Old 11-12-2016, 01:53 AM   #1
mattwithcats
mattwithcats has a spectacular aura aboutmattwithcats has a spectacular aura about
Default P0301 code...
Turned cold again, so the Silver Surfer tossed me a P0301 code.
Did this last year when it got cold, reset it, tossed some Techron at it,
stayed away until tonight.
Still runs good, code came on just after startup...
Doing wireset and plugs tomorrow,
egr valve is next.
Anyone got hints / suggestions on how to clean the egr?
2002 Silver SL2, manual, 5th gear swap (.605), 79,900 miles, black badges,
Pennzoil Ultra Platinum 5W-30, NAPA 41516...
NGK BKR6E-11 spark plugs
Old 11-12-2016, 08:22 AM   #2
Cheyne
Cheyne will become famous soon enough
2000 SL2
Default Re: P0301 code...
See the richpin video:
https://www.youtube.com/watch?v=bt5lRTt6BsU
Why those spark plugs?
Add to Cheyne's Reputation
Rate the quality of this post and help Cheyne reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cheyne is offline   Reply With Quote
Old 11-12-2016, 08:30 AM   #3
EGR is not likely to cause a 301. Plugs and wires is a better bet.
Old 11-13-2016, 01:20 AM   #4
Saturn Night
Are you getting a high idle, around 1,200-1,300rpms when the engine is warm?
Old 11-13-2016, 05:02 PM   #5
Jim@HiTek
Jim@HiTek is on a distinguished road
I just had the P0301 code. It was persistent. Symptoms were mild, but I had 1200 RPM while stopped at a stop light, engine warm.
Checked the plugs...fine. Checked the plug wires...fine.
Replaced the OEM inferior spark coils...no change.
Replaced the ICM...no change.
Sprayed carb cleaner near the cyl #1 intake area...Bingo! RPM dropped a little. So, bad intake manifold gasket.
Replaced it yesterday and the SES light was out shortly after starting and the idle is normal between 750 and 950 RPM. (Took my brother and me 5 hours! But we were also watching a Ducks game and taking our time).
So at least test that intake manifold gasket with spray cleaner first before you buy a bunch of stuff...unless those items need replacing anyway of course.
2001 Saturn SL1 SOHC
1.9L, Basic Transport
Add to Jim@HiTek's Reputation
Rate the quality of this post and help Jim@HiTek reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Jim@HiTek is offline   Reply With Quote
2008 vue P0301 code JSTDV8 Vue Tech 25 02-15-2014 01:36 PM
SES light and code P0301 Jerry_Strn S-Series General 14 03-21-2011 08:47 AM
Code p0301 sliprimitive Ion Tech 24 01-31-2011 01:23 PM
p0301 code saturntom1 S-Series Tech 2 02-04-2010 10:59 PM
01 SL2 Code P0301 guzzel S-Series General 8 08-04-2009 06:33 PM
