Old 03-06-2017, 10:41 AM   #21
Bradg
Bradg has a spectacular aura aboutBradg has a spectacular aura aboutBradg has a spectacular aura about
2004 VUE Red Line
Default Re: 2004 Vue red line misfire frustration
Vacuum numbers were well within specs of 17-20. Yep. Only codes are misfire.
Add to Bradg's Reputation
Rate the quality of this post and help Bradg reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Bradg is offline   Reply With Quote
Old 03-07-2017, 03:30 PM   #22
Bradg
2004 VUE Red Line
Hey Grumpy. I picked up a meter that would read mega ohms and checked out that crank sensor. Here's what I got.
Pin 1+ to 3-= no reading
Pin 1- to 3+= 11.8
Pin 1+ to 2- = no reading
Pin 1- to 2+= no reading
Pin 2+ to 3- = no reading
Pin 2- to 3+ = 13.72
This was on both sets of pins. Let me know what you think. It's a lot different than what you posted. Thanks.
Old 03-08-2017, 10:26 AM   #23
far2grumpy
far2grumpy's Avatar
Pin 1- to 3+= 11.8
I'm not sure you have bad CKP sensor - there are meter differences for sure but I also recall your engine starts and runs - plus your PCM does not have any of several CKP sensor fail codes set.
I'll post my fuel metering response here in case it could be helpful to others in years to come:
Here is FSM extract describing fuel metering system:
The function of the fuel metering system is deliver the correct amount of fuel to the engine under all operating conditions. Fuel is delivered to each cylinder by the fuel injectors. The fuel injectors are controlled sequentially by the powertrain control module (PCM). The PCM bases the control of the fuel injectors on several important engine parameters. These engine parameters include the following:
Engine speed (RPM)
Accelerator pedal position (APP)
Engine coolant temperature (ECT)
Intake air temperature (IAT)
Manifold absolute pressure (MAP)
Fuel control oxygen sensor input (HO2S 1)
See attached PDF extract for more information regarding how PCM or ECM manages fuel trim for closed loop operation.
Forum file attachment sizes prevents attaching the complete file but I can send if you (or any other member) PM's an email address.
Old 03-11-2017, 06:03 PM   #24
Bradg
2004 VUE Red Line
With the help of the old Grump, problem solved. Turned out it was my cylinder 1 coil. It was setting of all of my misfire codes. I wouldn't have thought one could have thrown them all, but it did. Runs perfect. Thanks for all the help.
Old 04-26-2018, 01:43 PM   #25
cosmo1
cosmo1 is on a distinguished road
2002 SL1
2002 SL1
Fuel injectors will do that
Add to cosmo1's Reputation
Rate the quality of this post and help cosmo1 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cosmo1 is offline   Reply With Quote
2004 3.5 V6 Multiple Misfire Codes todd8 Vue Tech 17 06-05-2014 12:16 AM
2004 V6 with Misfire code on all cylinders and P0300 Mark94 Vue Tech 4 10-09-2013 12:43 PM
2004 Misfire (2.2 4cyl), Battery dying Stupidusernames Vue Tech 21 12-10-2012 02:58 AM
2004 AWD REDLINE 3.5Liter Noise/Misfire Code? scastle25 Vue Tech 11 10-11-2011 04:37 PM
2004 L300 Misfire jonus311 L-Series Tech 4 01-18-2009 04:35 PM
