Old 09-22-2017, 11:07 PM   #1
codypico
codypico is on a distinguished road
Default Saturn l series 2000
My Brake lights wont turn off at all even if the car is on or off. The only way it seems for them to go off would be if i pressed the brake pedal up. Can someone please help me find out whats wrong
Add to codypico's Reputation
Rate the quality of this post and help codypico reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
codypico is offline   Reply With Quote
Old 09-23-2017, 08:29 AM   #2
Dsaturn
Dsaturn is a jewel in the roughDsaturn is a jewel in the roughDsaturn is a jewel in the roughDsaturn is a jewel in the rough
2001 L-Series 2.2L Sedan
Default Re: Saturn l series 2000
Inspect the brake pedal switch for damage. It is under the dash connected to the brake pedal.
Add to Dsaturn's Reputation
Old 09-23-2017, 08:59 AM   #3
nancy gilbert
nancy gilbert has a spectacular aura aboutnancy gilbert has a spectacular aura aboutnancy gilbert has a spectacular aura about
nancy gilbert's Avatar
2009 AURA XE
This is gonna take a bit of getting on your hands and knees ...
The brake light switch is located on a bracket at the top of the brake pedal.
Watch the brake light switch while pulling up on the brake pedal. If the switch moves around (loose) you'll have to adjust and re-tighten the switch. If the switch doesn't move, its a good chance the switch plunger (its green) is worn, and the switch will have to be replaced.
Good luck with it ...
Add to nancy gilbert's Reputation
Rate the quality of this post and help nancy gilbert reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
nancy gilbert is offline   Reply With Quote
Old 09-23-2017, 10:36 AM   #4
Welcome to SaturnFans, codypico. From your description, it's clear that the switch is working. In general, when a stoplight switch fails then the stoplights won't work at all. It's unlikely that the plunger has overextended its proper length and is thereby remaining in contact with the brake pedal. Nevertheless, be sure that the brake pedal springs are bringing the pedal back to its rest position. I would tend to think that the switch is out of adjustment.
294,000 miles-it keeps on rolling!
Add to pierrot's Reputation
No heat or Air 2000 Saturn L series indylover2 L-Series Tech 1 10-14-2012 11:38 AM
So how do you test the O2 sensor on a 2000 Saturn S-series? MikeIndiana S-Series Tech 15 03-09-2012 09:09 PM
2000 Saturn LS Series 2.2L geturdone L-Series Tech 4 11-24-2010 03:45 PM
Oil Leaking - Saturn L Series 2000 jetaudio77 L-Series Tech 2 03-13-2009 02:07 PM
2000+ Saturn S-series radio diagram hookem202 S-Series Mods 0 12-15-2007 03:59 PM
