Old 11-28-2016, 10:24 PM   #1
Gundy
Gundy has a spectacular aura aboutGundy has a spectacular aura aboutGundy has a spectacular aura about
2000 SL2
Post Subframe clips for O2 sensors?
Does anybody know the part # for the small white clips that hold the rear O2 wiring harness onto the rear top of the subframe? There are two of them and I cannot for the life of me figure out what the part #'s are.
And unlike the 6 million dollar man, I cannot rebuild them.
I'm a long-time forum troll, this is my first post however. I am also a huge fan of Richpin!
Add to Gundy's Reputation
Rate the quality of this post and help Gundy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Gundy is offline   Reply With Quote
Old 11-29-2016, 12:22 AM   #2
Default Re: Subframe clips for O2 sensors?
Need 2 of these: http://www.wholesalegmpartsonline.co.../21023577.html
Old 11-30-2016, 07:20 PM   #3
Gundy
2000 SL2
Thanks fetchitfido! I have my subframe off and cracked both of these. I'll order them up. Hard to tell from the pics on that site. Much appreciated!
Old 11-30-2016, 07:54 PM   #4
Saturn Night
You may want to request whether they are available or not, first. That website is owned by Bob Hook Chevrolet, from Louisville, KY. I ordered exhaust manifold studs, and they showed available, BUT a few days after I ordered and paid for them, Customer Service emailed stating the part was discontinued. I called R. D. Banks Chevrolet, here in Champion, OH. They confirmed it was a discontinued part. However, the service manager pointed out to me that I could use the intake manifold studs in its place. So, of to my friend's local junkyard. He has a 1996 SC2 that has become the "victim" of my need to stockpile replacement parts, and I have been like a vulture picking over that car.
Bob Hook is issuing a refund, but it definitely has caused significant delays in getting my 1992 Saturn Exhaust "manifold" repaired after some lackluster installation by a trusted mechanic that normally does very good work.
Old 12-01-2016, 12:20 AM   #5
I wasn't 100% sure on that so I didn't suggest it. However, I'm 10000% sure intake manifold studs make better starter mounting bolts than the factory starter mounting bolts so if you can get 2 more (with nuts) really cheap it's a good idea to swap them out the next time you're under there
Old 12-01-2016, 07:15 PM   #6
TomM96
I would Not use InMan studs/bolts/nuts for Exhaust service.
The Saturn exhaust hardware is quite respectable. Most Intake hardware does not have the alloy spec to withstand exhaust temps.
{ask me how i know!!}
Add to TomM96's Reputation
Old 12-02-2016, 12:57 AM   #7
Macgyver
Macgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of lightMacgyver is a glorious beacon of light
If you work on cars often, you can buy an assortment below. It includes the O2 clips along with others for larger wire looms.
https://www.amazon.com/Swordfish-606.../dp/B01G2PV5LY
Add to Macgyver's Reputation
Use Saturn oem O2 sensors or generic sensors? 2strkBlu S-Series Tech 25 08-09-2016 01:55 PM
Eureka! 2 MAF Sensors, 3 Computers, 1 throttle body, and several sensors later!!!! jameskjeldsen L-Series Tech 2 03-16-2013 03:57 PM
Need Yakima q-clips for SW2 mbr S-Series General 7 02-21-2013 06:02 PM
Window Clips rickjbr S-Series General 6 02-23-2011 07:37 PM
Sound Clips Satellite Mods and Performance 0 03-27-2003 10:13 AM
