Old 09-02-2017, 09:07 AM   #1
surpontiff
surpontiff is on a distinguished road
Default Radiator fans running flood blast at all times
My radiator fans have been running full blast immediately after starting the car, and the level of noise it generates is obscene, made worse by the fact the fans themselves are pretty worn and generate a lot of noise anyway.
I brought it to a mechanic, and he said it was an electrical problem, he fixes it, and the bill was around $250, the replaced part being $21.
Unfortunately, it reverted back to always running full blast almost immediately, the only time the fans ran at the correct speed was the first time I started it after the repair, by the very next day the fans are back to running full blast.
It doesn't seem to actually be doing any harm other than being very loud and wearing out the fans, but I could be wrong.
I assume the actual problem may be somewhere else down the line as opposed to the part he thought it was and fixed. Is it worth bringing it back to get it re-done, am I incorrect in assuming he'd have to charge me again to find the actual problem?
It's a 2003 l200 4 cylinder 200,000+ miles.
Add to surpontiff's Reputation
Rate the quality of this post and help surpontiff reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
surpontiff is offline   Reply With Quote
Old 09-02-2017, 09:34 AM   #2
rb6667
rb6667's Avatar
2004 L-Series 2.2L Wagon
2004 L-Series 3.0L Wagon
Default Re: Radiator fans running flood blast at all times
Do you have any check engine warning lights on? The reason I ask is I had this same situation in the past. The cause was a bad thermostat causing the engine to run too cool.
Your temp readings should be 3/8's -1/2 way up on the gauge. If less than this, replace the thermostat. If these engines run too cool, this can cause the fans to run at very high speeds.
Keep us posted on what you find.
2004 L-Series Wagon 2.2
2004 L-Series Wagon 3.0
Add to rb6667's Reputation
Old 09-02-2017, 10:12 AM   #3
What was fixed and what part was replaced? Since the problem wasn't fixed and there should be a warranty for work performed, taking your car back and insisting the problem was never fixed should not incur more charges. If this shop can't fix the problem you may demand your money back. If the shop refuses to refund your money for repairs that didn't correct the problem, you may have to go to small claims court. Try to see if this can be resolved first.
Old 09-02-2017, 10:39 AM   #4
Russet
2002 L-Series 3.0L Sedan
As another said take it back to the repair shop and tell them to fix the problem they were suppose to fix as it is obvious they didn't fix it.
Add to Russet's Reputation
Old 09-02-2017, 10:18 PM   #5
As was pointed out by rb6667, a thermostat which is stuck open can cause this problem. Other members have reported the incessant running of the cooling fans with conditions similar to yours and it was corrected after the thermostat was replaced. This is a correction noted in the Factory Service Manual (FSM).
Obviously, this was not an electrical problem in the way that your mechanic thought that it was. If you would like to have information from the FSM to support your position in discussion with the mechanic please send a p/m with an email address.
If you don't already know, with 200K miles on the odometer your L200 is due for a cooling system service: flushing the system, replace all hoses, replace the thermostat, and replace coolant. Additionally, spark plugs are to be replaced.
294,000 miles-it keeps on rolling!
Add to pierrot's Reputation
Old 09-05-2017, 09:32 AM   #6
surpontiff
Thanks for all of the replies.
My check engine light is on actually. The codes seemed to imply something about an 02 sensor.
I'll take the car back to him and let him know the problem wasn't fixed.
The temp gauge usually reads right around the half-mark while I'm actually driving it, sometimes lower if it's idling ect.
fans running high dashiell General Saturn Discussion 1 10-05-2010 01:26 PM
radiator fans rinoa1@cfl.rr.c L-Series General 4 06-24-2010 02:34 AM
Blower Motor running full blast all the time HJackson L-Series Tech 2 03-02-2010 09:04 AM
Radiator fans not shutting off BryanF Vue Tech 11 05-24-2009 07:06 PM
radiator fans carlito Vue Red Line 5 08-06-2008 07:43 PM
