Old 01-05-2017, 11:41 AM   #1
Sir.Wilson72
Sir.Wilson72 is on a distinguished road
Default Fuel Problem / acceleration
Hello, Fans. Long time user first-time post. I hope I can get some great ideas to alleviate my problem. Here is the issue:
(In park)
Able to start with sputtering involved.
Attempt to "rev" the motor and begins to loose power.
While in park, It stays idle if I leave it alone, when I gas it, it dies out.
Could it be:
1) Oxygen Sensor
2) Sensor-Fuel Tank Pressure
3) Fuel relay
Any solid answers or high possibility guess would be greatly appreciated
2008 Saturn Astra
Add to Sir.Wilson72's Reputation
Rate the quality of this post and help Sir.Wilson72 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Sir.Wilson72 is offline   Reply With Quote
Old 01-05-2017, 01:50 PM   #2
Default Re: Fuel Problem / acceleration
Some history should be given; mileage, maintenance done, parts replaced, mods done, etc.. Any error codes?
Old 01-05-2017, 04:34 PM   #3
Sir.Wilson72
56,000
tune-up, spark plugs in the past 5 months, no major problems until now.
No other mods, repairs done before.
Old 01-05-2017, 07:09 PM   #4
billysvue
Originally Posted by fdryer View Post
Any error codes?
THere must be a check engine light, you would think OP would tell us that... COuld be a very low battery.
Last time it ran ok was ?
'17 Suby Forester
I'm a secondhand vegetarian.
Cows eat grass, I eat cows.
Add to billysvue's Reputation
Old 01-05-2017, 07:13 PM   #5
Sir.Wilson72
Low battery, no. I'm able to start my engine very easily at first. the nearest dealership that can give me diagnostic codes is far too far for me too travel to. And a local auto parts shop is not exactly have the best reputation for giving you the accurate codes. I could get codes from the Autoparts store, but at the same time they would have to come to me. There are not many that would do that.
Old 01-05-2017, 07:24 PM   #6
Originally Posted by Sir.Wilson72 View Post
56,000, tune-up, spark plugs in the past 5 months, no major problems until now. No other mods, repairs done before.
Sometimes little use of of our cars creates unusual wear. Throttle bodies may need cleaning. Catcons may disintegrate internally and partially block off exhaust flow. For whatever reasons, cars need to be driven at least once or twice a week for ten miles or more to have the engine up to operating temperatures.
Old 01-05-2017, 07:26 PM   #7
Sir.Wilson72
On average, I use it for/about 20 miles a day
Old 01-05-2017, 07:41 PM   #8
If allowed, will the engine warm-up on its own without shutting off (10-15 minutes)?
Old 01-06-2017, 08:54 AM   #9
emg77
emg77 has a spectacular aura aboutemg77 has a spectacular aura aboutemg77 has a spectacular aura about
emg77's Avatar
2008 Astra XR
If your check engine light is on, it's really worth it to get the codes read. I'd recommend you get something like this, https://www.amazon.com/BAFX-Products.../dp/B005NLQAHS
and get an app like Torque on your smartphone. All in, you'll be under $30, and you can use this on any car. Mine has more than paid for itself, plus, you can use it for so much more than just reading codes. You can read all the sensor values in the car in real time, like coolant temperature, temperatures ahead of and behind the cat, voltages, etc. You can also store and reset codes.
With a code, we'll really be able to narrow down what the issue might be.
When mine acted like you describe, it was the coil pack. It suddenly started running rough, acted like it was going to stall, and I managed to drive it about a half mile home but the car was not happy about it. I replaced the coil and everything was good as new. I had noticed some gradual decrease in fuel mileage (by about 2 mpg) in the months leading up to the coil failing, and it went back up after I replaced the coil.
Drives: 2014 Volt, 2015 Acadia
Past Cars: 08 Astra, 12 Enclave, 09 Traverse, 05 Vue, 04 Grand Prix, 00 Alero, 97 LeSabre, 72 Cutlass S
Add to emg77's Reputation
Rate the quality of this post and help emg77 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
emg77 is offline   Reply With Quote
Old 01-06-2017, 07:34 PM   #10
kikastra
kikastra has a spectacular aura aboutkikastra has a spectacular aura aboutkikastra has a spectacular aura about
kikastra's Avatar
2009 Astra XR
Is it possible its the Cam position sensor failing? I know when mine did, the symptom was a lose of power, but I don't remember it affecting idle, so maybe this is different. It didn't always throw a CEL either, but it did store a code. But if the sensor hasn't failed yet, maybe it is that, since that is one of the major failing components on these cars. Just a thought.
Add to kikastra's Reputation
Rate the quality of this post and help kikastra reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
kikastra is offline   Reply With Quote
acceleration problem? help? sccaligirl S-Series General 3 04-03-2011 05:18 AM
acceleration problem kcgp L-Series Tech 6 12-27-2010 11:53 AM
Acceleration problem...gets stuck...possibly transmission? Or a gas problem? Dingo Warrior S-Series General 34 03-29-2009 12:20 PM
Why is fast acceleration bad for fuel economy? redcannon S-Series General 21 06-01-2008 03:48 AM
acceleration problem green93SL2 S-Series Tech 1 06-20-2000 06:06 PM
