Old 03-06-2017, 01:20 PM   #21
trottida
trottida's Avatar
Default Re: Replacing or re-wiring the ignition switch.
Originally Posted by SgtDetritus View Post
Looks like I have an afternoon worth of fun to look forward to. My car is a manual tranny, so the circuit would run through a clutch switch, right?
That is correct. Yellow wire becomes purple wire at the clutch safety switch on the floor as per this photo.
Current rides
2001 SL1 MT (417,500 km @ 05/2018)
1999 SL2 MT (260,870 km @ 05/2018)
2011 Suburban LT (111,176 km @ 05/2018)
:canada:
Add to trottida's Reputation
Old 03-06-2017, 08:33 PM   #22
theviper121
theviper121 has a spectacular aura abouttheviper121 has a spectacular aura abouttheviper121 has a spectacular aura about
2002 SL1
On the 02 model the start runs through the clutch switch. I have a light switch in my sl1 and a heavy momentary push button to start. I bypasses the passlock with a single resistor in the bcm =)
Add to theviper121's Reputation
Rate the quality of this post and help theviper121 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
theviper121 is offline   Reply With Quote
Old 03-20-2017, 09:08 AM   #23
SgtDetritus
SgtDetritus has a spectacular aura aboutSgtDetritus has a spectacular aura aboutSgtDetritus has a spectacular aura about
SgtDetritus's Avatar
1995 L-Series 2.2L Sedan
Success! I ended up bypassing a bunch of stuff like a remote start kit would. I'm using covered switches for everything, including the one that triggers the starter solenoid. The cover is spring loaded so It's very easy to turn off. Pictured are the four switches that mimic the functions of the normal ignition switch.
The final switch that starts the car is located under the steering wheel, out of sight. the motion required to reach down and flip it on makes closing the cover a natural feeling motion (a happy coincidence)
thanks again guys! Next up, plugs, wires and (yet another) oil change
Rest in Peace, Yoda :-(
Green 97 SL2 named Yoda...When 266,000 miles you reach, look as good you will not.
Add to SgtDetritus's Reputation
Rate the quality of this post and help SgtDetritus reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
SgtDetritus is offline   Reply With Quote
need 97 sw2 ignition switch wiring diagram 55dude S-Series Tech 7 01-04-2016 07:38 PM
Ion will not do anything after replacing ignition switch... CrazyGrandpa Ion General 11 01-03-2015 12:12 AM
Faulty Ignition Switch or wiring? bachands S-Series Tech 3 06-07-2014 04:58 PM
98 sl2 ignition switch burn wiring scanlopa S-Series Tech 1 09-27-2013 09:42 AM
1995 SC2 Ignition Switch Wiring Problem SCATPK L-Series Tech 6 05-16-2005 09:11 PM
