Old 02-17-2017, 08:31 AM   #1
dbgrigsby93
dbgrigsby93 is on a distinguished road
1999 SL1
Default Power Mirrors Circuit Board
On my 2001 SC2, I was removing the center console to replace the shifter cables and accidentally ripped the wiring out of the bottom of the power mirros/window module. The power window wiring was fine but I the circuit board under the mirror switches came out and I think small pieces fell off of it and down under the carpet never to be seen again. If someone could post a picture of their circuit board intact, that would show me what I am missing and help me rig something to make it work again. Also please send a picture of the bottom side of the mirror adjustment buttons themselves as I believe a piece from the bottom of the mirror selector switch fell off as well. Thank you.
Add to dbgrigsby93's Reputation
Rate the quality of this post and help dbgrigsby93 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
dbgrigsby93 is offline   Reply With Quote
Old 02-19-2017, 12:37 PM   #2
Default Re: Power Mirrors Circuit Board
OK, so I'm reading your post and I think to myself, "Good luck, buddy. What are the odds that some kind of weirdo has pictures of the circuit board and bits lying around? I mean, who does that?"
Then I remember, I have a switch sitting on the scanner. Didn't throw it away for some reason - broke the left-right switch when I was cleaning it.
My recommendation - find a junkyard (pick n pull are the best) and just buy a new switch. A lot of fiddily, small parts and springs in there. When disassembling the mirror switch, it is best to have it upside down when pulling the bottom off (so the mushroom cap direction switch is pointed down), otherwise all teh springs and copper contact parts fall out (ask me how I know )
If you are a masochist and want to reassemble the switch, and need parts, let me know and I can ship it to you. I don't think I can reassemble it (as a matter of fact, I may have put the round white switch together wrong for the picture), but you will have the parts you need. Welcome to Saturnfans
Old 02-19-2017, 12:57 PM   #3
Missed the edit window - added comments. It fell apart when I took the bottom out, before I realized it should be upside down when disassembling, and I think I may have put the circled part in upside down
Cluster Circuit Board Madness10 S-Series Tech 17 11-21-2012 02:33 PM
Cluster circuit board Madness10 L-Series Tech 2 11-15-2012 09:51 AM
sl2 fan problems/sunroof circuit board chevylivesever S-Series Tech 1 03-10-2010 10:13 PM
circuit board quiksc2 S-Series General 0 03-25-2007 06:37 PM
Circuit board on top of transmission needs replaced?? mlambert77 S-Series Tech 2 08-31-2006 09:58 PM
