Old 09-09-2017, 01:56 AM   #1
Alexkepa12
Alexkepa12 is on a distinguished road
1998 SL1
Default Turbo 1998 Sl1
I have this idea about taking my stock 98 sl1 and doing an engine swap to an 01 sl2 5 speed, I got a person in town with a blown motor and good trans willing to sell for like 100 bucks, but what would I need to do to get a good powerful engine, Im not looking to spend 5 grand though. I know I will need to rebuild the sl2 engine, but I wanted someone's opinion on what mods should be done. I want a higher rev limiter, as well as a decent amount of power with a cheap turbo setup.
Thanks a Bunch,
Alex
Add to Alexkepa12's Reputation
Rate the quality of this post and help Alexkepa12 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Alexkepa12 is offline   Reply With Quote
Old 09-09-2017, 08:52 AM   #2
Default Re: Turbo 1998 Sl1
OldNuc has a point with SOHC -> DOHC swaps...if you aren't going to look up "how" and just ask a ton of questions that have already been asked a ton of times then swapping isn't for you. Just too many little change's. It's a fairly simple swap for '93-'98's if you stick with a '93-'98 motor (more challenging if going from a '93-'94 motor to a '95-'98 but still simpler than '99-'02 into '93-'98).
Mostly complete swap guide that so far hasn't been shut down: http://www.saturnfans.com/forums/showthread.php?t=88699
If you want NA power then what's been nicknamed "Deebs Rebuild" has the parts list you need; following that can bump compression close to 11:1 which isn't much fun with boost so kinda go the opposite way it says to to lower compression if boost is the goal.
Research MegaSquirt. It's the cheapest standalone PCM I know of and you'll need a laptop as well to tune it; the stock PCM can't handle worthwhile boost numbers.
If you can't find what you want on SaturnFans, I'd be sorta surprised but can happen so head over to Sixthsphere.com where the "big boys" at least used to live (400+hp out of our little 1.9L DOHC...lol) and still has more performance related info than here.
1996 1997 1998 1998 SL SW SC Arm Rest silverslp Classifieds 1 02-26-2017 08:16 PM
1998 to 1998 dohc engine swap....reflash? mrossbach S-Series Tech 2 03-19-2009 12:12 PM
Fs: 1998 Sc2 Ready For Turbo mark_92SC2 Classifieds 0 09-28-2005 12:48 AM
FS: Turbo Exhaust Manifold with Saab Turbo amazinghl Classifieds 1 07-14-2004 07:54 PM
For sale SOHC turbo manifold, downpipe, & T25 turbo turbo98sc1 Classifieds 0 08-27-2003 01:05 PM
