Old 01-17-2017, 12:02 AM   #1
Duhminic
Duhminic is on a distinguished road
Default 2000 Saturn sl SOHC shifting points
Hey everyone quick question, I have a Saturn sl SOHC engine, just wondering what's the best shifting points for the best acceleration? I've hear that anything over like 4.5 rpm is worthless. Just curious for when I need to accelerate fast.
Add to Duhminic's Reputation
Rate the quality of this post and help Duhminic reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Duhminic is offline   Reply With Quote
Old 01-17-2017, 12:19 AM   #2
Default Re: 2000 Saturn sl SOHC shifting points
Max HP is 5k rpm so over 4.5k isn't "worthless" lol
Max torque is 2.4k rpm however and just drops from there.
I'd shift between 4.5k and 5k rpm in a SOHC for max acceleration, maybe play around with it to see if higher or lower works better. Of course...it's a SOHC, the gas pedal is pretty much broken for any performance test that doesn't involve distance's between gas tank fill-ups anyway.
Old 01-17-2017, 12:32 AM   #3
Duhminic
Thanks for the reply! I will see what works best
Old 01-17-2017, 04:37 AM   #4
Saturn Night
Are we talking part-throttle acceleration here, or wide-open throttle?
If you are only using 10-15% throttle, and wait for 4,500rpm, you are merely wasting fuel at that point. I drive my SC2 in "Performance" mode, because the DOHC doesn't make peak torque, until 4,800rpm. This holds the gear longer, between each shift. At about 10-15% throttle, it will hold until about 2,700-3,000rpm, and shifts back to 2,000-2,250rpm. However, the DOHC is being driven well-below the start of its peak torque curve, so to shift early actually creates excessive heat and reduces fuel economy slightly, due to increased "lugging" of the engine.
With your SOHC, peak torque occurs very early, so you do not need to hold gears during part-throttle acceleration for quite that long. Shifting from 2,000-2,500rpm should me more than sufficient to keep the engine at the start of the torque curve, as you accelerate through all five gears. This won't hurt your engine, because it was tuned for easy driving at low speeds, and achieves much better fuel atomization at its lower speeds.
When talking about wide-open throttle, ideally, you want to shift at your peak HP rpm and back to your peak torque rpm or just a few 100rpm after peak torque. Shifting early may not hurt this particular engine, due the the torque curve, but it certainly won't make any noticeable difference than shifting at 5,000rpm. Running past 5,000rpm is fairly useless, because your torque drops off sharply, and once the engine reaches 5252rpm, it is doing more work(HP) than the power(TQ) it is generating. This is a universal law of physics, for all engines.
Peak torque is 114 ft-lbs @ 2,400rpm, which equates to 52hp.
At 5,000rpm, you are making 100hp, which translates to 105 ft-lbs of torque.
Like I said, you won't really "feel" 9 ft-lbs of difference in lateral g forces.
You should see your best fuel economy, during cruise, at pr about 1,500-1,800rpm.
Just keep a close eye on your oil level, and make sure you check it weekly.and after/during long-distance trips. If you don't, you won't have your Saturn for very long.
Old 01-17-2017, 11:21 PM   #5
Macgyver
Macgyver is a jewel in the roughMacgyver is a jewel in the roughMacgyver is a jewel in the rough
You'd shift at or near redline as usual for max acceleration. For daily driving, I'd shift between 2k-3k revs. The sooner you can shift to keep RPM's low, the less oil you're going to burn through.
Add to Macgyver's Reputation
Old 01-18-2017, 08:09 AM   #6
gpfaster
gpfaster is on a distinguished road
Best way to have a sohc acclerate fast is to drive it off a cliff lol.
2400-2500 keeps up with the flow of traffic nicely for me. Might wind it out to 3500 on a short high way on ramp
2001 SC1
2014 Ram 1500
Add to gpfaster's Reputation
Rate the quality of this post and help gpfaster reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
gpfaster is offline   Reply With Quote
Shifting Points Please... Please VueofBubbles 2008 Vue 2 05-03-2015 05:11 PM
Shifting Points Please... Please VueofBubbles 2008 Vue 0 05-01-2015 11:28 PM
2000 Saturn SL2 Shifting Hard Booki S-Series Tech 3 06-04-2014 08:55 AM
high RPM shifting points?? jazzbow Vue Tech 7 12-04-2011 02:48 PM
Optimal shifting points? SinWagon Mods and Performance 2 06-09-2001 05:41 PM
