#1 | ||||
![]() Join Date: May 2017
![]() I've researched on a few different occasions wanting to change out my whole exhaust system, I'm prepared to dump $1000 into a new system but I am just so overwhelmed by the responses I read from other people. I'm worried I will order something that will either no fit, or make my car run like ****.
I bought a 04' Ion-3 Coupe last year for $1,000... completely in love with it (and I should be, I've only ever owned 3 other cars, all ford focus's, with gay colors and standard windows) Anyway, can anyone just give me a simple answer. Every exhaust kit says it only fits a 2.0 redline, when I research can I use it anyway, I see people saying it will make the car run like **** but then I see people saying you can put a redline exhaust on a 2.2l and it work just fine which contradicts each statement right. I read I can use a LSJ manifold which I'm not even really sure what is it, I think its from a cobalt ss. Then I read you can use a 2.4 manifold on a 2.2 but again, not exactly sure what part that is or where it's from. Again I'm sorry if this is dumb and I know people have wrote countless threads on it but there all slightly different and I'm just hoping someone could give me a straight answer for my car model, show me exactly what parts I need to redo my entire exhaust system, so it sounds meaner, deeper then the leaking quiet stock one I have now. I rewrote this post 3 times trying to make it smaller, not wanting to write a story, trying to keep it short and simple for you guys. Thanks ahead of time for any input, help.
#2 | ||||
![]() BTW, this is what I've been looking at. As you can see, it only fits the 2.0 model. I'm just not sure if it's the whole thing, like will I still need a catalytic converter and exhaust manifold. Pretty sure the leak is around the flex tube area which is part of the catalytic converter. Again sorry If I sound retarded.
carid.com/magnaflow/street-series-stainless-steel-cat-back-exhaust-system-mpn-16663.html?singleid=20206684&url=1581462
#3 | |||||
![]() ![]() ![]() Join Date: Aug 2012
2005 VUE 2.2L
![]() Quote:
Is it throwing any codes? What trans do you have? What number of miles on it? What basic maintenance have you kept up with? ANy history on the car? If you really want to turn it into a money pit, you can go to sixthsphere for mod info. It would be a very real scenario to dump money in to the exhaust only to have the trans or engine go belly up in a few months. ... '05 ,2.2L, FWD,5-speed stick with transaxle death rattle is history,,, '17 Suby Forester 245216 mi. VUe is off to the dealer auction I'm a secondhand vegetarian. Cows eat grass, I eat cows.
#4 | ||||
![]() Join Date: May 2015
2006 ION-2 Sedan
![]() Welcome to the forums Rageclick! I would recommend ZZP parts http://zzperformance.com. They make really good quality stuff. The exhaust manifold would be the best place to start upgrading. The LSJ exhaust manifold that you mentioned is from the Cobalt SS and also the ION Redline. 2.25" is a good diameter for the catback portion and will give you a deeper tone. The ZZP catback is 2.5" iirc. You're going to want a good muffler and resonator too. The ZZP system has a muffler on it already and they have an add-on resonator option. If you don't go with the ZZP system check outhttp://portermufflers.com. Their mufflers have a nice crisp tone and don't drone too terribly. You can piece together the catback portion yourself with pre-bent pipe sections from your local auto parts store or the Summit Racing website, just search for "mandrel bent exhaust pipe". You will need (2)x 90 degree bends and (1)x 45 degree bend and everything else is straight sections.
But, like billysvue said, you could put money into the exhaust and have the engine and/or trans. go bad on you. If you have alot of miles on it already, it might not be worth the effort to upgrade. Hope this helps a bit.
#5 | ||||
![]() ![]() ![]() ![]() ![]() Join Date: Sep 2017
2004 ION-3 Quad Coupe
![]() I'm currently doing the same. It's super easy with the right tools. My flex pipe crapped out and I sounded like a WW2 fighter plane. SOO I had to remove the tranny anyways, but with 3 more bolts and removal of a few clamps and wire harnesses I hoisted the engine out. The manifold is like 8 bolts, I'd highly recommend starting there. Always go stainless, the 80 yr old you will be grateful when it still sounds crispy. Get the direct fit cat/flex section and the cat back is where you get creative. Stick to the factory bolt patterns so there's no second guessing the orders you make. Good luck
Exhaust replace/upgrade | djjsc | S-Series Mods | 52 | 04-23-2014 10:39 PM |
Wanting to upgrade the stereo in my 08 XR | Elmore8917 | Outlook General | 8 | 04-12-2013 04:04 PM |
Homemade Exhaust upgrade | Pokerking1993 | S-Series Mods | 11 | 01-29-2013 10:01 PM |
Can't Upgrade Exhaust | jrburkla | Vue Mods | 9 | 02-21-2007 05:48 PM |
94 SL2 EXHAUST UPGRADE | DAC94SL2 | Mods and Performance | 1 | 08-06-2001 09:42 AM |
