Go Back Forums > Models > Saturn Ion > Ion Tech
Old 06-24-2017, 05:49 PM   #1
JordanRAdams is on a distinguished road
2005 ION-2 Sedan
2004 ION-3 Sedan
Default Radio and AC quit simultaneously 2004 ION
Anyway, someone (previous owner or someone they had in the car, not us) sprayed the whole dash of my wife's car with pepsi or something, and it glued the buttons for the AC and the vent controls fast, so you couldn't turn them or push them. I let it go for too long, and today I decided to take it apart to clean it.
Took the radio out, took the AC head out, cleaned them up, put it all back...
Radio will only work when the key is in the ACC or Run position. As soon as you start the car, it shuts off and won't come back on until the key has been cycled again.
The AC head appears dead, although you can change the vent, adjust the heat, and change the fan level. The lights for the AC, Recirculate, and Rear Defrost functions don't light up, the lights behind the dials don't come on, the radiator fan doesn't come on, the AC compressor doesn't come on. Started checking fuses, and none are blown. Swapped relays, doesn't change anything. Jumped terminals with a bit of wire, radiator fan will run, AC compressor nearly stalls out the engine.
I didn't let the car run long enough for the radiator fan to turn itself on. I may do that later to try to narrow down the probable causes.
If any of this seems familiar to you, please advise. If I can't get it to work, I'm going to swap the radio and AC head from my 05 ION and see if they work (they work currently) but I'd rather pursue other avenues first.
Add to JordanRAdams's Reputation
Rate the quality of this post and help JordanRAdams reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
JordanRAdams is offline   Reply With Quote Sponsored Links
replace my 2004 ion radio for at 2006 ion radio emmanuelmatos1 Ion General 1 05-26-2014 01:44 PM
Radio: FM quit, but AM ok? jzinkel S-Series General 16 06-25-2012 09:18 PM
AC, cooling fan, and blower fan simultaneously shutdown JamesH S-Series General 1 10-23-2005 03:48 PM
radio, CD player quit Ace L-Series Tech 5 09-09-2004 05:42 AM
Service and Airbag Lamps on Simultaneously mr. ed S-Series Tech 3 02-03-2004 04:24 PM
Copyright ©2000 - 2018, vBulletin Solutions, Inc. The Saturn Enthusiasts Site.
