Old 10-04-2017, 02:08 PM   #1
Brittani_K
Brittani_K is on a distinguished road
Dizzy Strut/ball joint or something else??
I've replaced both hub assembly on my 02 SL2 5 speed! I also replaced tie rod ends! But my car is pulling to the driver side bad, it's a workout to drive even 40miles holding it to the right! But also when I go into a left hand turn it feels like it's jumping/jerking to the right! Someone said that my passenger front strut was bad! Would that cause this issue? If not what is going Wrong?? Plz help me figure this out! Don't want to spend a bunch of money an that not be the problem!
Add to Brittani_K's Reputation
Rate the quality of this post and help Brittani_K reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Brittani_K is offline   Reply With Quote
Old 10-04-2017, 02:19 PM   #2
Waiex191
Waiex191 has a spectacular aura aboutWaiex191 has a spectacular aura aboutWaiex191 has a spectacular aura about
Waiex191's Avatar
Default Re: Strut/ball joint or something else??
Sounds like it needs an alignment. You will have to do that after replacing tie rod ends.
Bryan Cotton
'99 SL2, 5SP bought new
'98 SC2, 5SP bought 2018
Add to Waiex191's Reputation
Old 10-04-2017, 02:39 PM   #3
Brittani_K
I did the string around the tires an everything looked good! I counted the threads (15 ¼) an put the tie rods back on at the same thread count! I agree it needs an alignment though! I just wasn't sure if it being out of alignment would cause it to jerk back to the right when I'm in a left hand turn! It feels like a shifting actually! An worries me cause it's like it's going to send me sideways! Someone shook the passenger side tire an said it's a strut bad! At first he thought it was the balloons on that side cause the tie was towed out at the bottom!
Old 10-04-2017, 08:04 PM   #4
bumpdraft
bumpdraft is a jewel in the roughbumpdraft is a jewel in the roughbumpdraft is a jewel in the roughbumpdraft is a jewel in the rough
bumpdraft's Avatar
1998 SW2
Setting it correctly within spec means getting both tie rods set to the correct “flat” on the hexagon.
Competition Clutch 10Lb. Flywheel. 14 stalls to date (and loving it)
Add to bumpdraft's Reputation
Ball Joint How To TombedOrchestra Vue Tech 6 05-08-2016 08:25 PM
'03 Ball Joint Chazberry Vue Tech 0 09-04-2014 04:56 PM
ball joint bmxracerchamp12 Ion Tech 9 10-07-2010 12:26 PM
Ball joint? jviper777 Miscellaneous Tech 19 06-21-2004 10:00 PM
Ball joint? Or not? Rozzwell S-Series General 3 11-13-2003 12:13 AM
