Old 10-09-2010, 03:53 PM   #41
mike10
mike10 is on a distinguished road
2006 VUE 3.6L
Default Re: VUE 3.5L Automatic Transmission Fluid Change
Is there a filter or anything to change or clean on the Transmission?
Add to mike10's Reputation
Rate the quality of this post and help mike10 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
mike10 is offline   Reply With Quote
Old 07-16-2012, 02:09 PM   #42
sthoms
sthoms is on a distinguished road
The GM dealer says there is a "cartridge" with an o-ring seal for the transmission filter. Can anyone confirm this? I had him order it just in case he is right. I have it drained and 5 quarts of Z1 ready... :-)
Add to sthoms's Reputation
Rate the quality of this post and help sthoms reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
sthoms is offline   Reply With Quote
Old 02-20-2016, 02:23 AM   #43
Cyber0Guy
Cyber0Guy is on a distinguished road
2004 VUE 3.5L
I have not had a problem with my saturn and i have the tranny fluid changed every 100K. It is never burn or change in color. I do not have a tow either. The first 100K was in california and ariziona. the second has been in michigan.
Had the chevy dealership do both fluid changes.
The owners manual stated repacement every 25K if you have a towing package and if you tow the vehicle with a tow bar not a dolly.
I have looked all over the tranny for a dipstick to find none. All i found was the fill plug on the top and the drain plug below.
This is the most dependable vehicle i have ever owned.
Add to Cyber0Guy's Reputation
Rate the quality of this post and help Cyber0Guy reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
Cyber0Guy is offline   Reply With Quote
Old 03-06-2016, 03:09 PM   #44
ebenditt
ebenditt is on a distinguished road
ebenditt's Avatar
2004 VUE 3.5L
I found a great resource online at justanswer that has pics for the AT tranny (justanswer.com/saturn/2o655-know-change-add-transmission-fluid.html)
Add to ebenditt's Reputation
Rate the quality of this post and help ebenditt reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
ebenditt is offline   Reply With Quote
Old 03-08-2016, 11:18 AM   #45
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
There are 2 Filters inside the Honda 5AT - both require significant tranny disassembly to replace. The only maint you can do is a 'drain and fill' every 25k mi.
The Tranny Dip Stick is down low, next to the Lower Rad Hose . . .
http://www.saturnfans.com/forums/att...2&d=1362849715
Add to Chazberry's Reputation
Old 03-08-2016, 12:14 PM   #46
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
This link . . .
http://www.justanswer.com/saturn/2o6...ion-fluid.html
. . . is for the 2002-03 Aisin and VTi tranny - not the 2004-07 Honda 5AT.
Old 05-20-2016, 05:25 PM   #47
bigbird90650
bigbird90650 is on a distinguished road
Hi. I have a 2006 Vue 3.5 L with the MJ7 Honda 5AT tranny. I'm going to the Honda Dealer to get some tranny fluid. I'm guessing that they are going to draw a blank when I tell them that I need tranny fluid for an 06 vue. Does anyone have a part # or pic of the Honda brand tranny fluid that I need? Thanks alot.
Add to bigbird90650's Reputation
Rate the quality of this post and help bigbird90650 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
bigbird90650 is offline   Reply With Quote
Old 05-20-2016, 05:45 PM   #48
bigbird90650
I just ordered this fluid on Amazon. Is this the right one? Thanks
GM part # 22717466
Old 10-22-2016, 02:20 AM   #49
cookie1400
cookie1400 is on a distinguished road
2004 VUE 3.5L
I warmed up my 2004 3.5L Vue jacked it up and got 6 quarts out.... and it's still trickling out. Honda does not recommend using a flush machine. They recommend the 3X drain and fill method. And its much easier to fill through the actual "fill plug".But this is just my opinion.
Add to cookie1400's Reputation
Rate the quality of this post and help cookie1400 reputation points. Click the reputation button near the bottom left corner of this message box. Thank you!
cookie1400 is offline   Reply With Quote
Old 10-22-2016, 02:25 AM   #50
cookie1400
2004 VUE 3.5L
GM part # 22717466
I wouldn't use that Honda transmissions are very sensitive. Just order the real stuff from amazon. PM me if you want the section fromthe service manual.
Old 10-23-2016, 06:08 PM   #51
Chazberry
Chazberry's Avatar
2003 VUE 3.0L
2007 VUE 3.5L
That is the original ATF specified for the Honda 5AT. However, Honda no longer sells Z-1 which was superseded by Honda DW-1.
2007 Saturn Vue Automatic Transmission Fluid Change greensaturn How-To Library 12 05-30-2018 04:00 PM
How to change the automatic transmission fluid? atikovi Ion Tech 5 07-23-2006 10:49 PM
LS1 Automatic Transmission Fluid Change Info 1995-SL1 L-Series Tech 6 10-17-2005 11:38 AM
LS-1 Automatic Transmission Fluid Change 1995-SL1 L-Series General 8 09-23-2005 04:25 PM
Changing VUE automatic transmission fluid dohc 97 Vue General 20 11-24-2003 06:21 AM
