Old 03-13-2017, 04:32 PM   #1
keenh
keenh is on a distinguished road
keenh's Avatar
2004 VUE Red Line
Default Fueling problem
From bad to ridiculous!
Since I bought my Vue, and got gas for the first time, I had problems fueling. I would fill it until the pump went off. Then slowly, pump by pump, fill it until it literally was at the very edge. This wasn't new to me because my Kia does it too. But today when I got gas, it went to the extreme. I started pumping and it stopped at .23. Ok, no big deal, the pump does that from time to time. Started again, same thing. I would get maybe .70 at a time. It can normally take 10 minutes to get gas. I just stopped at $20 because I have to work today and I only had 2 hours before I have to be there. Is there anything I can do to make the tank fill more quickly? It's ridiculous to begin with, but this is just infuriating. Any suggestions are greatly appreciated!
Add to keenh's Reputation
Rate the quality of this post and help keenh reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
keenh is offline   Reply With Quote
Old 03-14-2017, 07:03 AM   #2
atikovi
Default Re: Fueling problem
Try not sticking the nozzle all the way in.
Add to atikovi's Reputation
Old 03-14-2017, 05:45 PM   #3
keenh
keenh's Avatar
2004 VUE Red Line
I've done it every way imaginable. All the way in, all the way out, half way, you name it.
Old 03-14-2017, 08:41 PM   #4
If the canister vent valve is stuck closed when its supposed to be open during fueling, the sensitive fuel pressure sensor used in fuel nozzles triggers automatic shutoff. The canister vent valve is open to allow fuel vapor venting with ignition off, closes with ignition on to seal off fuel tank vapors and collect them in the evap charcoal canister for recycling to the engine intake. Emissions controls. The canister vent valve is usually mounted near the fuel filler neck, hidden behind the rear quarter panel and seen when removing the rubber seal around the fuel neck or while under the vehicle for tank repairs/inspection. If you can locate it, try a sharp smack to the assembly - it may loosen the solenoid valve back to open position (with ignition off).
Search threads about canister vent valves, error codes, diagnostics and troubleshooting.
Old 03-14-2017, 08:48 PM   #5
keenh
keenh's Avatar
2004 VUE Red Line
Thanks fdryer, I'll give it a look!
Old 03-17-2017, 01:27 PM   #6
flyingj
flyingj will become famous soon enoughflyingj will become famous soon enough
flyingj's Avatar
2001 L-Series 2.2L Sedan
For what its worth, this process of 'topping off' your fuel tank can cause this issue. You should stop filling your tank when the pump shuts off the first time. Continuing to fill it will cause fuel to enter the canister/vent line and then cause it to not vent the fuel vapors properly. This leads to the problem you are having where the car won't take fuel. There is a reason that the pump shuts off when it does.
2001 L-200 2.2l Mileage: 140,000
DOB: 05/08/01 Date Acquired: 07/01/07
2006 Vue 3.5L AWD Mileage: 130,000
DOB: 08/24/05 Date Acquired: 12/15/06
Add to flyingj's Reputation
Rate the quality of this post and help flyingj reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
flyingj is offline   Reply With Quote
08' XR Won't start after fueling up Slenderman Astra Tech 4 01-09-2016 08:03 PM
Fueling Question marmitage S-Series Tech 11 01-09-2012 09:58 PM
Hard Starting After Fueling bumpdraft S-Series General 20 06-01-2007 07:08 PM
Gas smell inside the car...after fueling pasha S-Series General 7 01-01-2006 02:02 PM
Fueling issue kayaksonvue Vue General 10 02-11-2005 10:15 PM
