Old 05-09-2017, 10:51 AM   #1
SalemCat
SalemCat will become famous soon enough
Default Battery Disconnect Cut-Off SWITCH ?
I have a 95, 96, and 98 SW2.
I alternate driving them, but when winter is full on I often concentrate on one Saturn and just start and idle the other two for 20 minutes or so weekly. Or even take them to the grocery store just to exercise them.
Still, this is NOT GOOD for the Batteries. They tend to last two years at best.
The old style Batteries (not Saturn) have those huge Lead Posts sticking up in the air. Simple and inexpensive Switches have been available for them for decades.
But I can't find anything similar for the newer batteries.
Something that requires no actual install, because to be honest grabbing a wrench and unscrewing the Positive Cable from the Battery is no big deal. Which is exactly what I began doing this Spring, for the first time, and to my 95 SW2 which is off the road and is undergoing a fairly complicated Brake Job.
But flipping a switch would be even easier.
Suggestions ?
Add to SalemCat's Reputation
Rate the quality of this post and help SalemCat reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SalemCat is offline   Reply With Quote
Old 05-09-2017, 11:13 AM   #2
SRGW
SRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of lightSRGW is a glorious beacon of light
1997 SL1
Post Re: Battery Disconnect Cut-Off SWITCH ?
https://www.amazon.com/Side-Battery-Master-Disconnect-Switch/dp/B001N72FES
1995 SL1 228,500 Well Oiled!!
1997 SL1 58,600 Just A Teenager!!
CHECK YOUR OIL!!
Add to SRGW's Reputation
Rate the quality of this post and help SRGW reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Old 05-09-2017, 12:06 PM   #3
SalemCat
Default Re: Battery Disconnect Cut-Off SWITCH ?
CHECK YOUR OIL!!
That could be just the thing !
Old 05-09-2017, 12:15 PM   #4
SalemCat
CHECK YOUR OIL!!
How about this one ?
https://www.amazon.com/dp/B06XDCC4L7...s_ad_dp_asin_1
Old 05-09-2017, 01:10 PM   #5
A battery disconnect has some major drawbacks the largest one is it will not stop battery self discharge.
The fix is a small battery maintainer. These work very well and are also low cost. I use them for long term storage and have had years of success with them.
http://www.batteriesasap.com/12un12v10bac.html
You can search for the part number and might find a better choice. Some of these come with leads and some do not so be aware of that. Part number is 12BC1000d-1 will find them all.
Old 05-09-2017, 07:22 PM   #6
mattwithcats
mattwithcats will become famous soon enoughmattwithcats will become famous soon enough
I have used this 800 milliwatt battery tender for years...
Waterproof, only drawback is that it will not charge a flat battery,
just maintain one, it needs to have some charge...
http://products.batterytender.com/Ch...emisphere.html
Another option is a solar charger, I used one while on deployment for 18 months.
Started right up...
http://products.batterytender.com/Ch...ontroller.html
These have quick disconnects, so you can buy extra connectors.
I cut the ring terminal from a "O" to a "C", slid right under the terminals...
http://products.batterytender.com/Ac...l-Harness.html
2002 Silver SL2, manual, 5th gear swap (.605), 78,000 miles, black badges,
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 08-07-2017, 08:40 PM   #7
Jaegweir1259
Jaegweir1259 will become famous soon enough
2002 SC1
Battery Maintainer, offers a trickle charger walmart under $20
Battery Maintainer 12V 750mA Automatic Battery Charger Automotive
2002 Saturn SC1, Orange, 1.9L L4 SOHC 8V MFI
Add to Jaegweir1259's Reputation
Rate the quality of this post and help Jaegweir1259 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jaegweir1259 is offline   Reply With Quote
Abnormal idle after I disconnect the battery 98SatSl2 S-Series General 5 01-20-2017 03:46 PM
Engine stall with A/C after battery disconnect DavidBo Vue Tech 15 06-11-2012 09:12 PM
Battery disconnect..... Audiguy S-Series Tech 3 08-01-2007 10:58 PM
Ion2 battery disconnect Red Sash Jones Ion Tech 4 02-20-2007 08:14 AM
RPM problems after battery disconnect. Hahcrac S-Series Tech 4 06-29-2006 11:27 AM
