Old 03-17-2017, 08:57 AM   #201
Chazberry
Chazberry's Avatar
Default Re: S-Series Automatic Transaxle "Reverse Slam Cure-All"
Originally Posted by Ez2rememb3r View Post
The filter exploding and blowing tran's oil all over the place is also gone with the old valve body, I seriously believe that the new one had some internal flaw(s) and was malfunctioning.
Who are you getting your VBs from? The one that was over-pressuring the Filter probably had a bad Pressure Regulator.
Add to Chazberry's Reputation
Old 05-18-2018, 12:05 PM   #202
Saturngears
Saturngears has a spectacular aura aboutSaturngears has a spectacular aura aboutSaturngears has a spectacular aura about
Hi guys, I just got done torquing the input shaft nut on my '02 SL2 (with a $75 kit purchased off ebay) but I think I have a more extensive problem (it didn't need a whole lot of extra torque to click to 112 ft/lbs)
When I removed the side cover I only had one shaft come out. Why might this be?
Add to Saturngears's Reputation
Rate the quality of this post and help Saturngears reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Saturngears is offline   Reply With Quote
Plastic Torpedo's S-Series Automatic Transaxle "Reverse Slam Cure-All" Question sdasilva S-Series General 7 08-28-2016 04:34 PM
Question About Wolfman's "Reverse Slam Cure." Zero_DgZ S-Series General 2 02-28-2009 02:59 PM
Reverse "Slam" Cure in Saturn Autotransaxles wolfman How-To Library 38 07-19-2005 03:15 PM
This may be an another reverse "slam" cure john_lu S-Series Tech 4 07-20-2004 07:09 AM
practice "reverse slam cure" on this $102 car eljefino S-Series Tech 7 05-30-2004 01:58 PM
