only dog code left is the 6 year old recurring P0401. Hmm, that I find to be very interesting!!!
Maybe I do not need to pull the head? But that story is on the other thread.
Thanks for the always awesome help here people!!!
Old 10-21-2017, 07:23 PM   #38
What solved this problem?
Old 10-21-2017, 10:10 PM   #39
Ecomike
New fuel pressure regulator-filter assy.
Old 10-25-2017, 03:25 PM   #40
Ecomike
Now that I have fixed the problem, I am noticing some faint pinging during heavy to moderate acceleration from about 15-40 mph on a cold first start up.
Still have the P0401 code, but I doubt it is related unless I have had the low fuel pressure hard start issue for 8 years?
Why would fixing the fuel pressure cause a cold engine pinging in these rigs.
In 45 years I have never had ping/knock issues on any vehicle unless the engine was too hot, or going up hill at wot in the wrong (too low) gear.
This is more like a timing issue to me. I do not think these Saturns have knock sensors? And there is no code listed for one thrown, just the old 401 code....
Carbon fouling from the low fuel pressure? And needs seafoam or.....water boarding treatment
2001 Hard Starting in Cold Weather dlacacres S-Series Tech 9 04-07-2014 04:51 PM
Hard starting midwest S-Series General 2 06-27-2009 11:54 AM
Hard Starting SL jdsdls S-Series Tech 0 06-24-2009 10:53 AM
Hard starting 97' SL2 rudy S-Series Tech 7 03-13-2005 07:44 PM
Hard Starting Vue Dar Vue General 15 02-26-2004 09:58 AM
